Old 10-23-2010, 04:54 PM   #1
aznjoker604
Member#: 165087
Default 2008 sti motor into 1998 2.5rs parts inquiry
Theres a wrecked, 2008 sti that is parting out, and would like to know what parts I would need to make it possible to work with my vehicle. If its even possible. Thanks.
1998 2.5rs currently running ej22t with ej20k heads with 6speed tranny.
Only reason why im changing my motor is for emissions. I require obdII readings to pass emissions. Any other advice would be nice too.
aznjoker604 is offline   Reply With Quote
Old 10-23-2010, 07:18 PM   #2
AWD P & A
Member#: 255962
1999 2.5RS 2.35L
Black Diamond Pearl
engine, ECU, and wiring harness...you should have everything else needed for the swap
AWD P & A is offline   Reply With Quote
Old 10-23-2010, 08:49 PM   #3
aznjoker604
Member#: 165087
Would i need the gas peddle since its throttle by wire? Also do 2008 ecu's have immobilizer's? Are the keys chipped? Also the intercooler, would the 2008 intercooler have fitment issues because of the hood? Im trying to be cost efficient before purchasing everything that i need. Thanks.
Old 10-23-2010, 09:00 PM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the biggest issue is the rear hubs ...
with the 08+ you really need a complete swap due to the can bus
the ecu get gets the vss from an average of the abs sensors
so you need the correct signal from the rear hubs ...
the only successful swap i have seen with an 08+ sti is into an 09+ forester
Old 10-24-2010, 12:47 PM   #5
DCCDPro
Member#: 227549
^^^I've solved the problem of the missing VSS signal with my new VSSPro product. It goes between an abs sensor and the ecu and generates the correct VSS pulse. The VSSPro was actually just released on friday.
You can now swap any year tranny into the 2007 and older chassis!
-Jeff
DCCDPro is offline   Reply With Quote
Old 10-24-2010, 06:19 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
cool product but it won't help with an 08+ ecu
the abs module needs the signals which it then passes across the can bus to the ecu
whats needed is a 2 channel signal processor that will produce 08+ waveforms from an older abs signal (05-07 sti rear hubs?).. although there is no published evidence on this...
Old 02-24-2012, 08:06 PM   #7
OneManArmy
Member#: 36154
2004 WRX Wagon
anyone having success with these swaps yet?
I tried to ask a similar question and my post was locked. So lets try here.
There has to be someone that has put a 2008 and up swap into and older subaru.
OneManArmy is offline   Reply With Quote
2008 sti longblock into 1998 impreza R.S. aznjoker604 Pre-2002 Factory Turbo Powertrain 3 09-28-2010 10:32 PM
FS: Complete Part Out- APEXI AVC-R, TEC3R, Semi Built Motor, FMIC, Misc 2.5RS Parts PSI87 Engine/Power/Exhaust 77 01-24-2007 02:27 PM
can anyone here wire a wrx motor into a 2.5rs? sc00bywagon Private 'Wanted' Classifieds 0 05-02-2005 10:45 PM
USDM STi Motor into 2000 2.5RS 2000 RSTi Subaru Conversions 29 04-12-2005 02:53 PM
1998 2.5rs parts for sale enyce4u Private 'For Sale' Classifieds 16 07-26-2003 08:00 PM
