View Poll Results: What would you do?
Go hybrid 7 77.78%
Drop in pistons and call it a day 2 22.22%
Voters: 9. You may not vote on this poll
Old 10-18-2010, 12:43 PM   #1
Tut4u2
Member#: 40424
05 STi
Default Need hybrid or not advice
After reading through endless threads I'm still no closer to making a decision as to what I should do. My tensioner broke this weekend and my valves high-fived my pistons.
I have already bought new S20 heads with Cower S2 cams, valves, retainers, springs, etc.
I don't know whether I should drop pistons into my current 2.0L (Wiseco pistons that will bump my compression to 8.4) or use an 2.5L block that I have access to. The 2.5L is an EJ251 with STi pistons and rods, and ACL race bearings. It has zero miles on it and its been spec'ed so everything is good with it.
If I re-use my block I would just drop in the pistons and go from there. My block has ~80K on it. I don't feel like taking it apart installing bearings.
What I use my car for: its my DD, I auto-x a couple of times a year, but I do more track days. Car will have a 16G initially, but I might do an 18G later on; turbo will not be larger than an 18G. I plan on revving to 7.5k.
What would you do?
Tut4u2 is offline   Reply With Quote
Old 10-18-2010, 01:41 PM   #2
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
I'd go hybrid.
wrxwhat is offline   Reply With Quote
Old 10-18-2010, 02:59 PM   #3
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
Originally Posted by wrxwhat View Post
I'd go hybrid.
polskaboys is offline   Reply With Quote
Old 10-18-2010, 06:45 PM   #4
25rsti
Member#: 166324
go hybrid with forged pistons
Old 10-18-2010, 06:55 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I'd do the hybrid too. My old hybrid w/ 8cm^2 18G was too fun. Great lowdown torque on demand
Old 10-18-2010, 07:04 PM   #6
Maxwell Power
Member#: 190729
get an EJ257 block and send the heads to EQ Tuning to have the chambers CNC'd to match the STi chambers. That is the proper way to do a hybrid. More power, more reliability
Any other way is half ass and a ticking time bomb.
Maxwell Power is offline   Reply With Quote
Old 10-18-2010, 07:59 PM   #7
sidewayz
Member#: 5810
2001 S366 2.5RS
Well ain't that a bunch of horse ****. There are plenty running around and are just fine. One that we built is over 70k on it an still running fine. Mine has over 20k and runs great
sidewayz is offline   Reply With Quote
Old 10-18-2010, 08:02 PM   #8
Tut4u2
Member#: 40424
05 STi
Not planning on sending the heads off for any work; I would drop in pistons before I got the heads re-machined.
What kind of power did you put down? Do you have a graph of your curve?
Old 10-18-2010, 08:05 PM   #9
Maxwell Power
Member#: 190729
no.
just because you did it that way doesn't mean it's the best way. There are a mess of issues and limitations by just dropping a big bore on a small combustion chamber. If you don't know or understand it, don't waste time arguing it.
The success rate of hybrids is lower than any other build.
Old 10-18-2010, 08:08 PM   #10
Maxwell Power
Member#: 190729
suit yourself. half ass is half ass.
Hell, I'm not even telling you to send them to MY shop to get work done. I'm just giving you sound advice. I have nothing to gain by you doing it either way.
There is the right way, the half ass way and the wrong way.
400 dollars for some machine work is the best hp/$ that you'll spend. It deshrouds the valves, raises the hp potential of the heads dramatically, lowers the compression ratio and increases reliability. Why wouldn't someone do it? There are ZERO negatives.
Old 10-18-2010, 08:36 PM   #11
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
I agree with Dom 100%, if youdont want to spend the extra money on the cc work, then sell the heads and buy a set of 2.5 heads.
rexworx is offline   Reply With Quote
Old 10-18-2010, 08:39 PM   #12
kellygnsd
Member#: 32669
LINK G4 hybrid STi
AYour cnc work is only $400 now. I thought it was a grand?
