Old 06-28-2002, 01:12 AM   #1
shortlid
Member#: 10297
2003 Legacy GT Sedan
Silver, 4EAT, 42k
Default Cali. emision heat shield rattle?
We have a '98 Legacy L wagon with EJ22 and auto, and Cali., emissions it has developed a heat sheild rattle at 2300 rpm. right under the trany but I can't pin point it exactly. No bolts on that particular shield what should I do to find and quiet it?? Is there a place they often rattle at??
shortlid is offline   Reply With Quote
Old 06-28-2002, 01:45 AM   #2
nuburu2
Member#: 2609
98 BK-GT White
'97 SVX Ebony Pearl
shortlid, I've read recently about people using sheet-metal screws, threaded between the shield and the exhaust at various points, by trial and error, to silence the rattles. Mine's getting annoyingly noisy too, and I'll also be looking to tighten up the shields soon. Depending on your location you may be able to just tighten up the fasteners, if they're not rusted solid, but from past experience I can say the harmonics seem to defeat most efforts!
Glenn O
nuburu2 is offline   Reply With Quote
Old 06-28-2002, 07:37 AM   #3
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
I finally removed ALL mine. It sounds good as new now.
HIHO is offline   Reply With Quote
Old 06-28-2002, 08:39 AM   #4
Cajual
Member#: 12900
1997 Legacy GT-Turbo
Quick Silver Metallic
I removed all of it too... my bolts were rusted solid, but i know a guy with a shop, so we just put it on the lift and torched the bolts and ripped it all off... much better now... it was really embarassing driving around with all that rattling.
Cajual is offline   Reply With Quote
Old 06-28-2002, 10:41 AM   #5
Subietonic
Member#: 12588
Four Count 'em
GF5,BDA,BD5, BP5
Default How many miles?
did you all have on your car(s) when the heat shield started to rattle? I too have a 99 L 2.2 with 39K but everything seems as tight as it was day one. Both 98 BD's 29K and 51K are tight too. Is this somehow specific to the auto versions or both? 5 spd will eventually get the full Brullen header back treatment so that's will then be a non-issue but was curious about your shield situations.
Br, Dale
Subietonic is offline   Reply With Quote
Old 06-28-2002, 10:36 PM   #6
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default Remove??
I can see how the screws would work but REMOVING THE SHIELDS!! wouldn't that develop HOT spots on the floor pan and melt paint and carpet!! How about starting fires the next time you park in a feild!!
Old 06-28-2002, 10:59 PM   #7
HIHO
Member#: 7624
BD5; family sedan
Default Re: Remove??
Heck, firefighters like to put out fires.
I haven't noticed any "hot spots". We are not the first to do it and I doubt the last.
Old 06-29-2002, 04:26 PM   #8
shortlid
Member#: 10297
Silver, 4EAT, 42k
Default OK, now what!!!
OK, I had my Mom rev. the engine to the RPM where the rattle is. I pin pointed the rattle to the front pipe cover around the front exhaust pipe off the (LH)/drivers side bank, as it is called in Haynes. In VT we bottomed on a rock and it scraped and dented the lower (LH) lower pipe cover so now it contacts the pipe running inside it and reverberates, there is suppose to be a air space to keep the pipe and covers separated. When I finally got the out side bolt off it resulted in it getting LOUDER!! The inside one is so rusted I can't get it of!! I tired a SS hose clamp with no luck. I was thinking about taking it off and leaving it off or replacing it. But on the '98 EJ22 with Calif. emissions the upper and lower front pipe covers are crimped together unlike the one in Haynes that just has clamps! I am thinking about shimming it with washers and putting a new bolt back in to see if it can increase the gap, but what should I do if that doesn't work start cutting it off with the Sawsall!! How would I thread screws in in my perdicament??
heat shield rattle jmmcguire Warranty Issues & SOA Problems 4 03-07-2003 09:48 PM
Turbo Heat Shield Rattling, don't know why, Can I go without? turbocharged Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 03-26-2002 08:54 AM
Muffler heat shield rattling like mad Keiho Car Audio, Video & Security 3 10-13-2000 06:06 PM
Heat Shield Rattle Stickee Technical Forum Archive 8 09-01-2000 12:22 AM
