Old 10-25-2010, 12:08 PM   #1
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
So I've got a hybrid that is idling like crap. Spark plugs 2 and 4 look rich, but 1 and 3 look lean. I would think a blown head gasket on the 2/4 side, but compression is really good. No codes, but misfire codes are remmed out in open source. Already replaced plugs, MAF, O2, turbo inlet, FPR, Crank and cam position sensors, blah, blah. On-boost power is great. Have WBO2 and it looks good. Stock O2 jumps from 12 to 16 afr at idle. Looks good at cruise. Timing jumps from 9 to 15 at idle. Good at cruise. Any ideas, crew?
Zackbo is offline   Reply With Quote
Old 10-25-2010, 12:18 PM   #2
DSM_Outback
Member#: 56345
93 Swapped L
Green
T belt right?
DSM_Outback is offline   Reply With Quote
Old 10-25-2010, 12:19 PM   #3
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
Checked timing; marks looked dead on.
Old 10-26-2010, 07:48 AM   #4
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
keepin' it fresh
Old 10-26-2010, 01:03 PM   #5
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
leakdown. Perhaps some valve problems.
Old 10-27-2010, 12:51 PM   #6
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
I've heard that valve problems will show up on a vacuum gauge. I've got a good vacuum gauge, and I'm not seeing any needle fluctuation, but I guess a leakdown test is next anyway.
Old 10-28-2010, 07:34 PM   #7
Zackbo
Member#: 43151
04 STI
Kinda Silver-ish
RANT: So I'm really big on updating your thread when the solution is found. Too many threads on here don't get concluded....... : end RANT
Afer dozens of hours of troubleshooting and $500 worth of sensors, my car is purring again.
Solution:
A $10 can of Seafoam in the tank.
Guess it was a clogged injector.
I've been working on cars for 20 years, and I would swear that you can't fix a car by pouring a quick-fix into the gas tank; I guess we're always learning
TGV DELETES:Motor on one side whats on the other stretchedk7 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-29-2008 12:26 AM
What mattress will stay stable on one side if somebody jumps on the other side? Cjchaps Off-Topic 12 01-21-2004 06:00 PM
BBS golds on one side and BBS silver on the other SinhCredible Interior & Exterior Modification 26 10-20-2003 09:08 PM
red thick blood like subastance on one side of my battery.. BUDLoNG Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-07-2003 07:15 PM
HID yellowish on one side viodea Interior & Exterior Modification 0 03-11-2002 06:50 PM
