Old 10-18-2010, 12:32 AM   #1
blckout7
Member#: 189845
Default Phenolic Spacers + cam question
Hey guys I've been reading about phenolic spacers and have gotten mixed results...apparently it's confirmed that they lower intake temps, but by blocking heat into the intake manifold isn't that heat getting transferred back to the engine making it hotter? Hotter engine giving out extra heat isn't that in turn going to make the intake hotter through convection? Just asking not sure if stupid question or not.
Are they easy to install, and where can I get them and anything I should be made aware of like fitment for a 06 2.5i?
I haven't done much research on cams but my friend was saying something along the lines that when cams are installed it allows for higher rpms which is fine in a manual car because you can shift at desired rpm, but he's not sure how they would work in an automatic....?
How much do they go for with installation (estimated)? I like experimenting with the car but I heard this is rather hard for someone not to technical....
blckout7 is offline   Reply With Quote
Old 10-18-2010, 12:37 AM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
I'll answer your first question...
The engine is already hotter than the intake and does not rely upon the intake for a source of cooling. The heat of the engine will not be affected by the intake manifold in any direct way. The intake manifold will not be as hot and therefore cooler, denser air will exist in the intake manifold and then pass into the engine where it can allow the fuel to be burned more efficiently due to the higher oxygen content.
PhilSine is offline   Reply With Quote
Old 10-18-2010, 12:40 AM   #3
blckout7
Member#: 189845
Thank you I was unsure and thinking of all possibilities lol
Old 10-18-2010, 09:01 AM   #4
renyo
Member#: 93577
98 Impreza
1st Question: Yes, your thinking is correct. The engine will still heat up everything around it (and inside it -- the coolant). Conduction, however, transfers heat better than the other methods. The phenolic spacers provide a barrier against heat transfer due to conduction. Because of this the engine has a MUCH harder time heating up the intake manifold. Also, convection doesn't really work that well in this situation since, for the most part, the (intake) air is flowing from the manifold into the engine.
2nd Question: Cams don't specifically allow for higher RPMS. They change the valve opening and closing profiles (when they're open, how long they stay open, how long overlap is, etc..). If you rev higher, you might want to change your cams to take advantage of different dynamics that occur in the upper engine speeds, but it's not required. You can also get a set of cams that are cut to target a lower rev range too.
Now for the automatic part. You can shift an automatic. You can shift it by either manually moving the stick, or by using the accelerator. You can also redline an automatic. Barring the TCU possibly wondering wth is going on with the engine speed, you should still be able to use an automatic normally with a higher rev limit.
renyo is offline   Reply With Quote
Old 10-18-2010, 09:10 AM   #5
blckout7
Member#: 189845
Interesting about the cams I think I'm definitely going to do the spacers just hope it's not to hard, the cams I'm iffy about I don't necessarily like high rpms I would rather a lower rpm cam but that with installation probably very costly.
Old 10-18-2010, 09:45 AM   #6
blckout7
Member#: 189845
p.s anyone have any experience with the intake manifold porting from grimmspeed? any good?
Old 10-18-2010, 10:58 AM   #7
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
If you watch their time lapse videos, they do a gorgeous job. Is it worth it for the buck? You can probably choose better mods unless you're going all out. Of course, you could grab a die grinder, Dremel, or drill and do it yourself for a lot cheaper. You have to remember that the air in the manifold is traveling slowest near the walls, so unless they're creating some vicious eddies, it doesn't need to shine! I port matched an SVX manifold, and it wasn't too crafty.
If you care about autocross rules: Porting is allowed up to an inch from the manifold and head interface in Street Prepared, and is unrestricted in Street Mod and Prepared.
LetItSnow is offline   Reply With Quote
Old 10-18-2010, 11:58 PM   #8
blckout7
Member#: 189845
Spacers look hard to install lol or very time consuming
Old 10-19-2010, 12:23 AM   #9
renyo
Member#: 93577
98 Impreza
Since I do, did you mean Street Touring with the first one?
