Old 10-26-2010, 12:53 PM   #1
BlaKKStaRR
Member#: 133325
2007 WRX TR
Default OCV Solenoid/AVCS Woes.. ECU???
Hey guys, I've had this issue for a good while now,
But I had a new motor installed in my car from a reputable guy, long story short, my passenger side OCV Solenoid is acting REALLY funky.
My passenger side OCV is NOT functioning. I even logged on on RomRaider and yep, Right side OCV sits at 0 mA
I've tried finding out what the issue is and I've narrowed it down to this.... when the vehicle is RUNNING.. there is POWER, but no ground. When the vehicle is OFF.. there is GROUND
Yes I've changed it out with other ones, the problem is still there
Yes I've checked continuity of both wires from connector to harness and its good
Is there a ground side control within the ECU for this?
There was NEVER a point where it had both Ground AND Power.
BlaKKStaRR is offline   Reply With Quote
Old 11-01-2010, 03:49 AM   #2
BlaKKStaRR
Member#: 133325
2007 WRX TR
anyone?
Old 11-01-2010, 07:54 AM   #3
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
Each solenoid is grounded via the ECU. Could be a problem there... not sure.
alcoolaid is offline   Reply With Quote
Old 11-24-2010, 03:14 AM   #4
BlaKKStaRR
Member#: 133325
2007 WRX TR
bump?
Old 11-24-2010, 06:48 PM   #5
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
the ground is duty cycled by the ECM. Its to fast to measure with a voltmeter you need an occiliscope to be able to measure the duty cycle.
OCV Solenoid Valve Signal A Circuit Open (Bank 2) XSUBYX Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 11-02-2014 09:07 PM
JDM AVCS solenoid vs. USDM AVCS solenoid coolcougar Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 39 11-08-2012 08:02 AM
Need wiring diagram for 04 sti ocv solenoid sti3573 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 06-03-2010 04:59 PM
04 sti ocv solenoid lennybootzz Private 'Wanted' Classifieds 1 08-09-2009 03:35 PM
Understanding AVC-R solenoid duty cycle... SilverSubie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-15-2001 07:22 PM
