Old 10-17-2010, 10:53 AM   #1
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
Default primer and paint question
sorry if this is the wrong forum- i have a body question for a car im painting:
i've just applied my 1st coat of a high build primer and found some swirl marks that I hadnt noticed before. is it best to sand it with say a 500 grit before applying more primer, or should i spray another coat and then sand?
thanks
hendo2.5 is offline   Reply With Quote
Old 10-17-2010, 01:26 PM   #2
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
This is the wrong forum, but I'll anwser anyway.
Most primer/surfacers call for a pretty course surface (usually around 120-220 grit) If you plan on spot priming some touched-up areas, I would not recommend 500 grit as you could end up with adhesion issues. Touch-up the areas you need to touch-up with 150 grit and re-prime the touched-up areas only. No need to re-shoot the whole thing if it's just a few spots that need to be corrected. Also, you never know, you might be able to sand the "swirls" out if you have enough material on there. After all, that's what high build primers are designed to do...
Edit: if you have to ask this sort of question, maybe you shouldn't be painting a car? Not trying to be a dick, but that's how I feel.
kcpaz is offline   Reply With Quote
Old 10-17-2010, 09:41 PM   #3
lostbeachbum
Member#: 261212
thanks
I would use 250 grit sand paper after your first coat of HBP, to get rid of those marks. I think 120 would be too harsh, wince that is what you should have been using before you sprayed the car, and 500 is to fine to really do anything significant. I would use 500 possibly after your second coat of high build primer and before your base coat.
lostbeachbum is offline   Reply With Quote
WTB 04-05 Primered/OBP Painted Front Bumper!******** JDM555 Private 'Wanted' Classifieds 1 10-23-2007 03:42 PM
White STi w/ Gold Rims Pic Please?? rim color and paint questions also ASDFG Interior & Exterior Modification 26 06-21-2004 07:58 AM
Primer without paint? HudsoN456 Newbies & FAQs 2 08-06-2002 08:54 PM
primer or paint TurboCharged WRX Interior & Exterior Modification 7 02-18-2002 09:13 PM
