Old 10-23-2010, 02:02 PM   #1
rpg5553
Member#: 253423
Default 95 EJ20G Turbo(JDM) no Injector pulse fuel
Can anyone tell me how to diagnose no pulse at injectors. I have wired a lite up and verified getting 12v power at the injector connector. Got the lite ground to the other connection. Verified my ground to the ecu. Is there any solenoid, etc that would cause this? I do not have the following> idle air control solenoid, waste gate solenoid, boost pressure sensor(using manual boost controller). The vehicle speed sensor is not there but
was told not required on 95. Also the ecu was for an automatic so is there something different about it. I found a pressure exchange solenoide from a 95 impreza and wired it up. There was another sensor attached to it and from pictures found it says it is a pressure/map sensor. Not a clue where it goes and if it relates to the EJ20G motor!
Thanks for any help you can give me
rpg5553 is offline   Reply With Quote
Old 10-23-2010, 06:08 PM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Sounds like an ecu issue ,Iirc the ecu controls the ground signal.. Also did you post in the pre 2002 turbo forum?
sense of nature is offline   Reply With Quote
Old 10-24-2010, 09:58 AM   #3
rpg5553
Member#: 253423
Posted in three forums with only this reply
EJ20G Motor no fuel no injector pulse. rpg5553 Built Motor Discussion 0 10-22-2010 09:18 AM
FS : EJ20G engine 550cc injectors and fuel rail drop in combo subartender Engine/Power/Exhaust 3 10-19-2010 11:38 PM
No injector pulse?! Please help! JordanHoudek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 11-22-2009 02:04 AM
No injector pulse roostema4328 Subaru Conversions 12 11-17-2008 04:01 PM
No Injector Pulse help (haltech E6K users) black knight Engine Management & Tuning 0 08-12-2003 11:01 PM
