#1 |
Member#: 238875
Vehicle:05 sti aspen |
so which side of the turbo would be the better side for my wideband? or is it going to make a difference? i have a bung on both sides and would like to know if anyone has an answer.
thanks
#2 |
Member#: 163361
NESIC
Vehicle:05 STI 10.22 @ 141 |
After the turbo is better. Like 8" if possible
#3 |
Member#: 112759
Vehicle:02 Srp STi... R ur Boltz to long???? |
I have mine approx 4" off, in the downpipe, never had a problem AFR's r tight !
#4 |
Member#: 238875
in my 240 my wideband is after the turbo but the manifold runner length is much shorter than the subi. i appreciate your .02
#5 |
Member#: 238875
anyone else?
#6 |
Member#: 253421
Vehicle:03 WRX 325whp Sonic Yellow |
My AEM ugeo says bungs should be welded at a 10 degrees incline from horizontal position of the pipe to keep moisture contact away. I think its around 36" from the headers or 16" post turbo(around/before the curve of the dp and way before the cat)
#7 |
Member#: 169556
AKIC
Vehicle:07' OPB STi BW S256 01' 2.5rs GM6 w/leather! |
My wideband o2 sensor was aprox 3" from the turbo outlet, after burning up 2 o2 sensors in 3 months, I had another bung welded in near the oem 2nd, and I haven't had any troubles in the last few months on one sensor.
I should add that the wideband is an innovate, and when the sensors died they flashed the error code of "sensor to hot" |
#8 |
Member#: 140444
NWIC
Vehicle:05 Stage Free LGT ATP 3076, 6MT, AVO FMIC |
Post-turbo for sure. The pressure in the up-pipe will throw off the readings otherwise.
I very much doubt that the people who advised putting the sensor 16" downstream of the turbo were thinking of Subaru's super-long pre-turbo exhaust plumbing when they came up with that guideline. Most downpipes that have bungs, have the bungs just a couple/few inches from the turbo. For every person who blew through sensors like the previous poster, there's plenty running long-lived sensors right behind the turbo. Mine's been in place for about a year now and it's still working fine. |
#9 |
Member#: 260982
36 inches is standard practice for any turbo application.
| Thread Tools | |
| Display Modes | |
| Hydra/wideband question | masiolli | Other Engine Management | 2 | 04-21-2005 11:05 AM |
| wideband question | Dissectional | Engine Management & Tuning | 4 | 12-25-2004 03:08 AM |
| Tuner wideband question. | Houdini | Engine Management & Tuning | 25 | 05-23-2004 03:08 PM |
| Different types of WideBands...question | Eric1855 | Engine Management & Tuning | 1 | 03-27-2004 03:16 PM |
| Techedge Wideband Question | WRC 555 | Engine Management & Tuning | 4 | 05-08-2003 04:06 PM |
