Welcome to the North American Subaru Impreza Owners Club Thursday September 1, 2016
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Engine/Power/Exhaust
Old 10-25-2010, 08:16 AM   #1
Ryan23
Member Sales Rating: (25)
Member#: 15116
2000 Ver6 STi Type-R
EJ257/GT35R
Default JDM STi Ver 7 EJ207 Intake Manifold/TGV deletes
Hey Guys -
I'm going a slightly different route with the intake for my EJ257 build. So up for grabs is my JDM intake + factory TGV deletes. It's in good shape with only a couple minor scratches, as shown. Looking for $250 + shipping. I can also include a throttle body (with all sensors) for extra, if you need one. Shipping time is 5-7 days to the West Coast and 7-10 days to the East Coast. Thanks!
Ryan
Ryan23 is offline   Reply With Quote
Old 10-27-2010, 12:31 AM   #2
Ryan23
Member#: 15116
EJ257/GT35R
~Bump~
Old 10-30-2010, 09:32 AM   #3
Ryan23
Member#: 15116
EJ257/GT35R
~Bump~ Shipping is cheap to the West Coast!
Old 10-30-2010, 09:40 AM   #4
Jubert39
Member Sales Rating: (55)
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
might be a stupid question, but is this direct plug in play on hybrid setup? ej257sb+ej205 heads?
or will i start throwing codes?
Jubert39 is offline   Reply With Quote
Old 10-30-2010, 09:53 AM   #5
Ryan23
Member#: 15116
EJ257/GT35R
Not a stupid question. Yes, it would be a direct bolt in because your 205 is drive by cable and this manifold is set up for drive by cable (notice the IAC slit above the throttle body inlet). As far as throwing codes, I'm not sure if your ECU would throw a code due to lack of TGVs or not. I would think there is an easy fix for this as most people are deleting TGV's. These already come with TGVs deleted.
Ryan
Old 10-30-2010, 09:58 AM   #6
brew02wrx
Member Sales Rating: (13)
Member#: 259970
2002 wrx cobb stg2+
psm proper fitment
i'll put it this way i test drove a wrx that had a hybrid setup exactly the same as this, sti im on top of a wrx block, didn't work out too well.....the car was throwing codes and after about 3 minutes into the drive would stall out and would start back up under a smokescreen
brew02wrx is offline   Reply With Quote
Old 10-30-2010, 10:18 AM   #7
Ryan23
Member#: 15116
EJ257/GT35R
Well, perhaps the car you "test drove" was a POS and had other underlying issues?
Was he using 550cc STi injectors with a WRX ecu setup for 440's?
Was his manifold torqued down correctly?
Did he bother to use gaskets?
Did he have a stuck injector?
There are plenty of people running STi manifolds and TGV deletes on this forum. To the original poster who asked the question...
Search TGV deletes and codes under the forum and see what you come up with.
Ryan
Old 10-30-2010, 10:30 AM   #8
Ryan23
Member#: 15116
EJ257/GT35R
To satisfy my own curiosity (we don't have TGVs in Japan):
The TGV FAQ:
http://forums.nasioc.com/forums/show...v+delete+codes
Do TGV Deletes cause a CEL? Yes. By removing the TGV motors, it will throw quite a few CELs. The bad news with this, is the TGV CELs will throw your car into limp mode, meaning unlike some other CELs that you can still drive around with and have no fear, the TGV codes limit boost/RPM operation meaning they must be taken care of in order to drive your car for any reasonable distance.
How do I fix the TGV CEL? You have three methods:
1. Normally, you remove the TGV motors and the rod that holds the butterfly valves in place. You could leave the rod in place (sans butterfly valves) and reinstall the TGV motors. This would allow them to actuate normally making the system think everything is working correctly.
2. APS makes a block that you attach the TGV motors to, this allows them to actuate normally making the system think everything is working correctly. These are not sold separately though, but can occasionally be purchased in the Private For Sale Forum or on eBay.
3. Various engine management systems can remove the associated CELs.
But "Suicidal Eggroll" says No...
Originally Posted by the suicidal eggroll
TGV CELs won't put you in limp mode.
As long as your current CEL is in fact TGV related, it can be turned off with the rest of them with the AP.
He's usually on point...
Ryan
Old 11-01-2010, 07:26 PM   #9
Ryan23
Member#: 15116
EJ257/GT35R
~Bump~
Old 11-01-2010, 08:12 PM   #10
wrxBRAH
Member Sales Rating: (5)
Member#: 256841
2004 FXT
Another dumb question (yay). Are the JDM tgvs also pnpd or do they just come with the deletes from the factory and thats it?
