Old 10-21-2010, 07:07 AM   #1
DBC_Templar
Member#: 261609
Default Impreza EJ18 with Ej22 Pistons, its possible?
Hello guys, i have with me one set of EJ22 pistons and rings STD Brand New, and i want to know, if its possible to use the EJ18 block with the EJ22 Pistons, just resleeving with new size? , this combination will be perfect if its possible because i can use our national fuel (etanol) with the hight compression ratio that will result for this change, so, with new sleeves , will be possible use the EJ22 pistons on my EJ18 block? , tks
ps: Sry for my bad english
DBC_Templar is offline   Reply With Quote
Old 10-22-2010, 01:43 AM   #2
bmxpunk
Member#: 89599
1995 almost 22B:)
red
DO you have access to a used 2.2 engine? What you are asking should be possible, but the cost to do the machine work + gaskets would be way more than what you should be able to find a used 2.2 for.
bmxpunk is offline   Reply With Quote
Old 10-22-2010, 12:39 PM   #3
DBC_Templar
Member#: 261609
unfortonely i am from Brazil, in here the subaru parts are to expencive , a used 2.2 engine its costing like U$2.600~U$3000, the service to do the resleave on my EJ18 will cost U$400~U$450 , in that case here in Brazil, its much more cheap to do the machine work + gaskets, tks for help.
Old 10-24-2010, 03:28 AM   #4
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
1994 BC4, 2015 Outback
For 400-500 I'm sure you can find 2.2 block halves shipped to Brasil...
Marnix is offline   Reply With Quote
Old 10-25-2010, 02:40 AM   #5
DBC_Templar
Member#: 261609
impossible to find an god working EJ22 shortblock for this price...
Old 10-25-2010, 09:59 AM   #6
Marnix
Member#: 51480
1984 AM5, 1984 AF1,
You only need the cylinder block not a complete shortblock. Ask around at USMB aswell... Should be possible to find in the States!
97-98 EJ22 n/a with EJ22T pistons/cams drumzzzzz Normally Aspirated with bolt-on Forced Induction Powertrain 29 11-14-2012 12:59 PM
ej18 with ej25d heads, possible? nojokesniper Normally Aspirated with bolt-on Forced Induction Powertrain 2 02-27-2009 08:55 AM
OBD-1 EJ18 or EJ22 CatchMyDrift Private 'Wanted' Classifieds 8 09-10-2004 04:22 PM
EJ18 and EJ22 Engine Swap Leftover Parts subachad Private 'For Sale' Classifieds 15 02-23-2004 12:06 AM
