Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 06-28-2002, 03:10 PM   #1
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Default My thoughts for closed-loop to open-loop with link.
We can use one of the two drives or both that operate based on rpm and fuel flow to turn on a relay that is normally connecting the signal line from the O2 to the link and switch it to a constant voltage of anywhere from 0-1v based on which voltage is easiest to create. Set the lambda target to this voltage. This way depending on your setting and if it is connected to both drives the ecu will go into open loop at a certain rpm and/or fuel flow.
My other idea (less likely to work):
If we can compress the wideband voltage into 0-1v then we can use it since we can set whatever lambda targets we want (0-1v). From the other posts I've read the resistance of the wideband sensor doest do much and is there just to check the condition of the sensor every once in a while. So all it would take is a device that converts the 0-5v of the wideband with a ratio of 1/5 into a 0-1v. Seem possible?
-Chav
Chav is offline   Reply With Quote
03 WRX bad cold start idle in closed loop / rich open loop fuelling toflaherty Open Source Reflashes 2 04-17-2010 10:06 AM
Close loop to Open loop and vice versa Walker Lam Open Source Reflashes 8 01-30-2009 11:51 AM
close to open loop goixiz Commercial ECU Reflashes 9 12-29-2006 10:22 PM
Closed Loop to Open Loop Transition, when? NavyBlueSubaru UTEC 19 03-03-2006 11:30 PM
What exactly is closed loop vs. open loop fuel control? Neek Engine Management & Tuning 5 03-09-2005 01:50 AM
