Welcome to the North American Subaru Impreza Owners Club Tuesday February 9, 2016
Old 10-18-2010, 10:26 PM   #1
GEE-OTTO
Member#: 201277
2009 Legacy GT
Default p0420 only with more than 1/4 tank. HELP
I have a odd issue with my 2008 LEgacy 2.5i. As of late (last 1000 miles) it throws the P0420 CEL when I fill up and stay on until i get down to 1/4 tank then it goes off. As soon as I fill up the light comes back one. Now besides a bad rear o2 and not other codes to suggest anything else, what do you think would cause this? I am going to order a new rear o2 from Rock Auto and patch it in and I hope that helps b/c no other codes are present to point to another cause of the issue.
Any help would be great or suggestions
GEE-OTTO is online now   Reply With Quote
Old 10-19-2010, 12:35 AM   #2
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Wiring problems. Go talk to the dealership.
Old 10-19-2010, 03:29 AM   #3
chRS
Member#: 228073
it should be covered under factory warranty since p0420 is an emission related problem. bring it to the dealer.
chRS is offline   Reply With Quote
Old 10-19-2010, 10:08 AM   #4
GEE-OTTO
Member#: 201277
2009 Legacy GT
Well I would but my car is out of warranty ( yes it's an 08 w/ 67.5k miles) so if the stealer is going to charge me for a new sensor I'd rather do it myself
Old 10-20-2010, 09:26 AM   #5
GEE-OTTO
Member#: 201277
2009 Legacy GT
The light comes on and goes off under a quarter tank and over three quarters of a tank. This makes perfect sense because the the ECU only monitors Catalytic converter effciency or defficiency between 3/4 and 1/4 tank of fuel. This expalins why I get light when full or low!!
My converter is actually bad but the ECU doesn't give a damn but only 1/2 the time (3/4-1/4 = 1/2)
Old 10-20-2010, 12:46 PM   #6
motohippy
Member#: 225882
2000 OBS
'88 BMW K75S
I may be wrong here, but it looks like if your converter goes bad you've got federally mandated warranty on it til 80K.
http://www.epa.gov/oms/consumer/warr95fs.txt
motohippy is offline   Reply With Quote
Old 10-20-2010, 01:08 PM   #7
RaineMan
Member#: 256727
2007 2.5I Wagon
Call the dealer and check on warranty status. In 2008 some Subarus were certified as PZEV, which carries an extended warranty on emissions components in certain states.
RaineMan is offline   Reply With Quote
Old 10-20-2010, 04:52 PM   #8
GEE-OTTO
Member#: 201277
2009 Legacy GT
Hey so I went to the dealer and as luck would have it the P0420 light went off and more oddly they said it wasn't stored in the ecu however I did notice my ecu was reset as it stumbles at idle hard fir the first few miles after a reset. Could the tech have rest the ecu then tried to read the trouble codes ? Don't they stay in memoryafter the light goes off and a reset? ( purge all built up electricity ) they claim there is no code and they will need to read the code before they honor a warranty repair or I have to pay $$$ for the diagnostic charge
And the p0420 hasn't came back yet which is how I know they rest it bc I do the same thing and it takes about 2 weeks to showup again.
More FBKC when under 1/4 tank of gas? aberg12012 Engine Management & Tuning 5 05-11-2010 01:16 PM
Used '08 WRX only $1K more than Used '06 WRX? Why? snvin General Community 28 11-06-2008 04:05 PM
Nickquest, a list of all the otters with more than 10 warning points -=C=- Off-Topic 140 09-23-2005 08:02 PM
Acura is going to have AWD with more than Subaru! 2002WRXSTi Off-Topic 29 12-11-2004 12:44 AM
Car won't let me run more than 18.4 psi? rasheeb Engine Management & Tuning 15 11-09-2003 01:40 PM
