Old 06-16-2011, 07:22 AM   #26
SCOOBMAN2011
Member#: 285788
Is the Td06 /60-1 technically the same as a forced performance red? or is there more differences, as i know the red uses a garret 60-1 wheel ,
thanks
SCOOBMAN2011 is offline   Reply With Quote
Old 08-18-2011, 04:13 PM   #27
EpicRasta
Member#: 270754
are there any updates to this thread?
EpicRasta is offline   Reply With Quote
Old 08-23-2011, 02:30 AM   #28
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Bumpdates?
sense of nature is offline   Reply With Quote
Old 08-24-2011, 09:35 PM   #29
Dr. octagon
Member#: 171127
2015 Subaru
in for an update as well
Dr. octagon is offline   Reply With Quote
Old 03-16-2012, 06:47 AM   #30
ROFLBOXER
Member#: 188503
2003 Built EJ257 WRX
2.5xtr+W2A IC
I'm curious to see how these have held up since this thread started. I need a new turbo, and I can't see myself affording a dom 2.5xt-r anytime soon.
ROFLBOXER is offline   Reply With Quote
Old 03-19-2012, 08:31 PM   #31
SCOOBMAN2011
Member#: 285788
i did build a td05 -60-1 with a mhi td05 small 16g and kando dynamic kit ,
i never got time to fit it in the end, so sold it , but still interested to see how these work,
Old 05-13-2012, 12:05 AM   #32
UK-Wagon
Member#: 232430
555 XTi
1 AW & 1 CGM
Ive herd good things about these turbos holding pretty well. BUT, recently a customer brought in his 06 Legacy Spec B with the 16g Version installed complaining of smoke and noise. The turbo let go do due oil debris going through the thrust bearings and clogging the oil passage.
Edited; took the turbo apart and found the cause.
UK-Wagon is offline   Reply With Quote
Old 05-13-2012, 02:13 AM   #33
banshee04
Member#: 179014
'06 WRX/STi
Built Motor/6766/E85
I have the TD06H 60-1 and I am absolutely impressed by it.
My car makes 483awhp at 21psi on E85.
Cant wait to turn it up to 30psi and hopefully get close to 580ish awhp
banshee04 is offline   Reply With Quote
Old 05-13-2012, 09:10 AM   #34
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
What RPM for fully spooled in 3rd, for 21PSI?
Old 05-13-2012, 09:39 AM   #35
STi MAN86
Member#: 287906
2006 STi
I see 20-21psi with the TD-06H 60-1 at 4,000rpm in 3rd
2.5L 2006sti
STi MAN86 is offline   Reply With Quote
Old 05-13-2012, 09:57 AM   #36
Vlad
Member#: 46135
02 WRXstiV9 Spec C
C63 AMG
Not bad, especially because the test gear for the Sti should be 4th, out of 6 and for the WRX 3rd out of 5.
So in 4th, you probably see 21 by 37-3800 RPM. Now with you, is that pump gas, or also E85?
Old 05-13-2012, 10:05 AM   #37
STi MAN86
Member#: 287906
2006 STi
in 4th gear i see full boost 23-24 by 3,800-3900 rpm that's on 98 Australin octane with 10% ethanol and 50/50 methanol/water
Old 05-13-2012, 01:07 PM   #38
djc1827
Member#: 238618
2011 WRX
11.82 stock 5sp/eng vf52
I love how people automatically bash turbos that are sold on ebay....are you aware that all the overpriced parts you buy from venders on here are on ebay for 10% cheaper, no tax, and free shipping. People said my racer x fmic was garbage ebay stuff too until I hit the track. That company makes quality turbos and sells em cheaper than the US companies. Just admit it, better hope Borgwarner or Kinugawa dont start making similar bolt turbos like Blouch or FP or they will take over the market
djc1827 is offline   Reply With Quote
Old 05-13-2012, 06:59 PM   #39
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
Installed a Kinugawa td05 20g chra in our old '95 L sedan that my son sold to his friend, his blew and he didn't stop driving it. He's short on funds so I helped him out. Bearing housing was fried, oil seal area was shroomed out from the turbine wheel grinding away at it. Couldn't rebuild it, so I bought an assembled Kinugawa chra for $350 and reused the turbine housing, compressor housing, oil lines, etc. Car has an EJ257 block w/ mahle pistons, EJ25D heads, hydra 2.12 rev 6, 38mm EWG. Its holding up well since January and the kid is always on it, boost controller is set at 23 psi. I've used several Kinugawa/Kando products from authentic boosting on ebay and I've had great luck with them.
theotherguy is offline   Reply With Quote
Old 05-14-2012, 12:39 AM   #40
V8Slayer
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
Thanks for the review. I'm contemplating buying one of the td05 turbos from them.
