Old 12-30-2010, 11:19 AM   #51
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
If this is a street car you might want to consider moving the fuel system between the strut towers. It will be much safer there if you would happen to be rear ended or involved in some sort of crash involving the rear of the car.
Md05STI is offline   Reply With Quote
Old 12-30-2010, 11:26 AM   #52
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
Originally Posted by KillerBMotorsport View Post
I think he meant preload. Meaning have the line tight between fittings.
Just be sure the are not super tight between cable carriers. A little room for expansion/contraction will prevent premature wear of the lines.
Ok, makes sense now. The -10 line is pretty inflexible so its pretty neutral in the cushion clamps. The -6 stuff is much more flexible so I did put a bit of pre-load on it. I will go back and loosen it up a bit. I am kind of concerned that if it is slightly loose it will move ever so slightly in ~150mph wind and rub on stuff. Should this not be a concern?
dexterous is offline   Reply With Quote
Old 12-30-2010, 11:32 AM   #53
dexterous
Member#: 23553
2014 WRX - Daily
Yeah, know what you are saying. The car will be driven to meets, track events, etc. I also have a JDM Spec-C tank (not pictured) that will be installed in that area as well so its going to be pretty cramped. I know others have pulled it off but I just cant picture how to make it work with my setup.
Old 12-30-2010, 11:49 AM   #54
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Heres how mines setup, minus the spec c tank of course. My hydramist pump is in the spare tire area like yours.
Old 12-30-2010, 12:01 PM   #55
dexterous
Member#: 23553
2014 WRX - Daily
Did you drill right through the floor of the trunk for the output from the A1000?
Old 12-30-2010, 12:34 PM   #56
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Yes then ran it down the drivers side of the car
Old 12-30-2010, 12:41 PM   #57
dexterous
Member#: 23553
2014 WRX - Daily
I was thinking of doing that my self. Did you use the factory return line?
Old 12-30-2010, 01:16 PM   #58
Md05STI
Member#: 76974
2005 CGM STI
10.03 @ 135
Yea i used the factory return
Old 12-31-2010, 11:31 PM   #59
dexterous
Member#: 23553
2014 WRX - Daily
Lots more work on the car today! I cant believe how many small things need to be adjusted, moved and changed! I worked for seven hours and unless you watched me work you would hardly notice any changes.
Old 01-01-2011, 12:31 AM   #60
dexterous
Member#: 23553
2014 WRX - Daily
Here are a few picts from today. I was shocked to find out how hard it was to get the lines through the grommets and into position. I have also decided to redo the side with the braided lines so that the -10 line has a large grommet as it seems a bit more stressed than I would like.
I also built a new meth surge tank to fit into the area that its going to live now. When I first got into meth a few years ago I learned a lot about about making surge tanks. A proper meth surge tank needs to have a breather port (the small barb on the left side), a large inlet (5/8 in this case) and a outlet pointing to the rear of the car (liquid naturally flows there during acceleration). I also fill the tank with real fuel cell foam to limit as much movement as possible. I glue everything together (including the cap) with "
automotive goopautomotive goop
" with is the only thing that I have found that will reliably hold through the hot and cold with meth chewing on it.
Old 01-02-2011, 08:32 PM   #61
dexterous
Member#: 23553
2014 WRX - Daily
I got a fairly large shipment of parts in the mail yesterday and I also drove down to Pittsburgh to pickup my Moore Performance twin scroll header (the turbo arrives on Wednesday). I also spent a bit of time on the motor its self so that I could work on the fuel system bits that are located on the motor.
Test fit of my injectors and rails:
Here's where I am planning on putting my fuel pressure regulator:
Here's my fuel distribution solution. I could only get a -10 to -8 "Y" adapter so I had to use multiple adapter s to go from -8 to -6 and then the hose fittings. This collection of adapters is going to ride on a custom bracket so that it hovers very close to the pitch stop mount in a similar position shown on the second picture.
Here's my header:
Old 01-02-2011, 09:04 PM   #62
Fuj1wara
Member#: 249207
2010 STi SE
Great build so far, looking to your progress
However, this image is the reason why I wont use that header, look at the excess length of the exhaust manifold. Excess length is less efficiency, and our stock header setup already is longer than it should be.
Good luck with your goals, I'll be following along to see how it goes!
