Welcome to the North American Subaru Impreza Owners Club Sunday August 30, 2015
Old 10-21-2010, 04:11 PM   #1
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
Default Phatbotti Tuned 2004 WRX: 2.0 VF39 MONSTER! 371whp on E85! *UPDATE*
Hey all, Mikey was helping me sort out a few problems i was having with knocking higer up in the RPMS. We couldn't quite figure out why this started happening other than a bad batch of fuel.
Previously the car was running 25* or so of timing at redline. After we started experiencing the problems we could not get the car to accept any more then 16* without it knocking bad! So i emptied the tank by driving on a safe map, filled up at another gas station, did a hard reset on the ECU, & re flashed the map on.
I also swapped out the plugs which were 1 step colder NGK's to stock heat range copper's. We thought that the colder plugs may have been leaving us un burned pockets of fuel and causing detonation since E85 already runs cold enough as it is.
Whatever it was the car is now running better than ever and is a real blast to drive!
Event: AirBoy dyno pull
Ambient Temp: 75
Elevation: 800
Weather: Clear, warm night
Tires: 17" all seasons
Car: 2004 WRX
Tuner: STi Mikey
Dyno Info: Airboy
Transmission: Stock 5 Spd
Gear: 3rd
Peak HP: 371
Peak Torque: 344
Baseline hp/tq for a stock on same dyno: 185whp
Target Boost: 21
Target AFR: 11.6-11.8
Fuel: E85
Engine/Power Modifications: Stock Motor, VF39 (self porting job), 73mm Intake, full 3'' TBE, DW 850's, Hallman MBC, STi Mikey Tuned on E85
Full list of modifications are available here: http://forums.nasioc.com/forums/show...3#post32237283
Have a good one!
-Caleb
Data Log as requested:
AFC- A/F Correction #1 (%)
AFL - A/F Learning #1 (%)
AP - Atmospheric Pressure (psi)
EL - Engine Load (Calculated) (g/rev)
ES - Engine Speed (rpm)
FBK - Feedback Knock Correction* (degrees)
FKC - Fine Learning Knock Correction* (degrees)
ITT - Ignition Total Timing (degrees)
MA - Mass Airflow (g/s)
MASV - Mass Airflow Sensor Voltage (V)
WDC - Primary Wastegate Duty Cycle (%)
TOA - Throttle Opening Angle (%)
Code:
Time	AFC	AFL	AP	EL	ES	FKC	FKC	IAM	ITT	IDC	IAT	MA	MASV	WDC	TOA	MPH	PSI
0	0	0	14.22	0.57	1899	0	0	16	28	9.32	82	18.26	2.3	19.22	37.25	24	1.08
266	0	0	14.22	0.59	1992	0	0	16	30.5	11.05	82	19.59	2.32	34.9	100	25	1.84
546	0	0	14.22	0.59	2068	0	0	16	30.5	11.47	82	20.29	2.38	47.45	100	25	2.11
796	0	0	14.22	0.58	2141	0	0	16	31	11.88	82	20.81	2.4	60	100	26	2.46
1061	0	0	14.22	0.59	2221	0	0	16	31	12.32	82	21.97	2.46	72.55	100	28	2.77
1326	0	0	14.22	0.6	2282	0	0	16	30.5	12.66	82	22.92	2.46	85.1	100	28	3.06
1592	0	0	14.22	0.62	2378	0	0	16	30	13.7	82	24.38	2.52	97.65	100	29	3.38
1857	0	0	14.22	0.65	2450	0	0	16	29.5	14.63	82	26.46	2.58	79.22	100	29	3.71
2122	0	0	14.22	0.66	2525	0	0	16	28.5	15.62	82	27.91	2.62	79.22	100	32	4.14
2387	0	0	14.22	0.7	2598	0	0	16	28.5	16.63	82	30.41	2.64	79.22	100	32	4.62
2652	0	0	14.22	0.71	2696	0	0	16	28.5	17.83	82	32.02	2.76	79.22	100	34	5.26
2918	0	0	14.22	0.76	2797	0	0	16	27	19.1	82	35.17	2.86	79.22	100	34	6.07
3167	0	0	14.22	0.8	2930	0	0	16	26	21.87	82	38.73	2.9	79.22	100	36	7.06
3432	0	0	14.22	0.88	3038	0	0	16	25	25.27	81	44.6	3	79.22	100	39	8.43
3713	0	0	14.22	0.93	3138	0	0	16	24.5	28.78	81	49.34	3.18	79.22	100	39	10.35
3963	0	0	14.22	1.03	3272	0	0	16	24	33.51	81	56.86	3.38	79.22	100	40	12.82
4244	0	0	14.22	1.22	3443	0	0	16	22.5	41.14	81	69.37	3.58	79.22	100	40	17.29
4493	0	0	14.22	1.69	3609	0	0	16	23	53.89	81	96.85	3.72	79.22	100	43	21.66
4758	0	0	14.22	1.46	3820	0	0	16	23	49.72	81	73.55	3.94	79.22	100	43	20.55
5024	0	0	14.22	1.22	3998	0	0	16	23.5	55.44	81	81.95	3.82	79.22	100	47	20.67
5289	0	0	14.22	1.4	4197	0	0	16	23.5	59.99	79	97.11	3.94	79.22	100	52	20.98
5554	0	0	14.22	1.42	4380	0	0	16	24	64.48	79	104.2	4	79.22	100	52	21.19
5804	0	0	14.22	1.42	4590	0	0	16	24.5	67.56	79	108.64	4.04	79.22	100	56	21.19
