Closed Thread
Old 10-28-2010, 08:42 AM   #1
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
Default what type of oil and weight do you guys use?
Just curious. i've always used Royal Purple 10W30/10W40 pending on the season for the last 4 yrs. just want to know what the average person uses on their EJ20 G/K/205/207.
Rich
old_duwel is offline
Old 10-28-2010, 11:52 AM   #2
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
There is lots of information in the Service & Maintenance section, but RP is known for shearing down quickly. Lots of us have had success with Rotella T6 5W-40, and the UOA's are great.
sanremo_russ is offline
Old 10-28-2010, 12:05 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
friends dont let friends use RP in their car
Uncle Scotty is offline
Old 10-28-2010, 12:32 PM   #4
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
thanks, my next oil change will be something other than RP. i'll look in the Service & Maintenance section
Old 10-28-2010, 02:39 PM   #5
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
You could probably run Shell Rotella 5w40 and GC 0w30.
Subian is offline
Old 10-28-2010, 02:42 PM   #6
leighton1245
Member#: 210593
2002 WRX PSM
Epic tuned 300whp
I just changed mine to the rotella T6 yesterday runs nice a quite and smooth.
leighton1245 is offline
Old 10-28-2010, 02:52 PM   #7
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
Rotella T6 5w40.
XanRules is offline
Old 10-28-2010, 07:29 PM   #8
Infra_red
Member#: 127001
2008 Legacy 2.5i
Castrol Full Synthetic 5W-30 since I got her 101k ago.
Infra_red is offline
Old 10-28-2010, 08:03 PM   #9
Rallycraft
Member#: 192625
the W stands winter not weight just fyi
Rallycraft is offline
Old 10-28-2010, 08:03 PM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
danger
danger
danger
Old 10-28-2010, 08:28 PM   #11
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Pennzoil ultra euro 5w40
666stars is offline
Old 10-28-2010, 10:22 PM   #12
jagman
Member#: 191135
2004 Impreza WRX
Platinum Silver Metallic
I run Shell Rotella t6 5w40.
Last edited by jagman; 10-31-2010 at 10:46 PM. Reason: Whoops, nevemind. I don't use 15w40, it's 5w40.
jagman is offline
Old 10-28-2010, 11:39 PM   #13
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
<<<--- flogging the snot out of her since new with a stage II+ setup (312whp/360ft/lbs) At almost 70K and oil analysis results have always been great. I use the taboo Mobile 1 5w-30. I often never have to add oil between 3K miles oil changes, and when I have added oil it's no more than 1/4 quart. Half of my mileage is the worst kind; 2 mile trip then turn off the car, hardly ever gets up to full temp and the other half pure highway. While I abuse this car as much as possible, one thing I ALWAYS do is wait until the oil is up to temperature before getting into any boost.
KillerBMotorsport is offline
Old 10-29-2010, 12:44 AM   #14
centeno711
Member#: 184638
2002 wrx wagon wrb
97 cummins 1ton 4x4
ams oil 5-30, i know its expensive but my engine builder swears by it. does oil analysis every oil change and they come back clean every time.
after i lost one to a spun rod bearing from crappy penzoil i decided oil was a good thing to spend some coin on
centeno711 is offline
Old 10-29-2010, 01:18 AM   #15
lovemywagon
Member#: 260725
2004 wrx wagon
sliver and black
pennzoil worst stuff ever
valvailne synth bleand
lovemywagon is offline
Old 10-29-2010, 04:54 AM   #16
fastwrx25
Member#: 126441
03 bugeye
this. I actually had a friend who was using RP 5w30 for his new sti, he was using it because the guy at the dealer "recommended" it to him, and sold it to him. He burned 1L every 1k miles for months, untill I was finally able to convince him to switch to something else, M1 0w40. after that things were normal. true story.
before 98k I never needed to add oil b/w my 7k mile intervals. but now I've been burning alot more 1L every 5k miles. and this was on syntec 0w30....I need to change oil but torn b/w choices.
shell rotella 5w40 or m1 0w40, 5w40, or maybe even one of the true synthethic motul or lubromoly stuff. most likely rotella. its cheaper and easy to get and I need oil change asap.
fastwrx25 is offline
Old 10-29-2010, 10:20 AM   #17
subiebosch
Member#: 155548
2015 2500 Dmax
2011 WRX TP STG2 COBB DP
i had issues with the valvoline burning real quick....i was running M1 then switched to valvoline (a bit cheaper) and in 1500 miles I was down 2.5 quarts. Put M1 back in, no issues....half a quart every 5000 miles with no issues. Not sure why valvoline went haywire. 141k + on the car.
subiebosch is offline
Old 10-29-2010, 10:58 AM   #18
old_duwel
Top Scoob 015
Member#: 18175
99 STI RA Ltd #450
WRB blue
I don't think we get Shell rotella here on Okinawa. i'll look again but on base we have the
Pennzoil
Valvoline
RP
Castrol
M1
and more but i am really interested in the Shell rotella. i'll look on other bases to see if they got that oil. i am due for an oil change and would like to find some good oil to use on a tropical island. maybe M1 5W30 to see if it runs good.
Old 10-29-2010, 11:22 AM   #19
KitchenerWRX
Member#: 79934
02 WRX
MBP
danger
danger
danger
huh? LOL castrol syntec 5w30 is fine don't listen to this gump
past 5 years I've owned a WRX here are the oils I've come across that my engine prefers:
-shell rotella 5w40 (probably the best one)
-german castrol 0w30
-penzoil platinum 5w30
-castrol syntec 5w30
KitchenerWRX is offline
Old 10-29-2010, 11:24 AM   #20
ganzhimself
Member#: 252648
2010 Mini Cooper
Pepper White
Valvoline SynPower 5w30 full synthetic. So far, so good. I like their "300,000 mile engine guarantee" even though I fully doubt they will ever pay out on anyone's engine failure.
ganzhimself is offline
Old 10-29-2010, 05:36 PM   #21
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
So, to what do you ascribe the increased consumption?
bulwnkl is offline
Old 10-29-2010, 06:25 PM   #22
bluesubie
Member#: 767
04 FXT
Really? I'm anxious to hear more details.
-Dennis
Pennzoil Ultra 5W-40
bluesubie is offline
Old 10-30-2010, 01:28 AM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
that castrol is still an energy conserving oil
meaning that it isnt worth a ****
the 5w40 would be a better choice
Old 10-30-2010, 02:25 AM   #24
jddssc121
Member#: 253302
2011 G37x
German Castrol 0w30
Mobile 1 0w40
I also got some Mobil 1 5w30 ESP (not the regular 5w30 which is crap) when it was on sale.
jddssc121 is offline
Old 10-30-2010, 01:44 PM   #25
tribalwrx
Member#: 32993
vf39 Best trap 110
Best ET 12.51 Dale tuned
Shell Rotella 5w40, last 40k since the new motor went in
tribalwrx is offline
Closed Thread
What kind of license plate frame do you guys have? bnr34rb26dett Interior & Exterior Modification 51 04-27-2011 01:49 AM
What type of whey protein/supplements do you take? NewShockerGuy Off-Topic 57 02-15-2010 01:23 PM
What type of HD Media Player do you use? Alaskan_awd Off-Topic 58 11-07-2007 11:32 AM
What type of suspension set up do you use? JLOWRX Brakes, Steering & Suspension 13 11-01-2004 01:14 AM
Poll: What type of board or boards do you ride & what would your next purchase be? breaka19 New England Impreza Club Forum -- NESIC 21 10-09-2000 09:02 AM
