Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 10-18-2010, 12:02 AM   #1
AW Sti
Member#: 202929
Default Are 04 cams different from 05-06??
I have a doubt because sometimes I see sets of cams selling for 04-07 STi (USDM AVCS) and in some others I see them listed as 05-07 or 05-06
Are 2004 USDM STi different from the 2005-2006 USDM STi??
Would I have any problems buying camshafts for a 04 if they're listed as 05-06?
AW Sti is offline   Reply With Quote
Old 10-18-2010, 09:07 AM   #2
Member#: 108089
2003 WRX
NF Performance
you'll be fine
Nuke209 is offline   Reply With Quote
Old 10-18-2010, 02:05 PM   #3
jason miller
Member#: 158313
2003 WRX
I believe that starting in '06 they made the cams hollow to reduce rotational weight. I read once that the valve lash should be set slightly differently depending on whether you have the 04-05 or '06 up cams, but I can't remember the specs. Otherwise, the lift/duration should be the same no matter what year.
jason miller is offline   Reply With Quote
What are "MECHANICAL, DRIVETRAIN" differences between 05 FXT and 06 WRX Wagon??? eSToI Loco Newbies & FAQs 0 11-07-2007 03:06 PM
Catback exhaust difference from 05 to 06? mdungelman Normally Aspirated Powertrain 15 03-26-2007 07:01 AM
06 wrx difference from 05 Suberman Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 04-13-2006 09:17 AM
06 Wagon tail lights, different from 05? styng88 Impreza Forum 4 09-16-2005 03:10 PM