6069	0	0	14.22	1.43	4810	0	0	16	25	70.81	79	113.86	4.08	79.22	100	56	21.17
6350	0	0	14.22	1.42	4977	0	0	16	25	73.26	79	118.62	4.14	79.22	100	62	21.02
6599	0	0	14.22	1.42	5230	0	0	16	25.5	76.99	79	123.93	4.2	79.22	100	62	20.65
6864	0	0	14.22	1.42	5419	0	0	16	26	79.76	79	127.81	4.22	79.22	100	66	20.52
7130	0	0	14.22	1.41	5572	-2.11	0	16	24	80.83	79	130.96	4.26	79.22	100	66	20.34
7395	0	0	14.22	1.39	5764	-2.11	0	16	24.5	83.62	79	133.88	4.3	79.22	100	71	19.9
7660	0	0	14.22	1.36	5948	-2.11	0	16	25	84.34	79	135.91	4.3	79.22	100	76	19.51
7925	0	0	14.22	1.34	6107	-2.11	0	16	25	84.69	79	136.69	4.3	79.22	100	76	19.22
8190	0	0	14.22	1.32	6292	-2.11	0	16	25.5	85.9	79	138.24	4.32	79.22	100	80	18.99
8456	0	0	14.22	1.28	6449	-2.11	0	16	26	87.27	79	139.54	4.34	79.22	100	80	18.97
8721	0	0	14.22	1.25	6660	-2.11	0	16	26	86.68	79	137.98	4.32	79.22	100	85	19.1
8986	0	0	14.22	1.24	6732	-2.11	0	16	26	86.25	79	138.76	4.32	79.22	100	85	19.3
subydude02 is offline   Reply With Quote
Old 10-21-2010, 04:14 PM   #2
WOTisfreedom
Member#: 192212
2004 S203ish WRX
Smurf'd OUT
That's wuz up , I luv to see 2.0's putting the power down, great numbers!!
WOTisfreedom is offline   Reply With Quote
Old 10-21-2010, 05:11 PM   #3
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
hey if you are going to be pushing it on e85 you need to buy the tester from Quick Fuel Technology,if is basically a portable test tube marked off to show what percentage of ethanol is in the fuel you are running.All the instructions for use are on the test tube and IIRC it was less than 20.00.
john 1badSTI is offline   Reply With Quote
Old 10-21-2010, 05:14 PM   #4
roof_rack
Member#: 257866
wow, damn good numbers out of a VF39, congrats!
roof_rack is offline   Reply With Quote
Old 10-21-2010, 05:51 PM   #5
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
very good point. i was actually going to test that previous batch.
I was seeing online that Spinx(place that sells e85 here) actually switches to a winter blend of e70
Old 10-21-2010, 06:58 PM   #6
GDB FAN
Member#: 105814
370?!?
And you did this on a 2.0L, with a vf39?
I was reading your other thread and you picked up, basically 30whp just by changing the plugs?
http://forums.nasioc.com/forums/show...light=vf39+wrx
GDB FAN is offline   Reply With Quote
Old 10-21-2010, 07:15 PM   #7
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
Originally Posted by GDB FAN View Post
370?!?
yeah i know doesn't make sense but it's what i came up with when i ran the log last night! I've actually since turned the pressure down, i don't want to run nearly that much power on my stock motor. 342whp was above what i wanted initially! I should be down around 19psi now
Old 10-21-2010, 08:50 PM   #8
SubieFiesta
Member#: 149426
2002 Subaru WRX
and 2005 Subaru STi
This is hard to believe. Not saying it isnt possible, just hard to believe.
Can you post the log please.
SubieFiesta is offline   Reply With Quote
Old 10-21-2010, 09:58 PM   #9
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
will do when i get home this evening!
Old 10-21-2010, 11:40 PM   #10
achavez
Member#: 139320
2006 RA 1-4 5mt
wrx obp needs a e85 tune
370whp is awesome. Especially from a vf.... why didn't your 1/8 traps reflect it though? Just askin because rob and juan both had awesome traps
achavez is offline   Reply With Quote
Old 10-21-2010, 11:46 PM   #11
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
I really wasn't pushing the car that hard. I'm just to nervous to blow anything right now. I was able to trap alittle over 90 in the 1/8th which is actually pretty good. I suspect that i could trap 93-94 no prob if i was really goin at it. i think Juan trapped a 95 with his OG Green
Mikey's tells me that with the current setup the car will preform 11.7 all day long. But it will be a good while before i push that hard(gear set, forged pistons etc.)
