Old 10-18-2010, 08:27 PM   #1
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Unhappy Balancing pistons/ rods... slightly upset with machine shop
So after having my engine balanced I noticed the machine shop removed metal from one piston from right in the middle at its thinnest spot. Should I be worried by this?
340Duster is offline   Reply With Quote
Old 10-18-2010, 09:46 PM   #2
hot-j
Member#: 260982
God Yes!
hot-j is offline   Reply With Quote
Old 10-18-2010, 10:14 PM   #3
MartinSTi05
Member#: 145145
2006 wrx STi
That's honestly about the best place to remove material.
MartinSTi05 is offline   Reply With Quote
Old 10-19-2010, 12:17 AM   #4
Junior2JZ
Member#: 64908
10.8 [email protected] GR+
9.1/157mph 2015 STI
Man, I don't know about that. You don't want to take material from the area that is going to get the most pounding. Generally they take material off from the skirt insides.
Junior2JZ is offline   Reply With Quote
Old 10-19-2010, 01:39 AM   #5
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
Well, the only time that is going to fail, is if something is horrible wrong, and at that point it is something OTHER OTHER OTHER than the maching shop doing anything to that piston.
Subaru pistons fail at the edges, 99.9 of the time. I personall have cracked a piston in half but only after burning off a 1/4 of the top edge.
I would not worry at all. Seriously.
Old 10-19-2010, 09:25 AM   #6
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
normal..
if you also notice there are 2 other holes up near the wrist pin bridges.
removing material to get pistons within a weight tolerance of each other.
when balancing recipication assemblies the weights of pistons & rods
are within a grams of each other.
look at your crank pulley & flywheel
Old 10-19-2010, 03:12 PM   #7
MartinSTi05
Member#: 145145
2006 wrx STi
They drilled many holes specifically to keep the depth/loss of strength to a minimum. I would be worried if there was one hole drilled for the same weight removal;-)
Old 10-19-2010, 04:06 PM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I always take away from pin boss area, near the bottom, as it usually has excessive amounts of extra bulk and has little influence on weight side-to-side fo the pin.
IBleavethecrownalone
Old 10-19-2010, 04:57 PM   #9
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
I agree it's probably not a huge issue; just ranting because I feel there are better areas they could have removed material from.
Old 10-19-2010, 07:47 PM   #10
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
I'd be worried if they removed material from the piston tops...lol
But you should be fine with what they did.
mtcs is offline   Reply With Quote
Old 10-19-2010, 07:47 PM   #11
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
they try to do it in the center like that so as to take material off the center mass of the piston.Like they said above it is normal and doesn't weaken the piston really at all.
john 1badSTI is offline   Reply With Quote
dropped off pistons to the machine shop/ Pavoni8297 Built Motor Discussion 9 06-24-2010 01:40 PM
Need a machine shop recommendation for flywheel/pressure plate balancing AnorexicSTI Vancouver Impreza Club Forum -- VIC 2 06-21-2007 04:23 PM
sti block sohc heads... what pistons/rods to go with? rst4me Built Motor Discussion 9 01-06-2007 07:55 PM
So now I'm slightly upset.... jpmarotta New England Impreza Club Forum -- NESIC 24 07-07-2004 07:08 PM
Pistons,Rods,Balance Crank, Crank Bearings for turbo EJ25 3BadHabbits Normally Aspirated with bolt-on Forced Induction Powertrain 14 01-10-2004 04:04 PM
