Old 10-25-2010, 10:23 PM   #1
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
Default Best way to store an Engine
So I am going to be buying a 2.0L short block with a spun bearing for next to nothing. However with being in college I am A) Broke, and B) Limited on space/tools. We live in a half house so I have an unfinished basement and room in the apartment. I want to get an engine mount but still don't know what precautions I should take to the block to keep it from rusting or any other damage that could occur.
This is just a winter project so I can learn more about the workings of a motor, so it will be worked on all winter.
Thanks!
subaru_steve is offline   Reply With Quote
Old 10-25-2010, 10:38 PM   #2
Ds baruuuuu
Member#: 4724
01 01RS
brp
i went to costco and bought some saran wrap (sp?) for misc parts and for an entire long block i tape up all the holes TB,Coolant openings turbo and then put a large trash bag over it on my engine stand
Ds baruuuuu is offline   Reply With Quote
Old 10-26-2010, 04:23 AM   #3
alcoolaid
Member#: 134949
'07 SWP STi
Twinscroll ViPec Anti-lag
Just put it on an engine stand and tape up all the holes
alcoolaid is offline   Reply With Quote
Old 10-26-2010, 08:17 AM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
and oil the iron cylinder walls so they don't rust up
Old 10-26-2010, 04:25 PM   #5
Nappula
Member#: 260249
Use anti corrosion spray (for example afc-50) or spray some oil on your parts. Tape, wraps and bags wont do the trick. In fact if room temperature changes, wrapping the block will only make things worse.
Before oiling or spraying make sure your parts are clean and dry.
Nappula is offline   Reply With Quote
Old 10-26-2010, 04:51 PM   #6
Krang
Member#: 134272
Chapter/Region: HIIC
2002 WRX Wagon - WRB
ej207 v8 vf37
In Hawaii we have an abundance of salt in the air ( as you could imagine ) so covering anything susceptible to corrosion is #1 priority. Also, our huge temperature swings ( between 78 and 82 degrees ) don't really cause much in the way of condensation.
Krang is offline   Reply With Quote
What is the best way to store your wheels/tires for the winter? Bankie Tire & Wheel 3 11-13-2005 10:30 PM
Best way to store an almost new tire? silvercharged Tire & Wheel 7 07-05-2005 06:30 AM
Best way to store tires for winter is. . . skiteton Tire & Wheel 17 11-30-2004 09:48 AM
best way to pickup an engine? phatroksek Tri-State Area Forum 17 01-05-2004 05:41 PM
Best way to clean an engine? wcbjr Factory 2.0L Turbo Powertrain 6 08-31-2003 10:41 PM
Message Board Statistics All times are GMT -4. The time now is 04:35 PM.
