Welcome to the North American Subaru Impreza Owners Club Monday October 24, 2016
Old 10-25-2010, 06:38 PM   #1
Member#: 143346
03 wrx 285 whp
Default crank rod journal size question
Soooooo, I tore down a ej20 block I plan on re building and im at the point where Im measuring everything 10 times. My rod journals all measure between 51.981 and 51.983. Acceptable tolerances are 51.983 and 51.988. Should I just buy a new crank? Could I just buy thicker bearings? What is the acceptable tolerances or lee way if any? Any info is appriciated.
gleesamo is offline   Reply With Quote
20h rod journal size rs182 Pre-2002 Factory Turbo Powertrain 13 09-29-2015 02:18 PM
WTB : Bearings EJ25 STANDARD 52mm Rod Journal Size with Thrust in #5 Position xANDRESx Private 'Wanted' Classifieds 1 07-03-2010 01:30 AM
48/52mm journal size and stroking question bugeyes Built Motor Discussion 14 06-26-2006 03:41 AM
Grinding the rod journal Starkiller Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 12-06-2005 09:32 PM
What's the diameter of the rod journals? jasona Normally Aspirated Powertrain 1 10-24-2005 02:04 PM
