Old 10-16-2010, 12:07 PM   #1
DausWRX
Member#: 134429
02 wrx
blu
Default main and rod bearing lube
when installing the main and rod bearings, is it safe to apply lube to the back part of the bearings?, i heard doing so can cause a spun bearing during start up and right now i have a shortblock sitting in my garage that i put together but in doing so i applied lube to the back side of the bearings, should i tear the block apart and reinstall the bearings? or am i just worrying to much?
DausWRX is offline   Reply With Quote
Old 10-16-2010, 12:12 PM   #2
StandardSti
Member#: 171471
2002 35r wrx
Take it apart and clean the lube off the back of the bearings. The surface should be clean and dry. only put lube on the tops.
StandardSti is offline   Reply With Quote
Old 10-16-2010, 12:17 PM   #3
stevenkelby
Member#: 207569
MY04 Forester XT
Red
Hell no, as above, clean that off, asking for a spun bearing.
stevenkelby is offline   Reply With Quote
Old 10-16-2010, 01:08 PM   #4
DausWRX
Member#: 134429
02 wrx
blu
good thing i asked, thanks for the input guys
Old 10-16-2010, 01:15 PM   #5
stevenkelby
Member#: 207569
MY04 Forester XT
Red
No worries, always better to ask
GL with it all.
Old 10-16-2010, 05:46 PM   #6
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
what makes it going to spin when there's a tab on the bearing???
if anything installing the rod bearing cap 180* of what it should be would spin a bearing in the long run.
FuJi K is offline   Reply With Quote
Old 10-16-2010, 11:05 PM   #7
Lucky Strike
Member#: 196786
Where do you think oil goes after it lubes the main bearings? I wouldn't lube it on purpose but nothing to freaking lose your shorts over
Lucky Strike is offline   Reply With Quote
FS: Built EJ257 shortblock! 99.5 CP Pistons, Eagle Rods, ACL Main and Rod Bearings 06TRDude Engine/Power/Exhaust 12 12-22-2009 09:24 PM
need clevite main and rod bearing part number 05blkwrx Built Motor Discussion 4 05-18-2007 09:41 AM
Who knows how to sell me EJ25T main and rod bearings? 2phless Built Motor Discussion 14 05-10-2006 06:31 AM
WRX & RS 99-01, same main and rod bearings? STIspain Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 08-12-2005 05:32 PM
