Old 10-17-2010, 09:16 PM   #1
bigredOBS
Member#: 260219
2000 Impreza OBS
Tan
Default YES/NO question: do 02-07 WRXs use the same main pulley and a EJ22??
basically the title says it all. are wrx crank pulleys the same as the phase 2 EJ 22 pulleys. can they be interchanged?
bigredOBS is offline   Reply With Quote
Old 10-17-2010, 09:32 PM   #2
grafton
Member#: 187936
07 WRB STi
all ej series engine have the same size crank pulley
grafton is offline   Reply With Quote
Old 10-17-2010, 09:33 PM   #3
bigredOBS
Member#: 260219
2000 Impreza OBS
Tan
thank you.
Do the EJ253/EJ251 and EJ257/EJ255 use the same size crank and rod bearings? ciper Built Motor Discussion 4 06-05-2009 07:01 AM
Do the 02-03 imprezas use the same bulbs as the 04 imprezas? SinhCredible Interior & Exterior Modification 2 02-23-2004 03:28 PM
Do the GC8 and GDA cars use the same Sti motor and tranny mounts? edkwon Transmission (AT/MT) & Driveline 2 05-24-2002 02:10 PM
Do the GC8 and GDA cars use the same Sti motor and tranny mounts? edkwon Normally Aspirated Powertrain 0 05-23-2002 12:21 PM
('93-'01) Do the 2002 RS and WRX use the same shifter? driver Impreza Forum 0 06-03-2001 09:59 PM
