Notices
Old 10-21-2010, 02:04 PM   #1
Jduke
Member#: 29699
2005 Legacy GT Wagon
Red
Default 99 LGT 2.5 Auto into a 98 LGT 2.5 Manual
Basic question (I think)...
What problems can I prepare myself for with this swap?
I have a 98 Legacy GT manual with 154,000 miles the engine has HG
issues and I have the opportunity to buy a wrecked 99 Legacy GT auto
with only 118,000 miles (this is a limited so im going to salvage the
leather and stuff too) But most importantly I want the low mile engine.
Side note: do these run the same rear differential? Auto vs Manual?
Thanks in advance for any help.
John
Jduke is offline   Reply With Quote
Old 10-21-2010, 05:29 PM   #2
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
The Manual transmisison will have a 4.11 Final drive and the Automatic will have a 4.44 Final drive. Are you specifically wanting the automatic transmission?
wrx_driver_2002 is offline   Reply With Quote
Old 10-21-2010, 07:49 PM   #3
Jduke
Member#: 29699
Red
more just looking to do an engine swap, but may consider the tranny as well if it eliminates possible issues. Are any differences between the auto's rear diff and the manuals rear diff?
Id like to keep the car a manual if possible, but the rear diff is going (binding up on tight turns after highway driving) So if its not possible to use the rer diff off the auto with the manual trasmission ill consider swapping the engine, auto tranny, and rear diff, etc. Does this make sense?
Thanks
Old 10-22-2010, 11:37 PM   #4
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
you can just swap ring n pinion gears from the rear diffs , motors r the same , just swap in torque convertr in place of flywheel
sense of nature is offline   Reply With Quote
Old 10-23-2010, 07:36 AM   #5
grafton
Member#: 187936
07 WRB STi
Thanks
an engine only swap is world easier than an engine AND trans swap, plus when going to auto you need the shifter,
all the electronics, and different mounting hardware under the transmission etc...
tbh the motor's should 100% the same if they are dohc
just do a motor swap and fix your rear diff less work and less headaches
grafton is offline   Reply With Quote
Old 10-23-2010, 07:38 AM   #6
grafton
Member#: 187936
07 WRB STi
Thanks
an engine only swap is worlds easier than an engine AND trans swap, plus when going to auto you need the shifter,
the only way it makes sense is if you want an auto
Old 10-25-2010, 04:04 PM   #7
Jduke
Member#: 29699
Red
I actually have the whole car... so If I needed to I could do the manual to auto swap... got a deal on a totaled 99 lgt limited....
But if I can Ill keep it manual and fix the rear diff
98 LGT 5spd into a 98 OBS? JapCarRealGood Transmission (AT/MT) & Driveline 7 05-28-2009 05:13 PM
how can i manage to put a 2.5 bumper onto a 98 impreza 2.2 lovethatIMPREZA Newbies & FAQs 2 08-16-2007 09:23 PM
98 L manuel tranny into a 98 auto 2.5rs ilgdrummer Transmission (AT/MT) & Driveline 0 09-28-2006 07:17 PM
Are 96-99 Legacy Rear Spoiler the same as 98-01 2.5RS Coupe? XyKo Newbies & FAQs 3 04-02-2006 10:23 PM
