Old 10-20-2010, 11:27 AM   #1
lilschwikes
Member#: 221329
04 impreza
pacific blue
Default what kinda power should i be making???
hey guys im just finishing up my engine build and im wondering what kinda power you think i will be able to produce with my mods that i have so heres the list:
1. bc 280 cams and springs
2. tgv deletes
3. 850cc injectors
4.perrin gt3076 rotated kit
5. full straight pipe exhuast
6. turboxs fmic
7. wiseco forged pistons and rods
8. turboxs utec
9. unequal header
10. soon to have aem meth kit
thats what ive done to the motor so im hoping 450+ but what have you guys found
lilschwikes is offline   Reply With Quote
Old 10-20-2010, 11:39 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
You really gon rev that motor out wid them cams?? You got a 2.5 on there?
Them cams dont go well with that size turbo if on a 2.5L. We done up a STi wid Crower 264* on that same turbo kit and turn up 500whp on DynoJet. On mustang it wudda done up 470whp had it not been spark blow out. We were runnin on E85 here on this setup.
FuJi K is offline   Reply With Quote
Old 10-20-2010, 11:45 AM   #3
vangstaboi86
Member#: 119945
2004 sti
java black pearl
Yup Fuji is correct on that. I think 450 will be a bit hard running pump gas.
vangstaboi86 is offline   Reply With Quote
Old 10-20-2010, 11:50 AM   #4
lilschwikes
Member#: 221329
04 impreza
pacific blue
yea its a 2.5 06 sti motor i wanna get a 35r or 40 but just running outta funds
Old 10-20-2010, 12:05 PM   #5
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
a few things.....
1. bc 280 cams and springs - 264* for GT3076
2. tgv deletes - plug them good
3. 850cc injectors - maybe look at the 1000cc top feed kit
4.perrin gt3076 rotated kit - save a little more foro the 35R if that's what you want
5. full straight pipe exhuast - as long as it's 3", that's all that matters
6. turboxs fmic - you gone need one with good end takes like APS's big FMIC if you go 35R
7. wiseco forged pistons and rods - You gon run 8.9:1??
8. turboxs utec - What you gon do that? reflashed ECU works well.
9. unequal header - Which ones? Better not be aluminum foil. needs to be thick pipes
10. soon to have aem meth kit - you aint got E85 there huh?
Old 10-20-2010, 12:13 PM   #6
Nuke209
Member#: 108089
2003 WRX
NF Performance
he's fine with 850 if staying on pump or pump&meth or race gas
turboxs' fmic should be fine
not everyone has e85
Nuke209 is offline   Reply With Quote
Old 10-20-2010, 12:22 PM   #7
lilschwikes
Member#: 221329
04 impreza
pacific blue
no no e85 by me and the tgvs are welded and ported smooth inside the only reason why i went 280's was cause i know the engine will be out again and the turbo i no is a tad small but its better then the 20g i had for it but eventually ill go bigger mabey even a 6262 turbo idk will see
Old 10-20-2010, 01:15 PM   #8
vangstaboi86
Member#: 119945
2004 sti
java black pearl
I'll still say those 280 cams would be a bit too big... Hmmm, go with some gsc 272 cams or kelford 272 cams and you should be fine with a 30r on or a bigger turbo on later down the road.
Old 10-20-2010, 06:14 PM   #9
juanmedina
Member#: 133146
07 FPgreen [email protected]
WRX VF39+E85 12.0, 121mph
Why are you guys keep saying that the cams are too big? what is it bad? He is going to make more power with bigger better cams than with small cams
Old 10-20-2010, 06:38 PM   #10
ASU
Member#: 164551
2006 Brotastic STi
Land of beer and laws
Agreed wit Juan here those cams are not big by any means, BC cams haves less lift and duration the Kelfords and Cosworth 272's
ASU is offline   Reply With Quote
Old 10-20-2010, 11:15 PM   #11
lilschwikes
Member#: 221329
04 impreza
pacific blue
yea i was gunna say every where ive read the cams are over rated and are actually less duration so i was right
Old 10-20-2010, 11:54 PM   #12
JF824
Member#: 71460
2007 WRX/STi
HTA Green 11.89 @ 119
With the cams and mods you have (if your not hurtin to get your car back for a DD) just save and wait another couple weeks and try and get an HTA 35R - especially if your not doing the work yourself. I built my motor with cams, pistons, rods, bearings, etc, and then put an HTA Green on the car. I wish I had just waited another couple weeks to save and put a 35R on the car. However, financially this was not an option for me as I needed my car back for daily transportation. Sounds like your in the same position as I was. But in the long run, if I was able to be without my car for another couple weeks (which I wasnt) I would have waited for a EWG'd HTA 35R. If you can do the bigger turbo go for it. Even if you can't though, its still gonna be a fun car with the 30R.
