Go Back   NASIOC > NASIOC Classifieds > Vendor Announcements
Closed Thread
Old 10-21-2010, 06:07 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Vendor Sales Rating: (95)
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default New Moroso High Volume, Baffled Aluminum Pans for 08+ STi
The Moroso Pain is designed to reduce oil slosh during hard cornering, and helps to prevent oil pickup starvation which could cause a loss of a motor!
Lab tested, and track proven this pan is the next best thing to a full dry sump system!
* 5qt Capacity
* Manufactured from .125" thick aluminum
* One piece 3/8" thick billet aluminum oil pan rail provides a rigid flange for leak-free sealing * Bottom of oil pan is finned for heat dissipation
* Windage tray for increased horsepower saving and oil control
* 1/2" NPT fitting that can be used for crank case ventilation or for head drainback
* 1/2" NPT fitting for oil temperature sender
* Oil pump pickup included
* Oil pan gasket included
* Included adapter allows use of factory dipstick
* High-grade mounting hardware included
__________________
RallySport Direct is offline
Old 10-26-2010, 11:14 AM   #2
RallySport Direct
Member#: 33174
We are Open Late!
Bump!
__________________
Closed Thread
New Moroso EJ Series Steel Oil Pan! RallySport Direct RMIC Vendor Classifieds 21 01-11-2011 10:44 AM
FS: (CT) New Perrin turboback (stealth black version) + Accessport for 08 STi - $1600 jaybert Tri-State Area Private Classifieds 0 01-21-2009 05:40 PM
New Cat back or Turbo Back Exhaust for 08 STI!! Fizz Autosports Engine/Power/Exhaust 2 12-10-2008 10:32 AM