Thanks though!
Old 10-22-2010, 12:06 AM   #12
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
OP updated with data log the airboy was generated from
Old 10-22-2010, 03:41 AM   #13
PhatBotti Tuning TKR
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Caleb,
Your car has turned out to be a beast, but it looks like they may have switched over to the winter blend (~70% ethanol). Looks like your throwing a 1 count up top. Lets get the tester John was talking about.
-Mikey
PhatBotti Tuning TKR is offline   Reply With Quote
Old 10-22-2010, 06:27 AM   #14
achavez
Member#: 139320
2006 RA 1-4 5mt
Thanks though!
understandable about not pushing it. ive gone to sac raceway a few times and every time i went down the strip i thought 3rd gear was goin to give but shes still hangin in there
Old 10-22-2010, 08:44 AM   #15
Innovative Tuning
Member#: 67958
MY96 Time Attack
and 06 STI daily
Your map was probably setup to avoid significant fuel trimming at high loads, which is normally a good thing, but they probably switched to winter blend or the tank you pumped from is somewhere in between at the moment. As the gas content increases your car will run richer under high load and the ignition system is probably having a hard time burning the mixture.
Innovative Tuning is offline   Reply With Quote
Old 10-22-2010, 08:51 AM   #16
CatfaceType-R
Member#: 81102
this car has fmic, no?
CatfaceType-R is offline   Reply With Quote
Old 10-22-2010, 10:05 AM   #17
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
Caleb is not really launching the car, actually IMO he is not even launching it . He should 2-3mph IMO by launching the car. Caleb: you need to ask Mikey to setup your Launch Control it will make life really easy. My first time at the track was at Greer and I did ok, this the thread about with the camtuning.com map.
http://forums.nasioc.com/forums/show....php?t=1719031
Caleb has driven my car with the V39 before, he should be able to make a comparison
Thanks though!
Comparing your times with my times is not a really fair comparison. My car was running really crappy because of LC triggering the failsafe fuel tables; like me and other had said in my thread with the bugs fix my car should trap in the high 90s and low 100s in the 1/8th
It has a STi TMIC
Old 10-22-2010, 10:18 AM   #18
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
seems too easy to use, john you think this works pretty well??
blowbyu24 is offline   Reply With Quote
Old 10-22-2010, 10:47 AM   #19
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
http://www.zeitronix.com/Products/ECA/ECA.htm
or if you had stand alone, you can simply pick up the 0-5v signal from the denso sensor but this is a bit cleaner and easier to view.
Old 10-22-2010, 02:49 PM   #20
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
yes it works real well I check every 3rd fill up for safetys sake ans it is just a smaller version of what everybody used in the beginning and quick fuel tech does a lot of carburetor conversions for racers so their stuff is top notch.
Old 10-23-2010, 11:50 AM   #21
strange_magic
Member#: 259257
Wow, your mid range timing is awesome! I have a very similar set up to yours but I dont run anywhere near that much. I thought 17* at peak trq was pushing it. Maybe I will have to do some tinkering and see if I can pick up some torque.
strange_magic is offline   Reply With Quote
Old 10-23-2010, 03:18 PM   #22
subydude02
Member#: 140643
04' PSM Limited Wrx
371whp/344wtq E85
Wow your right i just noticed that too. 30* in the midrange. Must explain why i'm slammed into the seat
Old 10-23-2010, 10:52 PM   #23
Member#: 239659
STI Mikey & Phatron
Tuning Da Subies
Caleb,
You have asked me quite a few times as to what the car is capable of running down the track.
Bonfire with the 18g just went 11.8 @115 in his 04 wrx, full weight.... making 32whp less!!
*** Phatbotti Tuned 2002 WRX: 2.5L FP Red KSTech 83mm 16 Bit ECU 450whp E85 *** PhatBotti Tuning TKR Proven Power Bragging 34 11-22-2010 12:43 PM
*** Phatbotti Tuning: 2004 WRX: 2.0 VF39 MONSTER! 342whp on E85!! *** PhatBotti Tuning TKR Proven Power Bragging 74 10-07-2010 11:55 AM
2.0 + Dom 3.0XT-R + E85 makes 392whp rexblake Proven Power Bragging 36 07-20-2010 10:58 PM
04wrx 2.0 vf39-279whp,260tq 1.20 correction - tuned by TheShop/Junior meo Proven Power Bragging 93 04-26-2010 11:35 PM
2.0 vf39 tuned by Andy at Verocious pearljam11 Proven Power Bragging 5 04-03-2008 09:15 AM
