Old 10-24-2010, 09:47 PM   #1
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
Default how far should i go???
ok so i have an 07 wrx with a
vf43 turbo
aps 65mm cai
aps hard inlet soon to be installed
tgvs deletes soon to be installed
sti intercooler
walbro 255 fuel pump
full 2.5inch turbo back
cp pistons
apr engine studs
tuned 288 whp
312 torque to the wheels
i was debating and wondering how far i should go with my motor i was thinking of connecting rods and crank shaft for it. i really dont know if im going to go to a big turbo or not but i like the idea of a solid block and good tune to have more breathing room
i know on the heads i cannot do the cams because it then can make it diffcult for DD which my car is
any input guys on what i should do or what company i should go to for the connecting rods and crank shaft
emsbuff124 is offline   Reply With Quote
Old 10-25-2010, 11:49 AM   #2
RicersWetDream
Member#: 245581
2009 WRX
2014 Forester XT
Unless you have a reason to tear into the engine I don't see much of a reason as to why you would want to tear into it again.
If you do a larger turbo, you've already taken the weak pistons out of the equation. I'm not really sure on differences between WRX and STi rods and cranks since they're both just EJ25 short blocks the only real difference between the two was the pistons having a slightly different dome on them for compression's sake.
CN, not worth it even if you max out the 43, maybe worth putting some h-beam or better rods in there if you go to a larger turbo and can push 400+ to the wheels.
RicersWetDream is offline   Reply With Quote
Old 10-25-2010, 04:16 PM   #3
emsbuff124
Member#: 201972
07 WRX TR
crystral grey
hmmm good point, yeah i didnt know really how far i need to go i have a conservitive tune on it but i just wanted to have a really safe motor. On the other hand i know that building a motor with the wrong type of parts can cause problems i know people who put internals in ment for the track and not DD and they end up having more issues than stock motors
how far should i go.... dan avoN7 Engine Management & Tuning 4 03-27-2003 11:56 PM
How far can I go without engine management with these mods... fueledbymetal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-01-2002 02:17 PM
How far can I go & still deal w/smog? Drew888 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-03-2002 11:13 PM
So how far would you go to show your love.... Philip Bay Area Impreza Club Forum -- BAIC 3 06-24-2002 11:10 PM
How far can you go with NA EJ25? Cusco Normally Aspirated Powertrain 14 02-18-2002 03:02 PM
