Old 10-16-2010, 06:47 PM   #1
Twills(215)
Member#: 256636
2001 Impreza Outback
White and gold trim
Default Parking Lights Keep Flashing? HELP
I have an 01 impreza outback sport 2.2 four cylinder. I took the thing out to do alittle ripping on 95 and took the rpm's past 6 grand, almost red lining the thing and my check engine light came on. Figuring it was nothing, I went to take the ground out to clear the light and after a few minutes, i placed the negative back on and just my parking lights keep flashing. I'm wondering, why is it doing that and how can I make it stop. I was thinking it may be the computer resetting, I have no idea.
Twills(215) is offline   Reply With Quote
Old 10-16-2010, 06:54 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
hit the unlock button on your remote.
Old 10-16-2010, 06:58 PM   #3
Twills(215)
Member#: 256636
White and gold trim
I don't have an alarm, just a key and I tried playing with the locks n such. no good
Old 10-16-2010, 07:40 PM   #4
Audi20Tdriver
Member#: 206040
2009 Audi A4 2.0T
APR Stage 1
Momma says aint no such thang as dumb questions so I'm gonna ask.... Your hazard lights button didn't get pressed in somehow did it?
Audi20Tdriver is offline   Reply With Quote
Old 10-17-2010, 10:20 AM   #5
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
2001 outback doesn't have the remote lock/unlock? I don't know if it was an option then or not. Mine doesn't have an alarm either, but the unlock button works. You can also try the unlock on your door(again, I don't know if power locks were an option and for what years). Last thing you can try is to just start it. Oh, and +1 for the hazard button...
Old 10-20-2010, 10:24 AM   #6
Pohenegamook
Member#: 134262
cyka blyat
Originally Posted by Twills(215) View Post
my check engine light came on. Figuring it was nothing...
Really? Those aren't just blinkenlights Subaru added for fun..
^^ this right here is an electrical discussion, for the electrical subforum
But since we're here, if you are lucky you blew a fuse / knocked something loose/ hit the hazard. If you are unlucky, you'll be hunting electrical gremlins for weeks...
Are you sure they are parking lights? OR are they hazards / turn signals? (just the front or all 4 corners?)
Edit: Could be an alarm / security thing - you might need to jam you key in the ignition and turn it like 10 times in 20 seconds or whatever....different years have different procedures for manually (w/ key) overriding the security system.
Pohenegamook is online now   Reply With Quote
Old 10-20-2010, 12:31 PM   #7
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
Yeh, that screams security system - my '99 OBS did some quirky thing like that when I had it. The solution involved pressing a mildly inconspicuous button under the dash.
LetItSnow is offline   Reply With Quote
Old 10-20-2010, 02:14 PM   #8
bangedlegacywagon97
Member#: 215017
97OB 2004 civic
Leave key in Ignition position. Remove negative terminal and then return key to Acc position connect terminal again and start. Worked on my 98 Outback
bangedlegacywagon97 is offline   Reply With Quote
Cruise control light keep flashing whats up with that jetblue2004 Service & Maintenance 13 11-22-2010 08:49 AM
Reset ECU -- Parking Lights are Flashing! Spenk General Community 2 08-22-2006 01:25 PM
05 sti, reset my battery and now my parking lights don't flash when arming alram coil222 Electrical & Lighting 1 05-30-2004 03:59 AM
