Old 10-18-2010, 12:23 PM   #1
slider95
Member#: 231148
Default Major squealing coming from timing belt area
95 brighton wagon with 2.2
When it's not squealing it sounds like a dry bearing running.
Goes with engine RPM'S.
Does the water pump have a weep hole?
Car drives but has a jerk to it like a dead miss every now and then.
Think I have a bearing seizing up ?
I'm new with Roo's
slider95 is offline   Reply With Quote
Old 10-18-2010, 12:31 PM   #2
grafton
Member#: 187936
07 WRB STi
might be a timing belt idler
i believe the water pump does have a weep hole
dunno about the drivability issue
grafton is offline   Reply With Quote
Old 10-18-2010, 12:32 PM   #3
RaineMan
Member#: 256727
2007 2.5I Wagon
Has the timing belt been serviced? If not I'd say it is time... might as well do the water pump while you are in there.
RaineMan is offline   Reply With Quote
Old 10-18-2010, 12:57 PM   #4
Storm
Member#: 5218
96L Most Over-
Developed Beater
My money says the water pump has seized. Especially if the car doesn't have heat right now.
Don't run the motor until you pull the covers off and look. This can easily end up with a broken timing belt and bent valves......been there, done that!
Jay
Old 10-18-2010, 01:47 PM   #5
slider95
Member#: 231148
Don't know if it's been serviced, 0nly had the car for a year, put about 10,000 miles on it.
It has 185,000 on it now.
Looks like the timing belt says Made in the UK on it.
I just took the end cover's off.
Belt is cracked pretty good but it's dry, no oil or anti freeze.
Can anybody reccommend a timing belt kit for this.
Yes, I will replace it all while I'm there.
Thanks Slider
Old 10-18-2010, 02:00 PM   #6
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Ebay is your best and cheapest bet. There are company's on there who have full kits with water pumps for around $125
...search 2.2 subaru timing kit in ebay motors
dangerousatom is offline   Reply With Quote
Old 10-18-2010, 04:02 PM   #7
slider95
Member#: 231148
WOW ebay is the cheapest.
Thank You very much, Slider
Old 10-19-2010, 12:02 PM   #8
Subikid90
Member#: 239233
1998 LGT
Dont go cheap on a timing belt. Use a brand like gates, or OEM. Your 2.2 is non-interference so if the belt breaks you wont hurt anything internally. I am not saying you can wait, if the belt is cracked replace it now. Check all of your idlers, water pump and tensioner. Replace anything that is not working to spec. A haynes manual is nice to have when doing this.
Subikid90 is offline   Reply With Quote
Old 10-19-2010, 01:34 PM   #9
dangerousatom
Member#: 70710
Alot of times you can find or figure out who and where the company is off the ebay listing info and get a phone number. I did this for my Legacy SS build......I got a kit with extra stuff or with out stuff. Like the belt, I ordered a kit with H2O pump and Oil pump but without a belt. Then got a good warranted belt at Auto-zone.
Old 10-19-2010, 03:32 PM   #10
iluvdrt
Member#: 46248
82 Brat
Tan
FYI the t-belts at NAPA are manufactured by Gates, and they are a lot cheaper.
iluvdrt is offline   Reply With Quote
Old 10-19-2010, 06:31 PM   #11
cmiovino
Member#: 134005
2004 WRX Premium
EJ22s or those year are non-interference. If it breaks or the idler breaks, it will leave you stranded, but not bend valves.
If it's cracked and looks old, I'd change it and do it yourself since you can't mess it up.
Old 10-19-2010, 09:40 PM   #12
recnelis
Member#: 92778
2000 Impreza 2.5RS
It could also be your alternator going. Take the belts off to help isolate which piece is causing the noise.
recnelis is offline   Reply With Quote
Old 10-22-2010, 10:17 AM   #13
Bluefoton
Member#: 141373
2008 2.5i-hatch -
now with a HID retrofit
If you have the $ and plan on keeping the car for a few tens of thousands of miles, change EVERY belt and EVERY pulley and the tensionner ASAP. Hurts your wallet, but all the squeaks disappear and you'll be safe for a while (short of water pump and alternator)
Old 10-22-2010, 10:46 AM   #14
Bluefoton
Member#: 141373
2008 2.5i-hatch -
double post!
Old 10-22-2010, 12:59 PM   #15
ibanez24_7
Member#: 192322
2002 Impreza TS
I am changing my timing belt tonight and everything under it. I just dropped $700 in OEM parts. Thats the timing belt, water pump, all idlers and tensioner, thermostat and gaskets. My car is paid off so Id rather pay that than a $500 monthly payment for a new car. Id go oem with the timing belt and water pump. Your not paying that much more and do you want a part that might work or is garuanteed to work with your car? The squeal is probably a bad bearing either in the water pump or an idler pulley. Id get it fixed asap. Jsut as a reference this is what my local dealer quoted me for.
Timing belt—107.94
Tensioner—179.94
A/C belt---23.93
Alternator belt—22.43
Water pump—119.94
Water pump gasket—5.95
Thermostat—22.37
Thermostat gasket—5.95
Cam seals—12.03ea (2 req.)
ibanez24_7 is offline   Reply With Quote
Old 10-27-2010, 10:05 PM   #16
slider95
Member#: 231148
I found out what the noise was.
The Cog Idler Pulley was TOASTED Blue, with hardly any bearings left.
Timing belt was missing about 12 teeth and severly cracked.
Had to drill out tensioner pulley bolt hole to 7/16 and retap it
Somebody replaced the belt before and really screwed up the threads.
Replaced everything under the covers except tensioner, for $187 and change off of ebay.
Fairly simple job and now I have heat at idle.
Thanks everybody, Slider
Old 10-27-2010, 11:53 PM   #17
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
You kept a tensioner with unknown age and mileage on a car with 185k? Braver man than I.
BAN SUVS is offline   Reply With Quote
Old 10-30-2010, 10:30 AM   #18
slider95
Member#: 231148
Not sure if brave is the right word.
Cheap maybe, the tensioner tested good so I went with it.
Old 10-30-2010, 11:53 AM   #19
Bluefoton
Member#: 141373
2008 2.5i-hatch -
They still tend to fail, and when they do, buh-bye to the engine. Buy yourself peace of mind and change it.....
Squeal from V-belt area--Update with coolant probs huzidada Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 06-29-2010 02:13 PM
Squealing coming from Drivers Side Front Tire berylthemessiah Brakes, Steering & Suspension 0 03-10-2010 03:19 PM
Squealing coming from passenger side front.... -Kevlar- Newbies & FAQs 14 05-22-2008 05:42 PM
Squeal Coming from driver's side front wheel well roksax Brakes, Steering & Suspension 5 03-15-2007 12:43 PM
leak from timing belt cover area grizz3000 Service & Maintenance 17 12-27-2006 09:53 AM
