Old 10-21-2010, 01:21 PM   #1
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Default ver8 207 engine gasket kit??
ok well my block is at the machine shop and will be getting cleaned and fitted for pistons in about 2 weeks when the pistons get it, now my question is what gasket kit can i use??? i have only found a complete gasket kit at rallyspec, but its 450+ dollars is kinda high, i can get a 2.0 gasket kit for 250, is the only thing different the valve cover gaskets???? i can order those for 15 a piece, and i will have to get new head gaskets cuz the blocks getting bored .020" over,
seanathanq83 is offline   Reply With Quote
Old 10-21-2010, 02:19 PM   #2
seanathanq83
Member#: 173241
anyone??? i need this kinda quickly
Old 10-21-2010, 03:11 PM   #3
john 1badSTI
Member#: 77470
04 sti [email protected]
on e85@ 30psi--spinning
you should be able to use the 205 gskt set and stock size head gskts should still work even though your going .020 oversize.Compare the 205 gskts with your old 207's and I will bet they match up as the same.And since the v/c gskts are rubber they can be reused. good luck
john 1badSTI is offline   Reply With Quote
Old 10-21-2010, 03:21 PM   #4
seanathanq83
Member#: 173241
i dont have the old head gaskets, the talked to rally spec and the guy said i could do the 205 kit but the head gaskets are diff, i guess water holes are what he is talking about, also valve cover gaskets are different so i just ordered the set they offer with all 6 gaskets and 16 rubber gromment, cheaper than the dealer even with shipping, so i guess i will be getting a 205 gasket kit, does anyone know if they have the head gaskets??? and will they be ok to use?? i plan on about 400whp 450 tops, and ~25psi and will probably be using arias pistons since they offer 8.7:1 cr with out having to have them custom made unless someone can tell me some other ones i should use
EJ257 USDM STI Shortblock and Engine Gasket Kit - $1849 SHIPPED! P&L Motorsports Inc. Engine/Power/Exhaust 3 02-12-2008 12:15 PM
engine gasket kit LVT Built Motor Discussion 1 10-12-2006 08:37 PM
Where to order engine gasket kit, etc.. PeteDucati Built Motor Discussion 11 09-17-2006 10:52 AM
STi shortblocks are back- $1375 shipped, $1575 shipped with engine gasket kit subaruwrxparts.com Vendor 'For Sale' Classifieds 28 12-11-2003 12:51 PM
