Vancouver Impreza Club
Go Back   NASIOC > NASIOC Chapters > Vancouver Impreza Club Forum -- VIC > VIC Vendor Classifieds
Old 10-19-2010, 03:36 PM   #1
dalesalignment&brake
Vendor Sales Rating: (47)
Member#: 173316
'13 BRZ
Default Discount pricing RCE, Whiteline, H&R, Hawk, DBA in stock
RCE Yellows('08+STI) are here!!!!
Following the release of our popular "Regular Guy" springs, Racecomp Engineering has produced a more aggressive lowering spring for the 08+ STI. These new springs lower the car approximately 15mm and include new replacement bumpstops to maintain as much travel as possible on the lowering sensitive GR Impreza chassis.
Spring rates are an aggressive 330 lbs/in front and 335 lbs/in rear. With a stance to match the performance, these springs utilize the knowledge RaceComp has gained from years of GR chassis set-up experience to maximize handling, retain ride comfort, and improve the look of your Impreza.
Racecomp Engineering’s goal was to help cure the crippling understeer that adds to lap times at the track and autocross course. Studying the design of the new GR suspension, a more aggressive performance spring has been produced that retains available bump travel, matches the OEM dampers, and works in conjunction with the new rear motion ratio. The result is a car that handles extremely well from corner entry to corner exit.
$389/set
And add a set of these for optimum control:
Racecomp Engineering GR Sway Bars
These front and rear 25mm hollow 2 position adjustable swaybars are a must have for your 2008 and later Impreza STI. Featuring carefully chosen swaybar rates and a tubular design, these swaybars weigh less than other solid bars with a similar stiffness.
Racecomp Engineering GR Sway bars for the 08+ STI. Rear bar will fit the 2008+ Impreza / Impreza WRX.
$420 set
or these
Whiteline swaybars
email for pricing
We also have:
RCE Tarmac Zero-'02-07 WRX and STI-in stock
RCE Tarmac 2 '05+STI and '08+STI-in stock
RCE GD('02-06 STI)-in stock
RCE Yellows and Regular Guy springs for '02-07 WRX/STI-in stock('02-03 WRX/Impreza need '04+ rear tophats)
RCE CF Kool Brake Kit-in stock
GTWorx camberplates-in stock
Finally after a two year hiatus Racecomp Engineering Wagon Springs will be back in stock(Sept20)-$389
Finally, an option exists for Subaru WRX Wagon owners with upgraded struts! Rather then having to choose between spring rates that are too soft, like most wagon specific springs, and a saggy rear end, like most sedan specific springs, Racecomp Engineering is proud to announce an OEM replacement spring for the Subaru WRX Wagon. Designed for use with standard STi inverted struts, Koni Inserts, Tokico D-Spec struts or Ohlins Fixed Perch Replacement struts, these springs are intended for both the daily driven street driver as well as the autocross and track day weekend warrior. Using similar spring rates as the extremely popular and successful RCE Yellow Springs, but having a wagon specific ride height, these are perfect for wagon owners not looking to compromise either ride height or spring rates.
Designed with direct feedback from wagon owners, these are THE solution for Impreza owners looking to prove what a properly set-up wagon with upgraded struts can really do!
