Old 05-11-2013, 03:02 PM   #2676
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Originally Posted by bettner12 View Post
I KNOW! i want them!!!
tom, what part of slippery rock are you in? i could swing up sometime and lend a hand sometime
My house boarders the field with the water tower at the top of Center Street. Hell, you could even come up just to drink my beer.
dexterous is offline   Reply With Quote
Old 05-11-2013, 03:03 PM   #2677
dexterous
Member#: 23553
2014 WRX - Daily
IT RUNS AGAIN!!!
Old 05-11-2013, 03:04 PM   #2678
dexterous
Member#: 23553
2014 WRX - Daily
Working on the car right now so I dont want to spend a ton of time posting BUT, I finally got the car running today. I put the last bolt in, primed the oil, primed the fuel and hit the key. It started up right away, idled flawlessly and otherwise seems perfect.
Old 05-11-2013, 04:05 PM   #2679
bboylocob
Member#: 151809
2007 WRX
Sweet!!!! Great news!!!!!
bboylocob is offline   Reply With Quote
Old 05-11-2013, 06:09 PM   #2680
TwinscrollGT35R
Member#: 256810
Sweet...
TwinscrollGT35R is offline   Reply With Quote
Old 05-11-2013, 07:37 PM   #2681
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
What is the cooler in location of stock tmic? Fuel or oil?
Layvon is offline   Reply With Quote
Old 05-11-2013, 09:16 PM   #2682
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
oil i think.
if you have any post some pics of the compressor elbow going to the fmic piping.
stretchedk7 is offline   Reply With Quote
Old 05-11-2013, 09:26 PM   #2683
dexterous
Member#: 23553
2014 WRX - Daily
Thats my Setrab oil cooler. I run -10 hoses form a Mocal filter adapter. Its top notch stuff and I see ZERO pressure drop.
Old 05-11-2013, 09:50 PM   #2684
dexterous
Member#: 23553
2014 WRX - Daily
Originally Posted by stretchedk7 View Post
oil i think.
I didn't have any but I am in the garage so here you go. I have a big camera and its a very tight spot so this is the best I could do without taking the car apart again.
Old 05-12-2013, 12:35 PM   #2685
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
sweeet. so looks to me like you didnt weld an elbow on compressor but used a 90 degree coupler?
jw, in the past ive had to weld an elbow because of space
Old 05-12-2013, 12:53 PM   #2686
dexterous
Member#: 23553
2014 WRX - Daily
You're correct. Space wasn't an issue at all but I think I would like to convert it to a solid, welded bend next winter. I have not put any effort into things like that as my only goal for the past two years has been to get the car tuned. Thus far, I haven't been all that successful due to some pretty bad luck. I could have had it tuned at any point last year BUT I was very concerned that I was going to experience another block failure. Now that I am running a fully closed deck block with reinforcement material that runs all the way down the outside of the cylinder wall I think its time to give it a go.
Old 05-12-2013, 01:04 PM   #2687
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
sweeet sounds good. do it big
Old 05-12-2013, 07:24 PM   #2688
dexterous
Member#: 23553
2014 WRX - Daily
Well, I spoke too soon. I went to go for a drive, pulled out onto the main street and heard a horrible noise (sounded like a boost leak or something). Turned around, and went back to my house to discover that my turbo's compressor wheel was hitting the side of the housing. The turbo is out and I cant find anything else wrong with the car.
I hope this is because something happened to it while it was in storage this winter and not some kind of foreign object damage. The compressor is toast but the turbine looks perfect.
Old 05-12-2013, 08:13 PM   #2689
isis
Member#: 73283
05 CTS-V
03 Z1000
**** dude...
isis is offline   Reply With Quote
Old 05-12-2013, 08:41 PM   #2690
ringlander
Member#: 336100
2011 sti
So sorry to hear that. I hope it stops at the turbo. Did you take any pictures?
ringlander is offline   Reply With Quote
Old 05-12-2013, 08:44 PM   #2691
Fir3Fighter
Member#: 316780
2003 Impreza WRX
I hate ****ty luck..
Fir3Fighter is offline   Reply With Quote
Old 05-12-2013, 08:45 PM   #2692
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You can't catch a break Tom. Does it look like something went through the turbo or was it just a rub?
Old 05-12-2013, 09:35 PM   #2693
bboylocob
Member#: 151809
2007 WRX
Dang bro that sucks!!!! Its all good we know u will get it fixed and running asap. Keep Ur head up
Old 05-12-2013, 09:37 PM   #2694
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
jeeeez man......dont know what to say
Old 05-12-2013, 09:52 PM   #2695
manitou
Member#: 193757
2006 XTI Limited
OBP, Junior tuned 573WHP
Dayamn dude your luck's got to change for the better! Very sorry to hear this!
Old 05-12-2013, 10:24 PM   #2696
dexterous
Member#: 23553
2014 WRX - Daily
I took the entire turbo apart and couldn't find any explanation. There's a lot of runout on the compressor and you can clearly see where its rubbing the housing. The turbine is perfect or at least as perfect as I can tell by looking at it. It also makes a pretty bad noise when I rotate the blades by hand. I see no evidence that the compressor ingested anything but I wouldn't have expected to see that either given that theirs a filter right on the end of the turbo. Its all packed up again and heading to comp in the morning. USPS says that it will be there on Wednesday so hopefully this is only a two week delay.
Tom
Old 05-12-2013, 10:33 PM   #2697
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
I don't know much about how the chra system works but could some gummed up oil from sitting be the culprit? If it solidified maybe it got a little misaligned and thwacked stuff.. or ball bearings got boogered up?
We can all speculate but i guess we'll find out soon enough
Old 05-12-2013, 10:46 PM   #2698
shilohb
Member#: 214121
2005 604whp/543wtq
fp3586 twinscroll
Man your luck! I hope you leave your house wearing a helmet and full body suit!
shilohb is offline   Reply With Quote
Old 05-13-2013, 10:35 PM   #2699
dexterous
Member#: 23553
2014 WRX - Daily
Well, I run a filter on the turbo so I am not sure how that could happen. I checked the filter as well as the restrictor and both looked good. The turbo had oil flowing through it for sure, I primed the ever living crap out of the engine before I fired it up for the first time.
Old 05-13-2013, 10:38 PM   #2700
dexterous
Member#: 23553
2014 WRX - Daily
I called COMP and talked to them today. I also I shipped the turbo via USPS and according to the tracking info, it should be there by Wednesday. They said that they could possibly ship it back to me as early as Monday which will reduce my down time significantly.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 08:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 10:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 05:06 PM
