Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 06-28-2002, 06:20 PM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Cheap, easy, reversable Cold Air Intake mod :)
So Ive been running my legacy this way for a while and Im happy.
Bypass the coolant hose that "prevents ice from forming on the throttle plate." (subarus words).
The normal flow is from the outlet on the coolant, through the IAC then through the throttle body and back into the cooling system if I remember right. I just bought a peice of metal fuel line from kragen and cut it to the right length so it was easy to replace if it didnt work.
Check it out. Very easy cheap and I KNOW it must make a difference. I guess I could do some sort of write up on this, but its so damn easy you should know what I mean!
If you have trouble, look on the housing that holds the throttle plate (peice between gasket on runners and the plastic intake hose). On the bottom left and right side there are small heater hose's connected to 3/8 inch brass fittings. Get a peice of metal pipe say 5 inches long to take the place of the throttle body. So now instead of the hoses running through the throttle they go around.
Im pretty sure the paper gasket works as a decent heat sheild from the engine so this is one less source of heat for the air, especially since it is heating the throttle plate which has a decent surface area.
Edit: Oh and I havent had any Ice form yet
Old 06-28-2002, 09:10 PM   #2
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I'm sure it makes a difference, but I doubt it's anything anybody would ever notice by the ol' seat of the pants dyno. This is a pretty popular "modification" with the 5.0L Mustang crowd (which has the exact same type of setup), but chassis dyno results show essentially zero gain.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 06-28-2002, 09:27 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
I just realized, I left something out!
The reason I first thought of this mod was when I had a small leak in one of those hoses. I replaced it with standard heater hose (not the special subaru bent type)
So to make this mod EASIER, use ONE piece of 5/16 hose that is about 12-13 inches long.
I just went to pep boys to replace mine with this, only 80cents Cheaper than getting a metal line. Id also suggest some real hose clamps but thats up to you.
FS: MI - CHEAP Short Ram/Cold Air Intake 20BlueWRX02 Engine/Power/Exhaust 6 09-30-2008 11:33 PM
02' cold air intake mod. Jrad_150 Interior & Exterior Modification 4 04-18-2007 01:10 AM
Home Depot cold air intake mod semaj Vancouver Impreza Club Forum -- VIC 94 09-04-2006 02:29 AM
Cold Air Intake Mod Ooter Vancouver Impreza Club Forum -- VIC 27 07-01-2002 03:44 AM
AEM cold air intake or Injen cold air intake? energy57 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 31 05-20-2002 12:27 AM
