Old 10-18-2010, 03:42 PM   #1
CruizinLG
Member#: 70711
Default 2004 Legacy - Cigarette Lighter Adapter is 'kaput'.
I'm trying to help out my niece who owns a 2004 Legacy. She was using an air compressor to pump up her tire and it stopped working. I thought for sure it was just a blown fuse, but I checked it and it was okay. I even swapped it with another fuse with the same rating just to be sure, and the issue didn't change.
I read somewhere that there may be some sort of thermal fuse just behind the plug adapter itself, but I can't figure out how to access the back of the adapter to see what is going on back there. The only thing I was able to determine for sure with my DVM was that there was no power at the adapter itself. FYI - this is the adapter right in the front dash.
If anyone is familiar with gaining access to the back of the cigarette lighter / how to remove it, I'd appreciate it if you could enlighten me.
I want to be her favorite uncle!
CruizinLG is offline   Reply With Quote
Old 10-18-2010, 07:01 PM   #2
subie3429
Member#: 216668
00 Legacy
04 Yamaha r6
Pull out ashtray there should be 2 screw on the top side, take those out and then you should just be able to pull the trim peice out.
subie3429 is offline   Reply With Quote
Old 10-18-2010, 08:15 PM   #3
CruizinLG
Member#: 70711
Thanks - I'll take a look the next time she stops by with the car.
Old 10-20-2010, 12:49 AM   #4
Humbleninja
Member#: 208222
1992 Legacy SS
There is a type of fusable link of sorts on the back of some of these lighters but they arn't servicable, you'll need to replace the whole socket.
Humbleninja is offline   Reply With Quote
Old 10-30-2010, 10:26 AM   #5
CruizinLG
Member#: 70711
Well, maybe this car's dash is setup differently than Subie's. Attached are pics of the dash. I removed the ash tray and could only see 1 screw - about 6" back. I removed the screw and nothing happened - nothing loosened-up.
I would gladly purchase a new power point / adapter but I still wouldn't know how to remove the old one.
Any other thoughts?
Old 10-30-2010, 09:03 PM   #6
TRH_legacy2k
Member#: 66222
2000 Legacy
'68 Spitfire
The screws you need face "up" and you can barely see them in the picture. If you don't have a really stubby phillips head, I've used a phillips bit stuck in a 1/4" socket in a small socket wrench.
Also, (at least with the 5 speed) you have the pop off the wood trim around the shifter and you will find 2 more screws.
Make no mistake, this is a pain to do (and I've done it a number of times on my car).
TRH_legacy2k is offline   Reply With Quote
Old 10-30-2010, 09:41 PM   #7
CruizinLG
Member#: 70711
Thanks! I did notice those in the pictures I took and wondered if those might be the screws I needed to remove - thanks for confirming. Unfortunately, I don't have access to the car until she stops by again, so I will take another stab at it. I have an offset ratcheting screwdriver that will work perfectly for this application.
Appreciate the reply!
I'll wave the next time I pass exit 15 on my way to Lake George.
Old 11-07-2010, 07:18 AM   #8
CruizinLG
Member#: 70711
Bummer.....I wasn't able to budge the screws.
I don't know if there's another way to tackle this one, except perhaps just installing a new power point somewhere else. Has anyone run into this?
I may call the Subie dealer on Monday and ask them how much they charge to replace it, but I'm sure it won't be cheap.
Old 02-26-2011, 06:56 PM   #9
Mr Squiggles
Member#: 235039
2005 WRX
OB
well i don't know how much it will be in labor, but they quoted me $32.30 just for the socket. Compare that to around $6 everywhere else in the world. I have a feeling they may sell you the entire ashtray and trim piece. eitherway at least in my WRX you just pull up on the plastic trim around the gear shift and you can get to the back where you can then disconnect the power plug pigtail.
Mr Squiggles is offline   Reply With Quote
Trying to find Cigarette Lighter Adapter with LED Switches...HELP! P-Tein Interior & Exterior Modification 13 01-09-2009 03:27 AM
Is it possible to light a candle w/ your car's cigarette lighter? DrBuzzad Off-Topic 8 04-20-2005 09:35 AM
Keeping 12v cigarette lighter supply active when key is out? overdose Electrical & Lighting 3 11-21-2003 02:00 PM
Cigarette lighter cell phone charger adapter henryh Vancouver Impreza Club Forum -- VIC 8 12-31-2002 01:33 PM
