Welcome to the North American Subaru Impreza Owners Club Sunday March 29, 2015
Old 09-06-2010, 06:17 PM   #1
greyghost
Member#: 145305
2004 wrx
Default EJ20tt from 95 legacy same long block as 04 wrx?
I have a 2004 wrx and have acess to a ej20tt from a legacy. If i were to strip the ej20tt down to a long block will all my 04 "intake and electronics" bolt up. i guess a more straight forward question is are the long blocks the same?
greyghost is offline   Reply With Quote
Old 09-06-2010, 08:02 PM   #2
SteveTC
Member#: 118552
2010 JuSTI
I have a 96 legacy EJ20R which is a twin turbo in a race car. Recently, I upgraded to an ECU from an '02 WRX. Heads and intake are definitely different, as are the sensors, cam pickups, IAC, Throttle body, ect. Basic block has two less tapped holes to transmission. Basically nothing is an easy fit, so to answer your question plainly, no, nothing is the same, but it can be made to work by swapping heads and all sensors, intake, etc...
Steve
SteveTC is offline   Reply With Quote
Old 09-07-2010, 08:15 PM   #3
greyghost
Member#: 145305
2004 wrx
so the heads are completley different? I cannot use the long block?
Old 09-07-2010, 08:39 PM   #4
SteveTC
Member#: 118552
2010 JuSTI
Correct, they have different intake port configurations.
Old 09-07-2010, 09:59 PM   #5
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
Well, apart from the thrust bearing location, the block HALVES are going to be almost the same.
i_c_the_light is offline   Reply With Quote
Old 09-08-2010, 09:39 PM   #6
charliew
Member#: 125304
You can use the motor if you go to a aftermarket ecu. Also if it is a jdm motor it will have higher compression as jdm had better fuel and could run higher compression.
charliew is offline   Reply With Quote
Old 10-20-2010, 04:26 PM   #7
mattapo
Member#: 258028
2000 GTB Legacy
why do you want a twin turbo block? the heads are different, the oil feed and return and water feed and returd are done quite differently. you could block off the ones you dont need and use it in your wrx. compression is 8.5:1 on those off the top of my head.
problem is its the earley TT engine. they are really bad, the later ones from late 96 to mid 98 are not to bad
mattapo is offline   Reply With Quote
EJ20tt from 95 legacy same long block as 04 wrx? greyghost Pre-2002 Factory Turbo Powertrain 2 09-07-2010 01:40 AM
04 STi Long Block into 04 WRX Not Using AVCS Couple Questions.. STIStalker Subaru Conversions 11 06-28-2010 12:12 PM
What fuel rails and injectors for 04 STi long block in 04 WRX? STIStalker Built Motor Discussion 6 01-31-2010 12:15 PM
Is the 05 Legacy GT throwout bearing same as 04 Wrx? LiquidForce Transmission (AT/MT) & Driveline 1 11-04-2007 10:39 AM
Are 04 sti wheels the same as 04 wrx ? WRX82 Tire & Wheel 8 02-09-2006 11:22 AM
