Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 10-16-2010, 03:41 PM   #1
Cusson
Member#: 95695
2003 WRX Sedan
ACLASS
Default Manufacturer Defect? Radiator Fan Tears Top Radiator Hose
Yesterday I was driving my car around and smoke started to come from under my hood. I immediately smelled coolant and knew it was some kind of leak. I pulled into a nearby parking lot and popped the hood. My whole engine bay was covered in coolant and I saw it spewing from a hole in the underside of my upper radiator hose. The hole was caused by the radiator fan blades hitting the hose. This is actually the second time this has happened to my car. The first time was back in 2007 and the hole was in the exact same place.
When the car is off there is about a half inch gap between the hose and the fan blades but I can only assume that when the engine torques, it brings the radiator hose in contact with the fan blades spinning. I'm just wondering if this is something that has happened to other people's cars? If not, I just wanted to give everyone a heads up to check their radiator hoses for wearing. When I picked up a replacement hose at the Subaru dealership they quickly denied it was anything they had seen in the past, but I got to believe it's some sort of defect. This has happened twice already and it's something that never should've happened in the first place.
Save yourself the trouble of cleaning up a nasty mess and buying replacement coolant and check up on that hose. I really hope this doesn't happen again on my car.
Cusson is offline   Reply With Quote
Old 10-16-2010, 06:29 PM   #2
mbaker
Member#: 188614
2004 WRB WRX wagon
VF-37 twin scroll on E85!
stock radiator? wait it doesnt even matter... just trim the hose... done!
mike
mbaker is offline   Reply With Quote
Old 10-16-2010, 07:55 PM   #3
Flesher
Member#: 7921
Sliver
This happened to me yesterday as well. It looks like there's a sleeve on there that was intended to prevent this, but mine must have migrated away from it's intended area.
Flesher is offline   Reply With Quote
Old 10-16-2010, 07:58 PM   #4
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
it happened to me last winter. Just cruising on the highway. must have been worn and then the extreme cold did it in
jmlaser is offline   Reply With Quote
Old 11-17-2010, 11:31 PM   #5
ProjektPhoto
Member#: 156702
2004 Impreza WRX
Aspen White 52E
This happened to me back in september. $13 from Napa and I was back on the road.
ProjektPhoto is offline   Reply With Quote
Old 11-18-2010, 09:33 AM   #6
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
trim the hose and put back the stock rubber sleeve on your replacement hose.
fastnoypi is offline   Reply With Quote
Old 11-18-2010, 04:40 PM   #7
fastwrx25
Member#: 126441
03 bugeye
if this is happening often, consider new engine+tranny mounts.
fastwrx25 is offline   Reply With Quote
Old 11-18-2010, 05:21 PM   #8
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
+1 for trimming the hose. Trim the end of the hose and it will pull it away from the fans. Then there's no issue. Also watch out for the alternator pulley.
340Duster is offline   Reply With Quote
Old 11-18-2010, 06:25 PM   #9
gsla72
Member#: 224573
2002 Wrx Wagon
Midnight Black Pearl
I used part of my old hose cut down and slit in half to reinforce the sleeve that was already there. It dosen't look like it should hit it, but i figure the extra five minutes was worth the peace of mind.
gsla72 is offline   Reply With Quote
Old 06-12-2011, 01:21 AM   #10
CrazyButHappy
Member#: 58545
2003 WRX
This exact thing happened to me as well, but my motor mounts and transmission mounts are worn out. I wish the Subaru techs at the dealership had mentioned this when I bought a new radiator and hoses. It seems like I just got the bitter sweet smell of cooked coolant out of my car after the radiator split open.
CrazyButHappy is offline   Reply With Quote
Old 06-12-2011, 01:39 AM   #11
rexblake
Member#: 178426
2010 Audi S4
That. Also trim the hose on either side as well. Particularly important if you pipit in an after market radiator ( the fan hits the hose at idle).
rexblake is offline   Reply With Quote
Old 06-12-2011, 11:55 AM   #12
hoffmanEstates
Member#: 122043
04 wagonier
psm
hoffmanEstates is online now   Reply With Quote
Old 07-07-2011, 01:06 AM   #13
T-REV16
Member#: 264615
05 Impreza WRX
I just put an aluminum radiator on mine today and this exact same thing happened to me when I was out test driving it. I taped the hose and unplugged the fan just so I could get my car home.