Fuj1wara is offline   Reply With Quote
Old 01-02-2011, 09:04 PM   #63
CatfaceType-R
Member#: 81102
very nice
CatfaceType-R is offline   Reply With Quote
Old 01-02-2011, 10:12 PM   #64
dexterous
Member#: 23553
2014 WRX - Daily
Yeah, they are pretty long. I am not sure how else you would make it EL though. At this point, the biggest challenge that the "long" pipes seem to be presenting me is how to hook up my oil cooler. If you look in the picture that you quoted above you will see that there is no room to pass a pair of -10 hoses through like I had in my old setup.
Here's my old setup:
Old 01-02-2011, 10:21 PM   #65
Fuj1wara
Member#: 249207
2010 STi SE
Remote hook up the oil filter. BTW, your response and humility makes me You seem to have quite a bit of commonsense
Old 01-02-2011, 10:22 PM   #66
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
it looks like that header is going to sit really low in the chassis, how does it compare (as far as distance between the bottom of the manifold, and the ground) to the stock manifolds?
looks like you are making good progress.....
timeXlost is offline   Reply With Quote
Old 01-02-2011, 10:35 PM   #67
dexterous
Member#: 23553
2014 WRX - Daily
Originally Posted by timeXlost View Post
it looks like that header is going to sit really low in the chassis, how does it compare (as far as distance between the bottom of the manifold, and the ground) to stock
That's a really good question. I was actually sitting here thinking the exact same thing. Once i have the motor in the car I will post lots of good Picts from angles that show the answer as clearly as possible.
Old 01-02-2011, 10:47 PM   #68
dexterous
Member#: 23553
2014 WRX - Daily
LOL, glad I made you smile, it so easily goes the other way here. So about this remote oil filter adapter idea of yours, what do you have in mind? I have seen a few other setups before but I never took the time to understand why it's done. Is it only a fitment thing or are there other advantages? I guess I could run a larger filter...
I worry about oil pressure drop and it's another point of failure. Hmmm...
Old 01-02-2011, 10:53 PM   #69
Fuj1wara
Member#: 249207
2010 STi SE
With the right setup, it shouldn't be that much more tubing, which would be less of a pressure drop than you think. Yes, it is usually used in situations where it's needed or it becomes more beneficial for periodic maintenance. Yes, more lines can become more things to worry about, but if you do it right, it'll be something you don't worry about as much as you think/
Old 01-02-2011, 11:05 PM   #70
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
Aspen White / Silver
I think you could have saved some space and complexity by just going with -8 to the rails on the supply, and even all the way back to the regulator.
Or going with a flare reducer
Token-Negro is offline   Reply With Quote
Old 01-02-2011, 11:45 PM   #71
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Since it's out of the car, think of it this way... You have just over an inch before you're at the outside surface of the belly pan. The bottom of our pan, at the back edge, is close to the belly pan. The back is closest because the engine sits at an angle in the car, as it does on some engine stands too.
Hope this helps.
KillerBMotorsport is online now   Reply With Quote
Old 01-03-2011, 04:10 PM   #72
dexterous
Member#: 23553
2014 WRX - Daily
Man, I looked and looked and looked (obviously not hard enough) for a fitting like that but I could not find one at JEGS. In the end I only ended up with one more piece (the male -6 to -6 union).
Old 01-03-2011, 04:14 PM   #73
dexterous
Member#: 23553
2014 WRX - Daily
Hope this helps.
Moore says the header is not the lowest point so I guess we will see. Any chance you have any suggestions for my oil cooler?
Old 01-03-2011, 05:46 PM   #74
Token-Negro
Member#: 81659
2006 STI / 2010 FXT
www.anplumbing.com Ive bought so much from these guys they know my voice. Great place to shop if you don't see it listed call them they supply or are supplied by EVERYONE! XRP,Earls,Aeroquip etc.
Yeah id just do the -8 to the rails looks like u just have a easy NPT > AN adapter on each end of the rail to set it up to what ever size. If you wanted to go really clean you could do a hose end that goes right to NPT and not use any adapter. In the engine bay you might also think about going to a softer cloth braided line the SS stuff is brutal on anything that comes into contact with it. You can also cover it with fire sleeve and tape the ends down if you really want the SS braid. Another trick is using heat shrink tubing over the SS braid.
Old 01-03-2011, 06:00 PM   #75
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Tough to tell from the pics, but what's there certainly looks like it's not going to fly
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 08:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 10:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 05:06 PM
