Old 10-20-2010, 10:36 PM   #1
silverongold
Member#: 132599
02 impreza wrx
Default suggest my rev limit
I would like to know what you guys think would be a good rev limit for my motor.
specs:
ej20g, closed deck
weisco pistons stock compression
scat forget h beam rods
acl race bearings
crank? i think it is out of a 2.2 motor and has bigger oil journals
08 sti oil pump ( i believe it is a 11mm or some thing large)
bc 272 cams
shim less buckets
ferrea and bc valves. stock size
I may have forgotten some stuff. Please ask if some thing is un clear, and thank you in advance for the advice.
silverongold is offline   Reply With Quote
Old 10-21-2010, 04:01 AM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Probably to be safe keep it around 8000. Just make sure you have oil pressure.
alcoolaid is offline   Reply With Quote
Old 10-21-2010, 12:54 PM   #3
silverongold
Member#: 132599
02 impreza wrx
i have been at 7500 but figured it could do a bit more. what oil pressure should i be at?
not sure if this affects it but i do have a moroso oil pan and mishimoto oil cooler.
Old 10-21-2010, 03:44 PM   #4
mtcs
Member#: 180640
2000 Drag RSTi
8.96 @ 163
It's really up to your oil pump. The fact that you are using an 08 11mm pump is good.
P&L makes a ported 08 oil pump that can handle higher rpms. I have it on my build and plan to see 8500 all day long and maybe closer to9k once in a while. After the ported 11mm (larger than the 12mm JDM pump) the next step would be a drysump system. Sadly, not too many people have $3500 lying around though. lol
On your build with your pump, I'd stay close to 8300rpm max. 8000 on the safe side.
mtcs is offline   Reply With Quote
Old 10-21-2010, 04:22 PM   #5
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
good info im building my ver8 and i will be using the 11mm oil pump wanting to run 8000-8250
seanathanq83 is offline   Reply With Quote
Old 10-21-2010, 04:52 PM   #6
silverongold
Member#: 132599
02 impreza wrx
what should i watch for as far as oil pressure?
Old 10-21-2010, 05:29 PM   #7
phlegmon
Member#: 26223
2012 GTR - on E85
07 STi twinscroll XTR
10psi per 1000rpm. Example: 8,000 rpm = at least 80psi. 9000 rpm = at least 90psi. It's a rule of thumb but effective. Make sure your valve springs can handle it...
phlegmon is offline   Reply With Quote
Old 10-21-2010, 08:18 PM   #8
silverongold
Member#: 132599
02 impreza wrx
i forgot that i am runnig bc valve springs and titanium retainers.. . .? as far as handling the revs will that do a 8k rev limmit? with my turbo i do not think reving it much higher will even matter for now.
Old 10-21-2010, 08:29 PM   #9
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
I think we are putting the cart before the horse.
What turbo do you have?
CKxx is offline   Reply With Quote
Old 10-21-2010, 08:32 PM   #10
silverongold
Member#: 132599
02 impreza wrx
I have the tomei arms turbo on now.
Old 10-21-2010, 08:37 PM   #11
Speed
Member#: 67371
05 BUILT 2.4L STI
_____________
500-600 rpm after peak power.
Speed is offline   Reply With Quote
Old 10-21-2010, 08:40 PM   #12
silverongold
Member#: 132599
02 impreza wrx
prob next friday i will be tuning again and spending some time on the waste gate so maybe i can get it to hold power a little longer for a higher rev.
Old 10-21-2010, 08:47 PM   #13
silverongold
Member#: 132599
02 impreza wrx
ckxx, why cart before the horse? what are you thinking?
Old 10-21-2010, 10:11 PM   #14
TuTudtee
Member#: 213987
1996 Legacy
from my opinion, try to set your max. rpm as low as possible ... the gear ratio is also another factor not to be forgotten .... high revs beyond the power band is not much benefitial ..... just rev high enough to keep you in the power band when shifted.
TuTudtee is offline   Reply With Quote
Old 10-22-2010, 12:04 AM   #15
CKxx
Member#: 33458
93 RX7+09 Forester
I meant that without knowing your turbo or powerband than there was no point guessing what you should rev it to. I'm not familiar with that turbo. How many lbs/min does it flow?
Old 10-22-2010, 12:21 AM   #16
Garrek11
Member#: 227747
2006 STI (BW S363)
SGM
I suggest a oil pan baffel...
Garrek11 is offline   Reply With Quote
Old 10-22-2010, 12:56 AM   #17
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
If he is drag racing setting the rev limit to 500 above peak power is a really stupid suggestion.
With cams and a good flowing turbo it might still make power up to 7500-8000.
Anything higher would be beyond efficiency of stock location turbo tho.
project_skyline is offline   Reply With Quote
Old 10-22-2010, 12:54 PM   #18
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I wouldn't go any higher than 7500 unless you had your entire rotating assembly professionally balanced before dropping it in (pistons, rods, crank, flywheel, pressure plate).
If you did, then 8k should be fine.
How Should I Set My Rev Limiter? Huamaru Newbies & FAQs 15 07-15-2008 03:58 PM
How do I Raise My Rev Limiter? ImprezaRSX Engine Management & Tuning 5 11-28-2003 08:40 PM
My rev limiter is over 7000 stock ?!?! WS6toWRX Engine Management & Tuning 4 07-11-2003 04:49 PM
Way to remove my rev limiter? subyguy2 Engine Management & Tuning 1 11-07-2002 11:17 AM
What the heck happend to my rev limiter? HomerJay Normally Aspirated Powertrain 17 04-18-2002 10:53 PM
