Old 10-18-2010, 09:10 AM   #1
Subey03
Member#: 159909
2004 STI on AIR
Default o5 wrx valve cover gasket ... give me ur opnion
05 wrx 75k i recently replaced the valve cover due to it was leaking pretty bad...any ways after install 2 weeks later i smell oil and look sher enough the gasket is leaking again......i did everything u should do i cleaned both mating surfaces....got the old sealant off the front part of the gasket...and put a new bead on the area shown in the 2.0l manual........
so due you think while tightening the cover some oil could of got on the gasket " impregnated it" and after some driving heating cooling expanding of the gasket and metal.....the gasket just started to weep again...?
or could it be the 2 half moon hard plastic pieces on the side of the block..." cylinder head plugs"
any help would be appreciated...im gonna order a new gasket and the cylinder plugs and try and replace them one more time....
or im gonna have to bite the bullet and the dealership said they would have to pull the motor to do the cylinder head plugs
thx again...anything would help me out
also what is a good sealant to use...i have heard honda bond......and any three bond gasket sealant....?
Subey03 is offline   Reply With Quote
Old 10-18-2010, 09:50 AM   #2
AliBenn
Member#: 487
1998 /2005 STunIcorn
Acadia Green RS-T
honda bond is what i used last time
probally the half moon plugs are your culprit
AliBenn is offline   Reply With Quote
Old 10-18-2010, 10:14 AM   #3
lavid2002
Member#: 226864
I used the ultra grey liquid gasket.
Even though you are just supposed to use the rubber gasket on the valve covers with a dab on the corners I used it all along the whole gasket so I dont have problems like this :P
Dont go to the stealership, if its only coming from the head it can only be the valve cover bolt seals, the moon shaped pieces, or the valve gasket. Get some sealant and dig in when you have some time.
lavid2002 is offline   Reply With Quote
Old 10-18-2010, 12:01 PM   #4
Subey03
Member#: 159909
2004 STI on AIR
so does this sound right
i got new gasket new half moon hard plugs and
so step
1 remove clean all mating surfaces remove old hard half moon plugs
re sealant new plugs 360 all the way around insert to head...
2 new gasket tighten all hard ware
3 bead of honda bond all the way around bottom part of valve cover and head...so no leaks and will protect against dp heat
let sealants cure for 24 hour
then start up drive make sher no leaks?
sounds good?
also should i just use honda bond on the whole gasket a small bead all around......or would that not be a good idea?
p.s. those half moon hard things aka cylinder plugs can be removed w the engine in right?
o5 wrx valve cover seal help Subey03 Service & Maintenance 3 09-24-2010 07:01 PM
brand new valve cover gaskets/valve cover bolt grommets ('92 legacy L) shoodoggy Legacy Specific Parts 1 01-19-2010 01:13 AM
where to find 94 wrx valve cover gaskets!?!? czo79 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-28-2003 10:25 PM
2 things here. cooling fans/ valve cover gaskets solarsvx South East Region Forum 1 01-21-2003 02:27 PM
valve cover gasket replacment biggreen96 Service & Maintenance 0 02-11-2002 08:50 PM
