Old 10-23-2010, 09:41 PM   #1
Tomk4
Member#: 261833
Default Winter wheels that work with 2011 Wrx wagon?
I'm helping a friend find a set of winter wheels for his 2011 Wrx wagon. I would really like to find a used set of winter wheels, if not a wheel/tire combo, at-least a used set of wheels.
After searching it looks like the OEM 16 inch wrx wheels will work, what other wheels can I look for? I think OEM would be best as I would know I'm getting a quality wheel. But what size and offset should I be looking for 16+ inch wheels with a +45-+48 offset?
Thanks!
Tom
Tomk4 is offline   Reply With Quote
Old 10-24-2010, 02:54 AM   #2
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
ive seen some oem 02 wrx wheels on a 2011, the specs on those are 16x6.5 55offset
so assuming that's the limit, anything larger in diameter, wider (to a certain point of course) and more aggressive offset (to a certain point) should work. i personally would look into maybe some 2010 wrx wheels they would look ok and there a pretty good size for winter.
jdmboy is offline   Reply With Quote
Old 10-24-2010, 03:10 AM   #3
BLkdubRX
Member#: 229971
2009 WRX
w/ SF hotbox
Check The Tire Rack for wheels and fitment. then see if you can find those wheels used.... that's what I'd do.
BLkdubRX is offline   Reply With Quote
Old 10-24-2010, 01:54 PM   #4
Tomk4
Member#: 261833
Only problem is tire rack says 16's won't work, but people on this forum are running Oem 16's with no problems.
Old 10-24-2010, 03:28 PM   #5
Robin2
Member#: 390
2011 WRX sedan
Plasma Blue
got mounted set hankook ipikes on 02-03wrx wheels but canadian cars don't have tpms...
Robin2 is offline   Reply With Quote
Winter Tires... that work in summer. or vice versa mrschmoley Tire & Wheel 34 08-26-2009 09:30 PM
What's the most that you've towed with your WRX Wagon/Sedan? 24 General Community 21 08-30-2006 03:52 PM
LATE: Winter wheels that fit FHI 4pots (16x6?) psyber_0ptix Tire & Wheel 0 02-21-2006 09:59 AM
Want Front bumper that works with 2004 WRX/STi and USDM bumper beam JoeCool Interior & Exterior Modification 8 12-04-2004 01:38 AM
WTB: cheap winter wheels that will fit over brembos (STI) sweetsuby Private 'Wanted' Classifieds 5 10-23-2003 11:51 PM
