Old 10-23-2010, 07:24 AM   #1
Join the Riot
Member#: 158523
Default EJ205 Block, 20G Heads... Gasket shopping
Swapping an open deck EJ20g from a JDM forester into my na 98 forester. Donor car had a spun big end bearing.. This was known, got a great deal. Found a solid EJ205, and will be swapping the heads and intake manifold onto the 205 block so i can retain the loom and other bits and pieces that i already have sorted out.
So, to maintain as close to stock compression ratio possible, will the stock EJ205 gasket [11044AA483] be a good fit? I'm aware the 20G gasket is 1.37mm due to the pistons rising above the deck at TDC, and the 205 gasket is 0.6mm. I was hoping it would be a simple calculation however the piston surfaces appear to have different castings and i have no idea what sort of volume difference there may be there, if any.
Will this even be an issue, or will it be to small of a variable to upset the ECU? I do plan on running a piggyback ECU in the near future but not immediately.
As for the timing belt, both engines have been recently changed [<10000kms]. I figure I'm better off using the 205 tensioner at the least as it is designed for the lesser overall engine width [would equate to ~1.54mm]?
Join the Riot is offline   Reply With Quote
Old 10-24-2010, 02:26 AM   #2
Join the Riot
Member#: 158523
anyone?
EJ205 Blocks,Heads, cams, EJ257 block, cams gotawd Engine/Power/Exhaust 22 04-30-2009 09:18 AM
EJ205 block and heads, 45k miles, $600 kpowell12 Engine/Power/Exhaust 16 10-09-2006 04:17 PM
FS: ARP head stud set, EJ205/207/20G/20H/255/257/22G25D WJM Private 'For Sale' Classifieds 10 11-18-2005 09:47 PM
usdm sti short block with head gaskets sjs41379 Private 'For Sale' Classifieds 8 08-06-2005 10:20 PM
Dirty Block & head gasket replacement SCOOBER Normally Aspirated with bolt-on Forced Induction Powertrain 0 03-27-2003 06:52 PM
