Old 10-16-2010, 11:59 AM   #1
empoweredwendy
Member#: 224926
Default Scratches & Chips on block...still use-able?
Ok, tore heads off 99 Impreza Outback 2.2 that son bought with supposed only mis-fire in 2 cyl. The kid busted off the compression gauge bottom in there, got part out. Any ideas on that? I was looking at the block and these chips alarm me; they are mostly on 1 & 3. Other side looked better but there was a lot more carbon and gunk on those pistons. My son thinks I know nothing, maybe I don't but seems to me it would interrupt a proper seal especially when you can't over torque. Whatta ya'all think? Can I use my 2.5 motor I have been saving for a Subie that needs an engine at a cheap price... totaled my 03 Legacy wagon. 2.5 SOHC with 69K on it. Can we swap it. Don't need to do wiring harness right? HELP!!!
Also, I am pretty sure when it was totaled, the timing belt was torn but still on till I removed it. Don't think anyone turned the engine over after it was off, but with kids and hubby, can't be positive. How do we make sure the engine is still good since it has now sat covered in my garage for almost 2 years.
http://s369.photobucket.com/albums/oo132/empoweredwendy/
empoweredwendy is offline   Reply With Quote
Old 10-16-2010, 12:01 PM   #2
lavid2002
Member#: 226864
Are you sure those are nicks + chips? When I took my heads off I had stuff that looked like that but I bet its just from having some flaws in the casting process. Im not sure though. I dont know it well enough. I think you can deck a block worst case scenario but a lot of garbage comes along with it.
Why dont you clean up the piston heads, cylinder walls, and block and take some pictures then?
Some looking flat across the block would be helpful I would imagine.
lavid2002 is offline   Reply With Quote
Old 10-16-2010, 12:51 PM   #3
empoweredwendy
Member#: 224926
Old 10-16-2010, 06:34 PM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
Everything looks normal.
Old 10-16-2010, 07:45 PM   #5
sidewayz
Member#: 5810
2001 S366 2.5RS
pssshhhh I've run worse :P
sidewayz is offline   Reply With Quote
Old 10-16-2010, 09:57 PM   #6
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Looks fine to me. Have all the surfaces resurfaced and it'll look good as new.
alcoolaid is offline   Reply With Quote
Will i still be able to use the vf39 turbo after spun bearing? mr.phil.roxass Newbies & FAQs 5 11-02-2009 12:45 PM
Will you still be able to use crusie control after getting a TBE/EM SubyWRXSti AccessPort 5 10-08-2006 10:56 PM
PDX Protune on 04WRX AccessPort --> able to be used on an '05WRX? doylfish AccessPort 3 06-17-2006 01:47 PM
can i spray paint my helmet and still be able to use it in auto x? Duo Motorsports 6 03-05-2004 01:44 AM
Question on paint. NOT scratches and chips. Evaider Car Care & Detailing 9 01-22-2002 02:52 PM
