Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 10-17-2010, 09:45 AM   #1
Join the Riot
Member#: 158523
Default Will a JDM forester ecu run an EJ205
Basiacally, as per the title, i have a JDM SF5 forester, with a spun big end bearing in the stock open deck EJ20G. Found a replacement engine, however it is an EJ205. Will my current ECU handle the EJ205 if i were to drop it straight in? and if not, what would be the simplest route to making it work? I have decent EJ20G heads, intake manifold etc if required. Or will a piggyback ecu be required?
Join the Riot is offline   Reply With Quote
Old 10-17-2010, 01:22 PM   #2
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
Put the EJ20G heads and intake manifold on the EJ205 shortblock. That's the easiest way.
Old 10-17-2010, 10:00 PM   #3
Join the Riot
Member#: 158523
yea i figured that would be best. One thing though, I keep seeing posts saying the pistons at TDC are above the surface of the block, but these posts seem to always be in reference to the closed deck variety 20G. IF this is true, do i just use a 205 head gasket? as if this is the case and i use the gasket designed for the 20G heads ill lower compression, which i imagine may have implications with the stock ECU?
Old 10-17-2010, 10:06 PM   #4
69subaru360
Member#: 159682
1995 WRX
1998 2.5 RS
The EJ20G pistons are slightly above the deck. The EJ205 aren't. The compression will change some. You have to do the math to see how much, then decide which gasket to use to get it where you want it to be.
Old 10-17-2010, 10:47 PM   #5
Join the Riot
Member#: 158523
any idea what the tolerance is? i can't seem to find a number anywhere
JDM forester ECU pinout 02SKReX Pre-2002 Factory Turbo Powertrain 18 10-22-2014 07:47 PM
Will an '05RS (DBW) harness run an '02RS engine using the '02RS ECU? urabus555 Subaru Conversions 3 07-28-2009 10:08 AM
Will my 2006 WRX ECU control an EJ257 longblock? saab-on-the-cobb Built Motor Discussion 17 04-05-2009 10:42 AM
How to run an Ej207 V8 engine on Ej205 Computer? WRXINTX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 02-22-2008 12:46 AM
will my 91 legacy ecu run without the knock sensor hooked up? bobturismo Engine Management & Tuning 11 03-06-2004 05:05 PM
