Old 10-25-2010, 11:28 PM   #1
nes
Member#: 258299
2009 wrx
blue
Default how would you build it?
hi guys, fairly new to the site (love it so far), i own a 2009 wrx which recently spun a rod bearing. i decided to go ahead and start a tear down of the engine and believe its time to go ahead and build it stronger. i have A budget, but its fairly reasonable, and have been able to find a couple spare blocks for a good price. my current thoughts are
ej257 bare block
new sti nitrided crank
eagle rods or sti rods as i hear they are forged and are good for some decent power
cp pistons(standard bore, 8.2 or 8.5 compression)
acl race bearings
new oil pump and water pump
new oem gasket kit
arp head studs
anything you guys would reccommend? my goals are 400-450 whp on pump sometime in the future, and while the engine is out i would like to go ahead and throw on some 1000cc injectors and colder plugs.
my real question is, if you where in the situation where a build was neccessary, how would you go about doing it? reccommendations for cranks, rods, pistons, turbos, injectors, cams, everything is welcome.
thanks
nes is offline   Reply With Quote
Old 10-26-2010, 12:01 AM   #2
FuJi K
Member#: 3687
MY99 GF4 JDM 6spd
NF Performance
your whp goal is a bit for pump. That means you have to run a fairly large frame turbo. I would prefer running the turbo at near it's max and making like 20whp more than target power. This way the turbo isn't too large and gives you a better power band.
It's like pushing a GT3076R to 450whp on E85 or race fuel. yes you hit your target power and also good power in the lower revs. You run a GT35R on pump to make the same power output, but the powerband and curve is going to be start climbing later.
You can do Meth injection. That's up to you.
FuJi K is offline   Reply With Quote
Old 10-26-2010, 01:09 AM   #3
69subaru360
Member#: 159682
1995 WRX
2015 F150
Your parts list looks fine. Pretty standard stuff. I'd do the aftermarket rods. I don't think your 09 has a factory oil cooler, but if it does replace it after a spun bearing.
Old 10-27-2010, 12:33 AM   #4
binjoau
Member#: 259948
MPS 510 whp GTX35R
Long Rod Motor
no factory oil cooler, just doing my 09 wrx build atm
binjoau is offline   Reply With Quote
$6K to Spend. How would you do it??? slim9300 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 11-01-2007 11:38 PM
If OT had to rob a bank, How would you do it? sebtarta Off-Topic 102 09-14-2007 12:08 PM
250whp and the lowest spool point possible: How would you do it? grue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 97 01-22-2005 11:39 AM
Ultimate Autocross Impreza (How would you build it?) JJTheSubeDriver Motorsports 22 07-02-2001 04:53 AM