I'm going to go buy new radiator hoses and try to trim the top one to see if that helps
T-REV16 is offline   Reply With Quote
Old 07-07-2011, 02:31 AM   #14
NDS1521
Member#: 269920
04 wrx
Same thing happened to me last fall and i just assumed it was from the previous owner accidentally doing while working on it or something. Interesting that this is somewhat common. Ill def be checking my upper hose once in while from now on.
NDS1521 is offline   Reply With Quote
Old 07-07-2011, 07:27 AM   #15
Vlad
Member#: 46135
02 WRX
Sti V9 Spec C
I didn't have this problem, but saw how easy it can happen with the aluminum radiator and took a long time trimming both the top and the bottom hoses.
Old 07-07-2011, 11:33 AM   #16
eastcoastbumps
Member#: 29201
BMW M3
Honda S2000x2
Unplugging the fan won't stop them from spinning and cutting the hose again. You need to tape the fan in place so the wind won't spin it.
I went through 3 hoses at one track day. I ended up pulling the fan.
Also, check your upper radiator mounts.
eastcoastbumps is offline   Reply With Quote
Old 07-07-2011, 10:50 PM   #17
02MillzRex
Member#: 206359
2005 WRX
CGM
Happened to me.....
02MillzRex is offline   Reply With Quote
Old 01-13-2012, 11:31 AM   #18
SubeSobczak
Member#: 241129
Same thing happened to me, finally wore down enough to start spraying coolant everywhere.. Huge mess
SubeSobczak is offline   Reply With Quote
Old 01-28-2012, 11:29 PM   #19
Heider
Member#: 172173
2005 Impreza WRX
05 wrx here. same problem. car started smoking, so i pulled over and found coolant spewing out of the upper radiator hose. looked like it was from the fan rubbing over time. seems like a bad engineering choice to me.
Heider is offline   Reply With Quote
Old 05-19-2012, 01:00 AM   #20
Magnum626
Member#: 62856
MBP SQC#197
Stockpiling parts...
Just happened to me today.
I'm gonna have to get my mounts checked. I had the hose put in with a new rad in January. Only started smelling coolant last few weeks but couldnt find it. I thought it wsa the pulley rubbing on it but couldnt find anything there. Didn't even know it was coming from the hose since the stock air dam thing was over it.
I couldn't figure why it started only happening though. It was clear for over 3 months, the way it was cut it was like it was getting closer and closer to the fan in just a few weeks or something.
Magnum626 is offline   Reply With Quote
Old 05-19-2012, 02:14 AM   #21
paulpat
Member#: 237145
02 WRX
12 FXT
Yup same here. Seriously i just trimmed it so it wouldnt have that problem.
paulpat is online now   Reply With Quote
Old 05-19-2012, 12:50 PM   #22
Magnum626
Member#: 62856
MBP SQC#197
I think I might need new motor mounts. Looks like the engine was moving more than normal which probably contributed to the wear on the upper rad hose causing the fan to get closer to it.
http://forums.nasioc.com/forums/show...7#post37178097
Old 05-19-2012, 01:33 PM   #23
wrxlaunch
Member#: 181298
2015 WRX Limited
Lightning Red
U might I just had mine ripped by the fan and replaced motor mounts and all has been well.
wrxlaunch is online now   Reply With Quote
Old 06-11-2012, 04:15 PM   #24
Gods_Pinky_Toe
Member#: 179917
2004 WRB WRX
SG E46 M3
This happened to me this past Sunday, this thread has been extremely helpful. My thanks to all the contributors!!!
Gods_Pinky_Toe is offline   Reply With Quote
Old 06-12-2012, 09:08 AM   #25
flash02
Member#: 78916
Yeah mine went this past Sunday as well, I'm going to replace the engine mounts, this is the second time this has happened to me. With the engine off the fan does not hit the hose, the only thing I can see causing this is and expanding hose and the engine moving around on the mounts.
flash02 is offline   Reply With Quote
OEM radiator fans VS mishimoto radiator fans stikid2005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 06-20-2010 06:09 PM
WTB radiator fans, front radiator hose, power steering reservoir, wrb hood and bumper subizzo02 Private 'Wanted' Classifieds 7 05-30-2009 01:39 AM
sti radiator fans vs. wrx radiator fans GrimmSpeed Subaru Conversions 2 12-21-2007 01:23 PM
Top radiator hose rubbing on radiator fan! whitereximpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 08-25-2007 04:26 PM
Upper radiator hose is hitting radiator fan! Shinallsm Service & Maintenance 5 03-29-2007 09:20 AM