We have Whiteline parts in stock for all make/model years of Subaru
Search here for your vehicles part#- http://www.whiteline.com.au/index.php
Strut top-camber/caster adj MOTOTSPORT KCA255M
Anti-lift/caster kit - lwr c/arm KCA359
Anti-lift/caster kit COMFORT KCA362
Anti-lift/caster kit RACE KCA359M
Brace-strut tower alloy adj KSB554
Brace-strut tower alloy adj KSB599
4 point Brace-Lower control arm KSB723
Brace-strut tower alloy adj KSB568
Subframe lock kit KSB750
Front of rear diff support lock KSB751
Gearbox positive shift kit W0584
Gearbox positive shift kit-MOTORSPORT W0584M
Heavy duty steer rack mounts KSR202
H/duty steer rack bushes KSR206
H/duty steer rack bushes KSR207
Roll-centre / bump-steer adjust kit KCA313
Camber adj kit-control arm upper bushes KCA326
Anti-lift/caster kit - lwr c/arm KCA334
Anti-lift/caster kit - lwr c/arm KCA334M Race
Strut top-camber/caster off-set KCA335
Sway bar link conv kit - extra h/d alloy KLC26
Sway bar link-bushed allow link KLC32
Swaybar link kit-spherical rod end KLC39
Swaybar link kit-spherical rod-end KLC066
Swaybar link kit-spherical rod end KLC047
Anti-roll link kit- h/duty adj ball link KLC139
Swaybar mount-h/duty kit KBR20-22
Swaybar mount-h/duty kit KBR20-24
Swaybar 22mm-h/duty Blade adjustable BSF12Z
Swaybar 22mm-h/duty Blade adjustable BSF30Z
Swaybar 22mm-heavy duty BSF30
Swaybar 24mm-X heavy duty Blade adjustab BSF30XZ
Swaybar 22mm-h/duty Blade adjustable BSF33Z
Swaybar 24mm-X h/duty Blade adjustable BSF33XZ
Swaybar 24mm-X heavy duty BSF33X
Swaybar 24mm-X h/duty Blade adjustable BSF36XZ
Swaybar 27mm-XX h/duty Blade adjustable BSF36XXZ
Swaybar 22mm-h/duty Blade adjustable BSF39Z
Swaybar 22mm-heavy duty BSF39
Swaybar 24mm-X heavy duty BSF39XZ
Swaybar 22mm-h/duty Blade adjustable BSR33Z
Swaybar 22mm-heavy duty BSR33
Swaybar 24mm-X h/duty Blade adjustable BSR33XZ
Swaybar 22mm-h/duty Blade adjustable BSR36Z
Swaybar 24mm-X h/duty Blade adjustable BSR36XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR37XZ
Swaybar 27mm-XX h/duty Blade adjustable BSR37XXZ
Swaybar 20mm-h/duty Blade adjustable BSR49Z
Swaybar 22mm-X heavy duty Blade adjustab BSR49XZ
Swaybar 24mm-X heavy duty Blade adjustab BSR49XXZ
If you do not see a part # listed pm/email for availability
Email for even better deals than listed
[email protected]
All DBA and Hawk part # in stock.
'04-10 STI
DTC 30
Front HB453W.585 Hawk Brake Pad- $174
Rear HB180W.560 Hawk Brake Pad- $148
HP+
Front HB453N.585 Hawk Brake Pad- $136
Rear HB180N.560 Hawk Brake Pad- $102
HPS
Front HB453F.585 Hawk Brake Pad- $119
Rear HB180F.560 Hawk Brake Pad- $80
'02-10 WRX, Legacy 2.5, Forester, Outback
HPS
Front HB352F.665 Hawk Brake Pad(early WRX)-$92.99
Rear HB434F.543 Hawk Brake Pad(early WRX)-$87.99
Front HB432F.661 Hawk Brake Pad(03-05, 08+ WRX)-$87.99
Rear HB452F.661 Hawk Brake Pad(03-05 WRX)-$79.99
Rear HB557F.545 Hawk Brake Pad('08+WRX)-$91.45
Front HB178F.564 Hawk Brake Pad(06-07, '08+WRX)-$87.99
Rear HB179F.630 Hawk Brake Pad(06-07 WRX)-$79.99
HP+
Front HB432N.661 Hawk Brake Pad(02-05 WRX)-$113
Rear HB452N.545 Hawk Brake Pad(02-05 WRX)-$107
Front HB178N.564 Hawk Brake Pad(06-07 WRX)-$113
Rear HB179N.630 Hawk Brake Pad(06-07 WRX)-$102
Legacy GT('05+)
HPS
Front HB533F.668 Hawk brake pad-$94.99
Rear HB434F.6543 Hawk Brake pad-$87.99
DBA Standard Slotted Rotors