V8Slayer is offline   Reply With Quote
Old 10-15-2012, 06:09 PM   #41
cueballsi
Member#: 202736
2002 WRX- 6spd - MBP
1992 Civic VX 40MPG
Any other news about this particular turbo????
Anyone figure our what the Lbs/min is on this thing???
Was looking at this one ...
http://shopping.kinugawaturbo.com/ki...1-1-2-1-1.aspx
Also Can anyone explain what the differance is between the TDO5H, TDO6H, and the TDO6SL2 versions????
http://shopping.kinugawaturbo.com/su...covertype.aspx
cueballsi is offline   Reply With Quote
Old 11-23-2012, 04:41 PM   #42
RustyHinge
Member#: 299742
2007 STI Limited#382
07 WRB STI sold 9/28/12
This is my very question ^^^ I'm interested
RustyHinge is offline   Reply With Quote
Old 11-23-2012, 06:23 PM   #43
theotherguy
Member#: 191514
'05 FXT 6spd, 98
http://forums.nasioc.com/forums/show...2319043&page=7
I run the td06sl2 60-1, I put up a virtual dyno run to show spool. Tune is low timing, super safe at 18 psi. Weight is also very light, should be 100+ lbs more.
You can read the debate on td06sl2 vs td06H4 11 blade. Spool or high end power.
Old 01-30-2013, 05:22 AM   #44
riggy30
Member#: 158321
2010 WRX STI
Is this the 2.4" or 3" inlet? And overall, how do you like the spool and top-end? I'm torn between this and the td06h 20g...
riggy30 is offline   Reply With Quote
Old 01-30-2013, 08:42 AM   #45
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Will be installing a td06H 11 blade 20g into a 2012 STI in the next month or so. I'll post up a graph when its done.
Old 01-30-2013, 10:53 AM   #46
RustyHinge
Member#: 299742
Looking forward to seeing the chart for sure
Old 03-06-2013, 03:37 AM   #47
decodeddiesel
Member#: 64102
05 STi
48W
Really considering one of these turbos when I finish building up my STi's block.
decodeddiesel is offline   Reply With Quote
Old 03-06-2013, 03:17 PM   #48
nate_fisher
Member#: 270482
2011 turbotek fxt
[email protected] 4eat xt record?
I love my td06sl2 20g 8cm great topend and spools is good seeing 23psi by 4000 rpm in a auto 4eat. The price helps a little to lol.
nate_fisher is offline   Reply With Quote
Old 03-07-2013, 12:07 PM   #49
decodeddiesel
Member#: 64102
05 STi
48W
That is encouraging. I am scratching together the funds to rebuild my shortblock with forged pistons and rods. Once this is done I am hoping to install the 3 in. inlet version of this turbo along with the 8 cm^2 turbine housing and use the 38mm Tial I already have on the car.
To folks running E85 with this turbo on an EJ257, what size injectors are you using? I have DW850s now so I could run E85 with the VF39 I had on the car, but I am thinking of upgrading to 1000 cc topfeeds.
Old 03-08-2013, 12:15 PM   #50
nate_fisher
Member#: 270482
2011 turbotek fxt
I have id1000cc on my car with a 300lph pump and they are maxed out at 23psi tapering to 19psi at redline on e85 at stock fuel pressure. So i think your 850cc will not get you were you want with e85. I am going to do a dw hardwire kit for my pump to bring down the idc but i could also bump fuel pressure with a aftermarket regulator if the hardwire doesnt get me were i want to be.
TD05 20g or TD06 20g battousaix Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 27 12-09-2011 05:34 PM
WTB: TD06-18g or TD06-20g or FP Green sonic03rex Private 'Wanted' Classifieds 5 01-15-2007 05:31 PM
