Old 12-27-2011, 04:00 PM   #1101
dexterous
Member#: 23553
2005 STI - Insanity!
2014 WRX - Daily
The numbers I posted were based on the combo of the numbers from my AVC-R and the Hydra.
dexterous is offline   Reply With Quote
Old 12-27-2011, 05:09 PM   #1102
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
Did you have a specific date you want the car back up and finished by Tom?
binjoau is offline   Reply With Quote
Old 12-27-2011, 11:28 PM   #1103
dexterous
Member#: 23553
2014 WRX - Daily
A few weeks ago I was going to try for new years. Now I am thinking mid January because I am making a few small changes. It's not like I can drive it much in the winter any way. Either way I won't be getting tuned until April.
Old 12-28-2011, 10:42 AM   #1104
USMC3782
Member#: 292585
96 OBS and 00 OB
Green/Blue
tom,
great build thread. this shows great ability to overcome adversity and to succeed. I wish nothing but the best for you. I work at a dealer, if you need anything at all please let me know. This car is front cover worthy on any magazine worth its name.
BTW it took me 2 weeks to read through all of this. Better than any Tom Clancy book for sure!
USMC3782 is offline   Reply With Quote
Old 12-28-2011, 01:44 PM   #1105
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
So she will be ready for next summer then for sure, my completion is for May now with everything that's changed on the build.
Perhaps a friendly drag race is in order? Lol.
Although il be at 500whp I'm sure you will be way over that
Old 12-28-2011, 02:08 PM   #1106
geronimo81
Member#: 154586
1996 Turbo Outback
9psi on 91 No EM
Tom, gotta give you props for working so hard on this. I can tell that Abbey is way more important to you so even bigger props for that.
Can't wait to see the start up video!
geronimo81 is offline   Reply With Quote
Old 12-28-2011, 06:11 PM   #1107
c2scanada
Member#: 51942
Great work. HOpe you have it up sooner than later
D
c2scanada is offline   Reply With Quote
Old 12-28-2011, 11:08 PM   #1108
Serkan
Member#: 180514
2004 Sti
Good luck Tom ! I hope 2012 will be the year for you
Serkan is offline   Reply With Quote
Old 12-28-2011, 11:43 PM   #1109
dexterous
Member#: 23553
2014 WRX - Daily
Thanks guys, I really appreciate it!
Old 12-28-2011, 11:45 PM   #1110
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
We all know you deserve it mate
Old 12-29-2011, 08:07 PM   #1111
dexterous
Member#: 23553
2014 WRX - Daily
Today was the most productive day yet. I managed to complete a ton of stuff (with Abby's help of course).
Abby likes to hold the smashed piston from the first motor while I work. I cant believe how old she looks in this pict! BTW, if you're wondering, that doll just got home from a date with Chris Brown.
I finally got my EGT probe installed in my JDM manifold. I had intended to do this sometime this winter but I never knew that I would be replacing the whole damn motor at the same time. This involved removing the drivers side heat shield which is welded on, drilling a hole in both the shield and the pipe and putting it all back together. I think it turned out pretty good:
My TGV gaskets arrived in the mail today so I bolted the intake manifold back on. It took me almost an hour to get all the metal fragments out of it from when the old motor blew. It looked like somebody put a hand full of scrap metal in it!
As I mentioned a few posts back, I bumped up the EWG springs up two steps. I am now running a 21.5PSI spring which I suspect will net me 18PSI.
Old 12-29-2011, 08:08 PM   #1112
dexterous
Member#: 23553
2014 WRX - Daily
Many people have asked about my Moore Performance Turbo kit. Here's the up-pipe extender known as "the adapter" that allows any stock location twin scroll JDM header to be used with a variety of rotated turbos. Twin TiAL wastegates and ceramic coating for the win!
Like all my EWG setups, I always run a pair of SuperTrap exhaust silencers. These things make an amazing difference when you are married, have a kid, live in a quiet neighborhood and otherwise need to pretend you are an adult from time to time.
Those who know me know how I covet my full set of $nap-on Torque wrenches. They are worth every penny!