Old 10-18-2010, 08:46 PM   #13
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
So you do it for 400? Cus I was quoted this (cheapest I found so far)
It's $175 extra for me to chamber reshape during a valve job.
So:
Valve Job $350
Chamber Deshroud $175
Total $525 for the pair.
You will still need to shim your valves afterwards.
I offer valve adjustment during a valve job for an additional $180 but you do not have to buy any shims.
So plug and play would be $705
Thanks
Joe
My question really is, how much will it cost in the end (before shipping), to have my heads done so I can just "bolt on"
you can PM me instead if you'd like
Jubert39 is offline   Reply With Quote
Old 10-19-2010, 12:15 PM   #14
erikos
Member#: 148432
2006 TR VF39, alky
ID1000's
no.
just because you did it that way doesn't mean it's the best way. If you don't know or understand it, don't waste time arguing it.
erikos is offline   Reply With Quote
Old 10-19-2010, 12:32 PM   #15
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
Im doing a hybrid right now an sent my heads to EQ tuning cause i want to do the build the right way. why put soo much money into something that wont last you over sooo many miles. be on the safe side.
Old 10-19-2010, 02:15 PM   #16
Maxwell Power
Member#: 190729
CNC Porting was over a grand. EQ Tuning does the combustion chamber work.
So:
Valve Job $350
Thanks
Joe
You can do the chambers without doing a valve job of any sort as the chamber work doesn't affect the valve seats or any valve geometry. If you need a valve job anyway then obviously do them all at the same time.
EQ Tuning does the chamber work. I thought it was 400 but it could be 500. Regardless, it's an additional 400-500 (+shipping) to whatever else you need to do.
I can assure you, even if it cost 1000 for the chamber work, it's worth every penny. The increase in power output AND reliability is substantial.
Old 10-19-2010, 03:07 PM   #17
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
so in the previous post, you said your shop does it. If so, do you charge the $400? If so I might be an interested customer. I DO realize it DOES help, but bottom line is I have little money, and still have to buy all the other parts, aka, water pump, gaskets, t-belt, tstat, etc... all those little bastards add up lol.
Old 10-19-2010, 03:53 PM   #18
Maxwell Power
Member#: 190729
I think you are mistaken.
I was saying that I'm not trying to sell you anything because I send mine to EQ Tuning too.
Old 10-19-2010, 07:11 PM   #19
sidewayz
Member#: 5810
2001 S366 2.5RS
no.
I understand there are issues and limitations but I would not consider it half assed.
I see more failures off half assed "regular" builds vs. Hybrids
But agree to disagree. It's the op's choice as to what to do.
Remember I never said not to cnc the heads, I also never said not doing it was stupid. People have been doing it this way for a long long time
Old 10-20-2010, 08:45 PM   #20
lcjarrett
Member#: 133814
2008 AW STI
Go Hybrid!!! I did!!!
lcjarrett is offline   Reply With Quote
Old 10-20-2010, 09:36 PM   #21
Tut4u2
Member#: 40424
05 STi
I decided to go the hybrid route..will post up the results and impressions when I dyno the car.
Old 10-21-2010, 03:05 AM   #22
polskaboys
Member#: 221147
2011 STI LIMITED
WHITE
To hybrid, or not? beef Built Motor Discussion 5 08-11-2010 11:06 AM
needed tune or not? RBrady29 Newbies & FAQs 6 08-08-2010 12:52 PM
Need advice on weather or not to install my Whiteline sway bar or wait. last lemming alive Brakes, Steering & Suspension 5 05-15-2010 09:13 AM
Input wanted on 05' WRX. To Hybrid or not? kpotzmann General Community 7 11-16-2009 09:15 PM
Need Advice.. save for a STi TMIC or not? SoLiDbReAkZ Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 01-17-2003 11:37 PM
