Old 10-19-2010, 12:13 PM   #1
sidewayz
Member#: 5810
2001 S366 2.5RS
Default Wiseco ring end gap
Hey guys, first time using Wiseco pistons. The instructions say minimum gap should be .004 per inch of cylinder diameter. Sooooo if I do this correctly then 3.917 X .004= .015 right?
Im measuring .022 for the top ring WITHOUT any grinding. Im used to CP's not these suckers.. any help would be great!
Thanks
sidewayz is offline   Reply With Quote
Old 10-19-2010, 02:33 PM   #2
sidewayz
Member#: 5810
2001 S366 2.5RS
ok.. so I searched once I spelled Wiseco correctly haha.. I think Im good. still getting .022 and under without grinding...weird they make them so large
Old 10-19-2010, 09:49 PM   #3
13larry
Member#: 253388
Did the rings come with the pistons? Did you have the bores measured accurately? Are you within specification on piston to wall clearance. Something must be wrong.
13larry is offline   Reply With Quote
Old 10-20-2010, 12:15 AM   #4
sidewayz
Member#: 5810
2001 S366 2.5RS
Ring came with pistons. I'm measuring the bores tomorrow. I didn't stuff the pistons in just yet. Something doesn't feel right so I'm double checking everything again
DIY Piston Ring End Gap - No funny tools Bad Noodle Built Motor Discussion 43 05-06-2013 06:24 AM
Piston ring end gap advice afmardve Built Motor Discussion 22 10-15-2010 09:40 PM
ej20 piston end gap DausWRX Built Motor Discussion 2 01-07-2010 01:11 AM
CP Pistons End Gap Question Hayaboosted Built Motor Discussion 39 08-14-2009 12:50 AM
piston rings...end gap? Mawheaton Normally Aspirated Powertrain 1 02-17-2009 12:43 AM
Message Board Statistics All times are GMT -4. The time now is 08:21 AM.