Here's another shot just for good measure
Here's the oil cooler thermostat sandwich adapter that caused all the drama a few pages ago.
Since I dont run the factory oil heat exchanger I put this hose here. I know I could block off all those barbs but I have always used a hose between them.
A block heater makes things really nice if for those super cold start-ups.
Old 12-29-2011, 08:40 PM   #1113
dexterous
Member#: 23553
2014 WRX - Daily
In addition to everything else that's been going on with my car I have been fighting a silent war with boost control for nearly three years. Yes, I know reinventing the wheel is not exactly required to keep boost pressure under wraps these days but for whatever reason this has been a total thorn in my side. The story starts back in the spring of 2008 when I was running a Blouch Dom 3 turbo on my stock motor. I was on my way home from getting tuned at Agile Automotive in Baltimore MD (a really great shop BTW) and at first everything seemed great with the tune. Unfortunately, by the time I hit the mountains in south central PA I started having boost control issues at WOT. In 1st-3rd gear everything worked just fine but boost was wobbly 4th gear and a total mess in 5th and 6th.
At the time, I was running the factory ECU with a COBB AccessPORT and a GM boost control solenoid. Hill (the tuner/owner at Agile) told me during that day’s tune that I should be looking for an aftermarket boost management solution because the car was somewhat difficult to tune using my setup. To fix the situation I decided to purchase an Apexi AVC-R since I had prior experience with one on a friend's car. This allowed me to tune the boost pretty well but there were issues. Since the AVC-R has no temp compensation, the car would make significantly different amounts of boost depending on the weather. As time when on this became super annoying because I was constantly making boost corrections every time I drove the car.
The following year (2009) I decided to try meth injection out so I moved to a Hydra ECU and installed a Hydramist meth kit. I also decided to move to the Hydra's internal boost control solution because of the frustrations with the AVC-R. The number one thing that swayed me to make this decision was the Hydra's ability to trim the solenoid duty cycle based on ambient temp which I thought would make all the difference in the world. Unfortunately, the Hydra 2.6's boost control ability is even WORSE than the factory ECU. The Hydra has tons more tuning capability than the factory ECU but not even Phil could get my boost situation ironed out. At Phil’s suggestion I re-installed my AVC-R, tuned the boost myself and ran the car like that for the rest of 2009 and some of 2010. Unfortunately, I would still find myself messing with the boost settings just about every time I drive the car due to the rather significant temp swings in the Northeast US (the temp can vary 30F in a day here).
In mid 2010 I tried the hybrid boost control method out to see if that would at least cap my boost at an acceptable level on cold days. While it technically worked, my experience running the hybrid setup with a Hallman pro RX and the AVC-R was pretty frustrating. The MBC would do its job just fine and prevent max boost form exceeding my desired levels BUT no matter what I did I could not prevent the AVC-R from slowing down the boost response.
After some more messing around I decided to cut the AVC-R out of the mix again and run a pure manual setup. The issue with running a manual boost controller was my meth kit. If a meth failure occurs the Hydra must have some automatic method of reducing boost. My solution was to buy a special MAC valve that's capable of being energized for long period. I used the valve to change between directing full boost pressure to the EWGs (spring pressure only) and directing pressure through my Hallman RX MBC. I also installed the remote control knob so that I could make boost adjustments form inside the car. A bit of brief testing showed that the setup had potential but it just left to much on the table.
At the strong suggestion of Phil and several others I decided to just move to an eBoost2 and ditch the custom and overly complicated boost setup that I had been running. I was surprised how easy the eBoost2 was to setup especially after hearing so many people complain. I obviously haven't used it yet but I am confident that it will be a significant improvement over what I have been running.
Old 12-29-2011, 09:04 PM   #1114
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
I love those silencers, great idea. I applaud your effort and commitment. Best of luck.
Tom
Thomas Ruble is offline   Reply With Quote
Old 12-29-2011, 09:54 PM   #1115
dexterous
Member#: 23553
2014 WRX - Daily
Thanks!