JF824 is offline   Reply With Quote
Old 10-21-2010, 12:02 AM   #13
lilschwikes
Member#: 221329
04 impreza
pacific blue
yea i know well ive been without the car for a like 2 months due to it being painted and the motor build but everything has been getting delayed over and over but yea well and now im getting tight on cash so i gotta cool it for a bit with the spending on it since my recent engagement now which if i didnt get engaged id have alot more done but ya well time to start growing up but im sure ill love to drive it and cannot wait for it to be done.
Old 10-21-2010, 04:10 AM   #14
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
cams go with powerband produced by turbo. So if the 35R is in mind later, then they are fine. I choose cams that will give me the widest powerband without losing too much down low and still hold power from dropping off up top.
Old 10-21-2010, 04:59 AM   #15
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
450+ can be done on pump and meth with that turbo.
alcoolaid is offline   Reply With Quote
Old 10-21-2010, 07:05 AM   #16
DBC_Templar
Member#: 261609
agreed, what gearbox will be used?, because a think the stock dont will handle very well with the new power...
DBC_Templar is offline   Reply With Quote
Old 10-21-2010, 11:37 AM   #17
lilschwikes
Member#: 221329
04 impreza
pacific blue
Well right now stock wrx 5 speed will be used cause I am gunna be doing some ppg gears in the spring
Old 10-21-2010, 11:52 AM   #18
juanmedina
Member#: 133146
This is true but by how much?? In EVOM they use 280 and 282 with stock turbos and they work perfect. Next time I have to open my engine, I will be installing something retarded big GSC 282 or something big from Kelford
Old 10-21-2010, 12:23 PM   #19
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
The EVO's are a 2.0L. That focuses the powerband more up there where the motor needs to rev so it can make power. They DO have a turbo that's quite large from factory. Damn inline engines....
Old 10-21-2010, 12:27 PM   #20
juanmedina
Member#: 133146
Thats is what I am asking: how much it will hurt, and I am sure no one really knows . Is probably a few rpms, while the gains could be substantial and they should be substantial
Old 10-21-2010, 02:03 PM   #21
lilschwikes
Member#: 221329
04 impreza
pacific blue
ok i do know one thing tho my roommate has a evo 8 thats fully build pretty much the exact same mods as i have and he is at 506whp with his 2.3 stroker motor but still same turbo same cams its just alot easier to make power out of the evos unfortunately
Old 10-21-2010, 02:03 PM   #22
PA-Outback2000
Member#: 161832
2000 Outback Limited
450HP is very doable with the right parts and proper tune. 35r is not really needed unless u really want that turbo. u don't need meth for that level.
PA-Outback2000 is offline   Reply With Quote
Old 10-21-2010, 02:19 PM   #23
lilschwikes
Member#: 221329
04 impreza
pacific blue
sweet so everyone is pretty much agreeing that i should be able to hit 425-450 no problem?
Old 10-21-2010, 03:18 PM   #24
vangstaboi86
Member#: 119945
2004 sti
java black pearl
look at the thread my buddy posted up on my car. hopefully that helps you get an idea of what your looking for.
http://forums.nasioc.com/forums/show...hlight=nuke209
Old 10-22-2010, 11:31 AM   #25
lilschwikes
Member#: 221329
04 impreza
pacific blue
Yea that's a nice setup but I wanna run 30-35 psi of boost not 26 so I should be able to reach the 435-450 mark
Low boost tune, what should i be making? AVOwagon Proven Power Bragging 15 07-10-2008 07:19 PM
how much power should i be planning on making?? sti.2005.blk Water/Methanol Injection, Nitrous & Intercooler Cooling 7 10-10-2007 05:54 AM
what kinda power increases should i get from this mattmx525 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-28-2007 10:41 PM
16g, What kind of power will i be making with this setup rexhio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 39 05-20-2007 02:56 AM
I've got all this, now what? -or- what kind of power should I be making? Porsche914boxer4 Proven Power Bragging 25 11-27-2003 10:17 PM
