Old 06-29-2002, 04:42 AM   #1
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Angry Is there a fuel pump between stock and Walbro???
There has to be some pump that flows more than stock but less than a Walbro! Anyone know of any? Supra? thanks
Eric
Eric SS is offline   Reply With Quote
Old 06-29-2002, 04:53 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
supra is a 255 lph IIRC...i am going to get in touch with aeromotive and see what their pumps will do, i know they claim 1000 HP @ 43 psi but i want to know what it will do @ 60 psi
Old 06-29-2002, 04:54 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Do you know what the Walbro flows? Thanks
Eric
Old 06-29-2002, 05:03 AM   #4
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
What about a WRX pump? I also think you can get 190 lph Walbros.
scootr is offline   Reply With Quote
Old 06-29-2002, 03:21 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
The common Walbro flows 255lph.
Why are you looking for something inbetween, out of curiousity?
Old 06-29-2002, 06:19 PM   #6
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
To get my fuel pressure down. I know that a pump that flows less than the Walbro but more than the RS will give me plenty enough fuel.
Eric
Old 06-29-2002, 08:01 PM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Eric
get the normal pressure high flow, not the high pressure high flow which everyone seems to use.
jeremy
Old 06-29-2002, 08:18 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Why don't you just use another regulator? Works for everyone else.
Old 06-29-2002, 08:27 PM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I have one. I finally bought a SVX regulator and still idle at 38psi and build to 85psi at 7# boost even with all the Cartech RRFPR screws at full lean.
Eric
Old 06-30-2002, 03:35 PM   #10
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Have you set the RRFPR right? Take off the vacuum line and make sure it is idling as low pressure as possible by turning the allen key (with the lock nut) screw... outward? Inward? Well, you'll see it. Just make sure it idles with the vacuum line off as easy as possible.
Actually, if you add it up... 1:1 rise on the normal FPR, 2:1 rise on the RRFPR... idle manifold pressure is near -9psi (guessing since you have that 2.2 with 8:1 compression). 38psi + (16psi * 3) = ~96psi. Kinda near where you're idling now... and if the RRFPR could adjust down just below 2:1, it'd be right on.
If you have that much troubles, try removing the RRFPR from the line, and see what it idles at... bet it's closer to 32psi and that the base adjustment screw is in too far.
Walbro fuel pump reusing stock wiring harness, any issues? brianha42 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 02-27-2010 09:05 AM
walbro 255 fuel pump on stock wrx? godfather2112 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 07-01-2005 02:59 AM
Is there a real difference between VF30 and VF34? Trevor723 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 07-14-2004 09:57 PM
IL: Trade Walbro 255 fuel pump for stock + lil $$ Shaitiger Mid West Subaru Owners Club Forum -- MWSOC 4 02-06-2004 05:10 PM
Is there a big difference between a 97' L and 99 RS suspension? BrysImpreza Brakes, Steering & Suspension 6 12-11-2001 01:59 AM