Old 12-29-2011, 09:57 PM   #1116
dexterous
Member#: 23553
2014 WRX - Daily
I decided to mock the turbo kit up so that I could re-route a few lines and hoses. I guess the benefit of getting to do this twice is that I get a chance to leverage my hindsight. There are a number of little things that I wanted to redo and now I have an opportunity to get it all perfect.
Here are a few more Moore Performance rotated kit pictures. This thing is like a work of art!
Old 12-29-2011, 11:59 PM   #1117
reid-o
Member#: 103631
2004 STI
So you switched headers as well? Sorry I didn't read the whole thread--just bits and pieces.
I'm glad it's all coming together.
reid-o is offline   Reply With Quote
Old 12-30-2011, 07:05 AM   #1118
buddsautoparts.com
Member#: 263591
2004 being rebuilt
good question!
Looks great as always Tom. You show us a picture of your Eb2 but make no mention of it. So whats the plan with that puppy?
buddsautoparts.com is offline   Reply With Quote
Old 12-30-2011, 07:42 AM   #1119
jockeygolfs
Member#: 260868
2011 STI
Tom
Ah, that is what those are. Do they hinder the flow of the ewg? That seems to be a great solution to the ridiculous noise ewg's make.
jockeygolfs is offline   Reply With Quote
Old 12-30-2011, 11:54 AM   #1120
slowgenius
Member#: 48350
WRX 03/04/07 hybrid
Thats what i was thinking, so i did re-read the thread, and at some point Tom went with an adapter from Moore Performance that bolts onto a factory jdm twinscroll exhaust manifold.
slowgenius is offline   Reply With Quote
Old 12-30-2011, 01:30 PM   #1121
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Originally Posted by Crystal_Imprezav View Post
Don't forget it also depends on where your pulling each reading from. Assuming your EWG is pulling pressure from a fitting on the turbo compressor and your MAP/Gauges are likely in the intake manifold/throttle, a 1-2psi pressure drop could easily happen with any leaks or inefficient IC/piping, BOV's, and etc...
Maybe I'm not thinking this through completely, but couldn't the EWG boost source be pulled from the manifold, so the EWG always matches the MAP/Gauges?
KillerBMotorsport is online now   Reply With Quote
Old 12-30-2011, 01:43 PM   #1122
SurfGuruJeff
Member#: 148974
2010 STi Hatch
I just had a Supertrapp welded onto my P&L EWG dump tube, too. Looking forward to having the benefits of dump-to-atmosphere but a lot less of the sound. Rerouting can cause boost fluctuations including creep.
^^^ removing the discs or adding more let's you fine tune the flow and sound of the EWG. Add more discs to add more flow and make it louder; take away discs to restrict flow and quiet it down, too.
dex, it looks like you have all 12 discs installed in each supertrapp... pull some discs out, make it even more quiet!
SurfGuruJeff is offline   Reply With Quote
Old 12-30-2011, 01:48 PM   #1123
SurfGuruJeff
Member#: 148974
2010 STi Hatch
6 discs installed;
Old 12-30-2011, 03:57 PM   #1124
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
lol tell me about hydra, that **** was the worst ecu ever made,
i cant believe people still using it,
Bariga is offline   Reply With Quote
Old 12-30-2011, 06:16 PM   #1125
dexterous
Member#: 23553
2014 WRX - Daily
LOL, the end of my post got cut off somehow. I will edit it.
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco SCIC Private Classifieds 11 10-22-2010 01:09 AM
Picture of my new Ultimate Racing twin scroll kit blowbyu24 Member's Car Gallery 682 08-24-2010 08:12 AM
VF37 Twin Scroll Turbo and New Tomei Twin Scroll headers/Up pipe arco Engine/Power/Exhaust 9 10-02-2009 01:04 PM
FS VA: JDM manifold, Twin Scroll kit, JDM Genome and more quadzilla Engine/Power/Exhaust 38 09-18-2008 10:22 PM
Pros and cons of twin-scroll turbo! Carisma Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 59 07-04-2005 05:06 PM