What about the JDM manifold. How is it anymore special than its USDM counterpart?
wrxBRAH is offline   Reply With Quote
Old 11-01-2010, 08:36 PM   #11
bdj238
Member Sales Rating: (17)
Member#: 207561
2005 WRB WRX WAGON
PPG Trans
so let me get this right, this does have the bracket for a drive by cable application. I'm driving a 05 WRX and may be interested. Also are these topfeed?
bdj238 is offline   Reply With Quote
Old 11-01-2010, 09:51 PM   #12
Ryan23
Member#: 15116
EJ257/GT35R
These are top feed TGV deletes. As you can see from the second picture, there is a throttle cable bracket.
For the previous poster, they are not ported. Just factory deleted. This manifold is different than the US STI because it is set up for a cable throttle with the appropriate air bypass at the throttle body inlet (see the first picture).
Thanks,
Ryan
Old 11-02-2010, 01:27 AM   #13
OrbitalEllipses
Member Sales Rating: (19)
Member#: 178811
2011 White Corolla
Over 400hp
It's a red WRX manifold with JDM TGV deletes. That's reductive, but there's no difference in 02-05 WRX manifold and that manifold that I can plainly see; in addition I own a V8 one piece to compare it to as well which is a long-runner manifold WITHOUT TGVs.
The expensive/nice pieces are the TGVs, the manifold is nothing special.
Not trying to **** on your thread, just trying to clear up some misconceptions I saw in the thread. I apologize if I come off as ****ting on your thread.
OrbitalEllipses is online now   Reply With Quote
Old 11-02-2010, 03:37 AM   #14
Ryan23
Member#: 15116
EJ257/GT35R
Thanks for thread-crapping with your "public service announcement". Regardless of what you "plainly see", it's advertised as exactly for what it is.... an EJ207 manifold off a Version 8 STi.
The "long runner" manifold, as you mistakenly put it, is the same length as this one. It's just cast as one piece to the same length as this one with TGV deletes. That is a Spec C intake. NOWHERE in my ad did I say this was a Spec C intake. FYI, not all Version 8s are Spec C
If you have no interest in purchasing, than don't bother posting. Follow the rules or we can get a mod to advise you.
Ryan
Old 11-04-2010, 03:23 AM   #15
Ryan23
Member#: 15116
EJ257/GT35R
~Still available!~
Old 11-04-2010, 04:52 PM   #16
OrbitalEllipses
Member#: 178811
2011 White Corolla
Over 400hp
Title states Version 7.
The "long runner" manifold, as I mistakenly put it, is the same length as your assembled manifold; I referred to it because the runners on the actual manifold are indeed longer than the ones actual manifold less the two TGV portions. I stated that there was no difference between that manifold and the USDM 02-05 WRX manifold. Which is true. The top halves are IDENTICAL. The difference lay in the separate TGV section; the top half isn't anything special. Sure it's from an EJ207 STI and JDM-awesome.
Ryan
My intent was to clear up anything that your potential buyers were asking. Obviously you know more since you're in JDM-awesome-land and your member number is lower, meaning I should shut up. I'll try not to be as polite next time.
Old 11-06-2010, 08:21 PM   #17
saabaru_aero
Member#: 238937
05 Saab 9-2x
black
still an awesome deal even if the jdm intake manifold is the same as the us version. the jdm deletes cost 210 dollars by themselves plus powder coating the manifold is about 100 bucks i really want to buy this but i just bought a ported exhaust manifold maybe ill get enough money before its sold
saabaru_aero is offline   Reply With Quote
Old 11-18-2010, 03:13 AM   #18
Wunder
Member Sales Rating: (3)
Member#: 260232
2005 FXT
Wunder is offline   Reply With Quote
Old 11-18-2010, 05:08 PM   #19
teesutt
Member Sales Rating: (18)
Member#: 127940
Evil shenanigans
Would those TGV's work with a USDM sti intake manifold?
I am converting my sti from side feed to top feed and need top feed tgv's but keeping DBW.
If so, i will take the whole setup.
teesutt is offline   Reply With Quote
FS : HOU: STI ver 7 EJ207 and other WRX parts! Bolster TXIC Private Classifieds 21 11-10-2010 10:35 PM
FS NYC: STi Ver. 7 EJ207 and 8 sets of wheels/tires + tons more! garface Tri-State Area Private Classifieds 26 11-11-2009 12:17 PM
JDM STI Version 7 complete intake manifold with STI pinks, TGV deletes... apexwrx Engine/Power/Exhaust 2 03-05-2009 05:45 PM
Ver 7 intake manifold TGV deletes Pinks car_cursed RMIC Private Classifieds 0 04-13-2006 11:12 AM
Aluminum Control Arms from JDM STi Ver 7 SSLegacyGT Brakes, Steering & Suspension 2 12-30-2003 01:13 PM
