Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-24-2010, 12:08 AM   #1
choleaoum
Member#: 255484
2010 EVO
Default Poor throttle response..
Hey how's it going, I got my car running and I borrowed a fellow nasioc member's catted downpipe with o2 sensors. (My previous car didn't have any) Well, long story short I changed the TGV Valve Gaskets and intake manifold gaskets and such to clean up the car a bit because the previous owner used nasty gasket sealer everywhere.
And now everytime I step no the throttle at first it struggles just a bit but when I get into high RPM's it's fine. It idles nicely too but the engine shakes a bit violently, would this be caused by the breather hoses not tightened in all the way? I haven't had a chance to run to autozone and buy new hoses yet. Just want to know what could cause this problem after removing the manifold.
I tightened the blow off valve hose, I noticed that was my problem first, everything else is tighten and hoses are clamped down nicely. The only thing that are not plugged up are the coolant lines of the throttle body. I'm throwing only a CEL for TGV but it hasn't put me in limp mode either.
Any suggestions or ideas?
choleaoum is offline   Reply With Quote
Old 10-24-2010, 01:10 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
you gon have to recheck all the hoses and clamps. Make sure they are not leaking. Also check the EVAP Purge solenoid. The fittings MAY have broken.
FuJi K is offline   Reply With Quote
Old 10-24-2010, 01:47 AM   #3
blakeM.U.R.T
Member#: 208575
2004 wrx
whats a evap?
blakeM.U.R.T is offline   Reply With Quote
poor throttle response sonycrr Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-02-2008 08:22 PM
Poor boost response question rsr14 Engine Management & Tuning 5 02-06-2006 12:51 PM
poor throttle response dokswon Service & Maintenance 1 11-14-2003 07:50 AM
Throttle response Dave99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-01-2001 09:01 PM
Crisper throttle response? OBSS Normally Aspirated Powertrain 10 04-04-2001 11:21 AM