Old 10-19-2010, 04:10 AM   #10
shum_87
Member#: 129898
2001 Impreza
the spacers didn't take that much of my time when I was installing them. it did take me a good hour or so, but I took my time. the only problem I really had was taking off the old gasket.
it may be easier to remove the intake manifold, but I left it in, and had to wiggle my big hands through everything to get the spacers and gaskets aligned. all in all, it wasn't too difficult to do it.
I haven't noticed that great of a difference in the temps of the intake manifold, but I'm very sure this mod has given me better mileage - no joke, I gained about 75+ kms from adding this and borla headers.
shum_87 is offline   Reply With Quote
Old 10-19-2010, 07:57 AM   #11
EdHilario
Member#: 137398
2004 Impreza 2.5RS
Did you do the headers at the same time as the IM spacers or separately?
EdHilario is offline   Reply With Quote
Old 10-19-2010, 09:05 AM   #12
blckout7
Member#: 189845
So what did you do just loosen the bolts lift the manifold up and slide them in?
Old 10-19-2010, 09:45 AM   #13
LetItSnow
Member#: 38222
'10 &'12 Foresters
The spacers aren't ridiculously hard to install. It is easier to do it with the manifold off, which is a good opportunity to do any port matching you want, surface treatments (grind off casting flash or unused bosses and tabs, or bust out a can of VHT Red Wrinkle), replace any older and potentially brittle hoses under the manifold and to clean out any oil that's accumulated inside it.
Remember, it's all aluminum in there. DON'T OVERTORQUE! IIRC the rating is 17-19 ft-lbs - not much! A little never-sieze probably wouldn't hurt, either.
FWIW, on the EG33, the manifold on spacers will collide with the AC line coming off the compressor and needs a notch in a rib, and the EGR line needs to be extended. Be prepared for stuff like this that may apply to the EJ.
As for autocross, per the 2010 SCCA SOLO rules:
STOCK: 13.10.D disallows port matching altogether.
STREET TOURING: 14.10.C allows intake modification up to, but not including, the throttle body. (Mostly your CAI, SRI, etc.)
STREET PREPARED: 15.10.U allows intake and exhaust ports and manifold openings to be matched, but only within one inch of the port/manifold interface.
STREET MODIFIED: 16.10.D.2 lets you have practically unrestricted fun.
This is where a measure of sportsmanship comes in. If your local region's ST competitors think that port matching on (assumed) a streetworthy, otherwise ST NA '98 Impreza will let you walk them, then they're really stretching. I don't advocate rule violation, but I won't be the first to say that the classing and PAX is not a perfect system. Just be sensible.
Old 10-19-2010, 05:28 PM   #14
renyo
Member#: 93577
98 Impreza
Yeah, that sounds like what I remember reading. Unfortunately, I haven't the money to do the port matching or the autocrossing at the moment, but thanks for the info regardless. I do intend to do much more in the future though.
For the record, I was asking because of this...
Thanks
Old 10-19-2010, 06:30 PM   #15
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
From our experience with our customers our phenolic spacers have gotten rave reviews. Many companies create spacers that are made out of basically cutting board material, the white ones, and these deform and cause leaks over time. We use phenolic material that is extremely hard and durable and kills heat transfer. We have had multiple customers say that with the 8mm phenolics and a coated/ported intake manifold and TGV deletes they could race their car hard like auto-x and stop and rest their hand on their intake manifold and it was not hot. Lower intake charge temps, I think so!
Will
GrimmSpeed is offline   Reply With Quote
FS : FS: ID 1000cc injectors, JDM TGV deletes, KStech phenolic spacers, AP Inlet The Deliverator Engine/Power/Exhaust 6 10-18-2010 09:59 PM
Phenolic Spacer Question boosted_scoob02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 10-16-2010 09:08 PM
Phenolic spacers question Ryan314 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 27 11-01-2009 07:23 AM
Phenolic spacer or hondata gasket questions jharl Normally Aspirated Powertrain 6 02-25-2005 04:34 PM
more phenolic spacer questions. Jejunum Normally Aspirated Powertrain 11 08-19-2004 07:50 PM
