Old 10-26-2010, 09:21 PM   #1
Strider327
Member#: 131280
2004 Impreza WRX
Default Car sometimes does not crank/start?
I have 2.5 raw performance street series hybrid setup. The engine has been running great so far up until today. The fuel pump whined up but there was no crank! I turned it off again and tried a couple of times, then left it off for about 10 seconds and tried again then it finally crank and fired up. Is this an indication that the fuel pump is going out or something related in fuel? The starter does not appear to be dying as there was no slow crank or indication of a dying starter. Please let me know your inputs on this. Thanks.
Strider327 is offline   Reply With Quote
Old 10-26-2010, 09:32 PM   #2
Feezor
Member#: 156605
14 WRX
If you hear the fuel pump prime (2 sec. I believe when the key is on) then it probably is not that. If you keep trying to start it and it eventually turns over? Next time it is not turning over try and tap the starter with a hammer and see if that helps. If so there is your problem.
Also other things to check could be a clutch switch going bad.
Food for thought.
Let me know if that helps at all.
Feezor is offline   Reply With Quote
Old 10-26-2010, 10:25 PM   #3
Strider327
Member#: 131280
2004 Impreza WRX
Hmm okay. Yeah I definitely hear the fuel pump priming all the time. However the turn over on the starter, I don't even hear the click. Its just nothing. I will keep my eye on the starter.
Old 10-26-2010, 10:27 PM   #4
kasra007
Member#: 225361
2006 wrx sti
beige
starter is going bad? i had the same issue and had mine replaced.
kasra007 is offline   Reply With Quote
Old 10-27-2010, 12:03 AM   #5
Strider327
Member#: 131280
2004 Impreza WRX
So yours didn't even click over like mine. It would continuously prime the fuel pump and then later it would just crank like normal?
Old 10-27-2010, 11:49 AM   #6
kasra007
Member#: 225361
2006 wrx sti
beige
fuel pump worked fine..its just some times it started and some times i didnt. over time it got wrose and wrose.
Also when it doesn't work do you hear a zzzzzzzzz sound ?
Old 10-27-2010, 07:27 PM   #7
Strider327
Member#: 131280
2004 Impreza WRX
Hmmm, the zzzz sound I hear isn't that the priming of the fuel pump? I indeed do hear that, but always thought it was the fuel pump just priming itself. So it was definitely the starter huh? No more problems for you?
Old 10-28-2010, 12:33 PM   #8
kasra007
Member#: 225361
2006 wrx sti
beige
the sound is very annoying, almost sounds like as if something is grinding against something in a very high pitch noise. if thats the case just have the starter rebuilt and it will fix the issue.
the fuel is kinda like vvvvvvvvvvvvvvvvvvv but the grinding ZZZZZZZZZZZZZZZZZZZZZZZZZZ
Old 11-08-2010, 08:46 PM   #9
tbland86
Member#: 260674
have a 93 impreza AT AWD and im kinda having the same issues kinda. I get power to the dash and radio and lights. I hear the fuel pump prim when i turn the key, also i can hear the main relay click on and i can feel it click if i touch it. I pulled the starter and it bench tested good, BATT has 12v and im getting 12v going to the starter from batt and ground for starter is good. Tryed tapping the starter and nothing, Could it be a dieing batt that just donts have the CCA to turn the starter? Can i by pass the ingnition some how and jump the starter on the car and see if she cranks and runs?
tbland86 is offline   Reply With Quote
Old 12-09-2010, 07:32 PM   #10
bigvicswrx
Member#: 260692
i have a 03 wrx and recently i had nothing the fuel pump primed and when i turned the key i could hear crickets lol but it doesnt want to start in the cold and it only happened after i had the trans rebuilt i have plenty of power due to its a new gel cell batttery if i leave the key on for about a minute itll start fine im stumped if anyone has the solution please share thankks a bunch
bigvicswrx is offline   Reply With Quote
Old 12-10-2010, 09:46 AM   #11
Strider327
Member#: 131280
2004 Impreza WRX
Yeah that works for me as well. Weird how it doesn't start up immediately...
Old 12-10-2010, 09:53 AM   #12
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
ok, so you guys have the relay click...is the solenoid (on the starter) clicking?
Old 12-11-2010, 06:02 PM   #13
Strider327
Member#: 131280
2004 Impreza WRX
Nope.
Old 12-14-2010, 02:50 PM   #14
nichama70
Member#: 208435
Default 2006 wrx starting problem
I am having this same issue. I have a 2006 wrx. sometimes when I turn the key over to start the car I get nothing, no clicking, no grinding, just silence. The first thing I did was test my battery. I have a optima red top that is only about one year old and it tested good. I tested the cable that plugs into the solenoid end of the starter and had my buddy start the car all 20 times I got 12 volts on that line. I ordered and replaced the starter with a new one. After installing it I still had the same issue. After that I thought that the issue might be a loose connection to the starter solenoid, so I put some dielectric grease on the connection, but i'm still having the same problem. I've heard some suggestions that it could be a grounding problem. Also sometimes when the car does not start, if I hold the key in the start position for about 5 seconds it will turn over. When the car does turn over it fires right up with no hesitation. Any ideas?
nichama70 is offline   Reply With Quote
Old 12-14-2010, 02:53 PM   #15
nichama70
Member#: 208435
Are there other relays in the starter path? like for the clutch pedal or like a antitheft relay that could be sometimes sticking?
Old 12-28-2010, 03:38 AM   #16
Strider327
Member#: 131280
2004 Impreza WRX
Nope.
Old 12-28-2010, 08:09 AM   #17
drewvdw
Member#: 255776
2010 LR WRX
MPS powered.
Food for thought.
for gods sake, DO NOT tap the starter with a hammer! modern car starters (around 1980+) aren't like your grandpas, the magnet inside them can break and chip off when you hit them. yes, it is logical thinking, but a very bad idea unless you want to buy a new starter. do some voltage drop tests to find out if it is getting enough power, using the power, and has a resonable resistance within the wires. using this method will tell you if it is the starter or not without the possibility of damaging something
drewvdw is offline   Reply With Quote
Old 01-01-2011, 02:21 PM   #18
Feezor
Member#: 156605
14 WRX
Dude I said to tap it not hit it like.... (insert whatever you want here).... It is a tap so vibrate it a little. I do feel informed about my grandfathers car starter now though thanks
New Optima battery does not start the car? CTP Electrical & Lighting 13 11-09-2010 06:35 PM
Car does not start sometimes BuggedWrx Newbies & FAQs 26 11-09-2010 11:21 AM
Car turns over but does not start... Poolhut23 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 31 11-21-2008 05:00 PM
In-car Navigation does NOT know everything, part eleventy... Cole Off-Topic 9 10-09-2006 02:54 PM
car does not start wrxite Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 05-11-2006 10:24 PM
