Old 10-21-2010, 09:09 PM   #1
jesterjames
Member#: 252663
Chapter/Region: HIIC
Default Re-assembly Question
When you guys go to reassemble the motor what do you do to purge the cooling system?
i couldnt find anywhere that its covered in the service manual
jesterjames is offline   Reply With Quote
Old 10-21-2010, 10:45 PM   #2
69subaru360
Member#: 159682
1995 WRX
2015 F150
Fill the radiator first, then cap it. Fill the tank on the engine next. I use one of those funnels that attaches to the rad cap and let it run and blow all the air out then cap it. If you're working on an 02 with no cap on the radiator, fill the block through the upper hose or you will have a big air pocket.
Old 10-21-2010, 11:37 PM   #3
jesterjames
Member#: 252663
THANKS!!
Old 10-22-2010, 12:56 PM   #4
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
I fill up the rad first, cap it, then fill up the upper reservoir. Once it's mostly full (not entirely full, or the next step will splash some out), I massage the upper rad hose to pump the coolant out of the upper res into the lines/engine to get the bubbles out (refilling the upper res as necessary).
I've done this probably 3-4 times on my car and have never had an air pocket.
Old 10-24-2010, 11:03 PM   #5
jesterjames
Member#: 252663
i have an 02, so no res
n00b questions on re-assembling my engine lavid2002 Built Motor Discussion 205 07-24-2010 03:21 AM
Question about re-assembling an engine... RBT-Rex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-10-2010 07:09 AM
EJ20K Re assembly questions. dr3w Pre-2002 Factory Turbo Powertrain 93 10-24-2009 12:02 PM
Motor re-assembly Saturday in Sterling rogue Mid Atlantic Impreza Club -- MAIC 14 08-27-2005 12:38 PM
Re-assembling stock suspension - do I need these parts? BurtonCR Brakes, Steering & Suspension 7 02-13-2005 07:48 PM