'04-10 STI
654SLR-10 DBA Brake Rotor front (dual bolt pattern)-$280pr
655SLR-10 DBA Brake Rotor rear (dual bolt pattern)-$245pr
No standard slotted rear rotors for '08-10 STI
'02-10 WRX, Forester, Legacy, Outback
650SLR DBA Brake Rotors front-$240pr
644SLR DBA Brake Rotors rear -$210pr
653SLR DBA Brake Rotor rear ('06-07 WRX)-$230pr
DBA 4000 Slotted Rotors
'02-07 WRX, Forester, Legacy, Outback
4650SLR DBA 4000 Brake Rotors front-$290pr
4644SLR DBA 4000 Brake Rotors rear-$245pr
4653SLR DBA 4000 Brake Rotors rear('06-07 WRX 2-pot)-$270pr
'05+ STI DBA 4000 slotted
42654SLR DBA Brake Rotors front('05+STI)-$348pr
42655SLR DBA Brake Rotor rear('05-07 STI)-$310pr
4654 BDA Brake Rotors front('04 STI)-$348
4655 DBA Brake Rotors rear('04 STI)-$310pr
42656SLR DBA Brake rotors rear('08+STI)-$350pr
05+ Legacy GT Front DBA slotted
42650SL DBA Brake Rotor-$270pr
42650SR DBA Brake Rotor-$270pr
Stoptech Pads
'02-05 WRX front-$78
'02-05 WRX rear-$65
'06-07 WRX (4-pot)-$78
'06-07 WRX( 2-pot))rear-$65
'04-10 STI front-$92
'04-10 STI rear-$72.71
DBA 5000 and Performance Friction 2-piece Slotted Rotors are also available
Steel braided brake hoses(all models)-$115
ATE brake fluid(Blue and Clear)-$18
Ferodo 2500/3500 in stock for STI
I will match price with any Canadian vendor-just forward me a valid quote
__________________
[CENTER][CENTER][SIGPIC][/SIGPIC][/CENTER][B][I][COLOR="Red"]"We do pricing a little differently. Every price you see includes the shipping cost to our office(Surrey, BC), duties and exchange rate . This creates a built in cost savings, no hidden fees, and less hassles. The best part is we still have a price match guarantee!"[/COLOR][/I] [/B]
[COLOR=black]Service Center: 604 530 9160 [/COLOR] [COLOR=black]Email- [/COLOR]
[/CENTER]
dalesalignment&brake is offline   Reply With Quote
Old 10-22-2010, 12:05 PM   #2
Member#: 173316
'13 BRZ
__________________
[/CENTER]
Old 10-27-2010, 02:45 PM   #3
Member#: 173316
'13 BRZ
We have every(almost) Whiteline, DBA, Hawk, RCE part # in stock for Subaru.
Email me for discount pricing on everything and tech advice if needed.
[email protected]
__________________
[/CENTER]
Old 11-01-2010, 12:12 AM   #4
Member#: 173316
'13 BRZ
pm's answered.
Still have RCE springs in stock, all models.
__________________
[/CENTER]
Old 11-20-2010, 03:56 AM   #5
clarkbw
Member Sales Rating: (6)
Member#: 215473
2004 Stg 2 WRX
Thanks for the awesome service guys! Car is turning and stopping so much better. Ready for the big trip out to Denver for American turkey day. Also looking forward to getting the sway bars and end links installed when I get back.
Cheers,
- Bryan
clarkbw is offline   Reply With Quote
RCE, Whiteline, H&R, Hawk, DBA in stock and better pricing dalesalignment&brake VIC Vendor Classifieds 1 06-11-2009 12:05 PM
RCE, Whiteline, H&R & KW suspension in stock dalesalignment&brake VIC Vendor Classifieds 0 05-25-2009 11:30 AM
RCE front lowering camber plates in stock and ready to ship Fine Line Imports Engine/Power/Exhaust 0 04-08-2009 03:33 PM
Aquamist HFS-1 and HFS-5 Kits in Stock and great prices Dyno Flash Engine/Power/Exhaust 19 05-27-2008 01:53 PM
Crucial Sport Springs BLACK in stock! ...and better than ever...wait did I say black? Crucial Racing Suspension/Brakes/Handling 55 10-16-2007 08:13 PM
