#1 |
Member#: 261612
Vehicle:2011 WRX 5 Door NF Performance Stage 1 |
|xluben's 2011 WRX | NF Performance | Project Dark Knight | ![]() |Spec B 6 Speed | Rotated PTE 6266 | 576WHP / 530WTQ | ![]() ![]() Dyno Plot: ![]() 6266 vs. VF52: ![]() Rotated Turbo Setup: ![]() ![]() ![]() Quick Pull: Quick 40-140 video: Here's another video: 3rd Gear Pull @ 32psi (boost gauge goes wacky above 30psi) 2nd Gear Brake Boost, 3rd, 4th @ 30psi 50-100MPH is ~4 sec for the 3rd Gear Pull 60-130MPH is ~8 sec for the 2nd, 3rd, 4th Pull Exhaust Video: Engine:
2011 WRX Purchased: 10/21/10 MODE Shifter: 11/03/10 SPT Exhaust: 11/07/10 Winter Wheels: 11/12/10 Stage 1 Tune: 11/18/10 COBB Downpipe: 12/19/10 Stage 2 Tune: 12/19/10 IPR TMIC: 1/14/11 Forge BPV: 1/14/11 Defi Boost Gauge: 1/15/11 SMY Dual Gauge Cluster: 1/19/11 Walbro Fuel Pump: 1/27/11 Kartboy Front Shifter Bushings: 1/29/11 DIY Seat Bolster Mod: 02/07/11 Kartboy Rear Shifter Bushing: 02/16/11 GrimmSpeed Master Cylinder Brace: 02/17/11 Red Tail Light Overlays: 02/19/11 Flapatax Mud Flaps: 02/26/11 AEM Cold Air Intake: 02/28/11 GrimmSpeed EBCS and MBC (Hybrid Boost Control): 02/28/11 Fiveo Motorsports 1200cc Injectors: 03/05/11 Custom E85 Tune: 03/05/11 Whiteline 24mm Adj. Front Sway Bar: 04/21/11 Whiteline 22mm Adj. Rear Swaybar: 04/21/11 RalliTEK HD Front Endlinks: 04/21/11 RalliTEK HD Rear Endlinks: 04/21/11 BC Racing Inverted Coilovers: 04/21/11 AEM UEGO Digital Wideband O2 Gauge: 05/23/11 Whiteline 22mm Adj. Front Sway Bar: 05/27/11 GrimmSpeed License Plate Relocation Kit: 06/02/11 Fast Motorsports (FMS) Front Mount Intercooler (FMIC): 06/07/11 OEM Scoopless Hood: 06/13/11 Yakima Roof Rack: 06/27/11 Invidia Q300 Exhaust: 07/22/11 Invidia Catless Downpipe: 07/22/11 Blouch 20G-XT-R Turbo: 9/17/11 GrimmSpeed License Plate Delete: 9/22/11 GrimmSpeed Turbo Heat Shield: 9/23/11 Gold 04 STi BBS Wheels: 09/28/11 KSTech 73mm Intake: 10/01/11 Tial MV-R 44mm EWG, GrimmSpeed Uppipe and Crosspipe: 10/13/11 Omni Power 4 Bar MAP Sensor: 02/06/12 Stock Exhaust: 02/18/12 Blown Motor - Cracked #2 Piston: 02/22/12 Built Shortblock: 03/05/12 TGV Deletes: 03/05/12 AMR 3" Hard Inlet: 03/05/12 Mach V Awesome 17x9" Wheels: 03/21/12 Dunlop Star Spec 255/40R17 Tires: 03/21/12 GFB 50/50 Hybrid BOV: 03/31/12 Turbo XS 50/50 Hybrid BOV: 04/05/12 ACT HD Pressure Plate: 04/06/12 ACT Street Light Flywheel 04/06/12 ACT Sprung 4 Puck Clutch Disc: 04/06/12 Dyno @ MAP: 462WHP / 492WTQ: 04/11/12 RCE Black Springs: 04/14/12 TurboSmart Kompact BPV: 04/18/12 StopTech SS Brake Lines: 04/18/12 StopTech Street Performance Brake Pads: 04/18/12 ATE SuperBlue Brake Fluid: 04/18/12 Koni Adjustable Dampers (Rear): 04/26/12 Koni Adjustable Dampers (Front): 04/27/12 besthaticouldo Shift Knob: 05/08/12 All-In-One Flip Key Mod: 05/16/12 In-Cabin MBC Relocation: 05/22/12 SPT Exhaust: 05/26/12 Blown 5 Speed - Stripped 3 Gear: 06/02/12 V-Limited Front Lip: 06/13/12 [url="http://forums.nasioc.com/forums/showthread.php?p=37362985#post37362985"]DIY Bumper Vent: 06/13/12[/URL] PAR Built 5 Speed: 07/06/12 Stock Exhaust: 07/15/12 Forge BPV: 07/16/12 TurboSmart Dual Port BPV: 07/19/22 Removed Clutch Delay Valve: 07/22/12 Greddy Ti-C Catback: 08/10/12 PTP Turbo Blanket: 08/12/12 Hand Wash and Wax: 09/08/12 Invidia Equal Length Header: 09/25/12 PAR Straight Cut 2nd Gear: 10/14/2012 Kartboy Pitch Stop Mount: 10/14/2012 Cusco Motor and Tranny Mounts: 10/14/2012 Mach V Awesome Decals: 10/18/2012 2 Year Anniversary!: 10/24/2012 Stock Wheels and Winter Tires: 10/28/2012 Stock Exhaust: 10/28/2012 ARK GRiP Exhaust: 11/02/2012 PTP Lava Turbo Blanket: 11/10/2012 GReddy SP Elite Exhaust: 11/14/2012 Exhaust Comparison Photos: 11/18/2012 Kartboy Shifter Comparison: 11/20/2012 VG Shark Fin Antenna: 01/14/2013 Photos Before/After Editing: 01/16/2013 Recaro Baby Seat: 01/28/2013 17x9" RPF1 (Black Background): 01/31/2013 17x9" RPF1 (White Background): 01/31/2013 DCCD Pro Photos: 01/31/2013 STI 6MT Swap Info: 02/11/2013 New Motor and Rotated PTE6266: 03/22/2013
#2 |
Member#: 261612
Click the photo for more images from the same post!
Forge BPV (1/14/11): ![]() IPR TMIC (1/14/11): ![]() Defi Boost Gauge (1/15/11): ![]() SMY Clustermaker Dual Guage Cluster (1/19/11): ![]() Walbro 255 Fuel Pump (1/27/11): ![]() Kartboy Shifter Bushings (1/29/11): ![]() DIY Seat Bolster Mod (02/07/11): ![]() Kartboy Rear Shifter Bushing (02/16/11): ![]() Last edited by xluben; 09-27-2012 at 01:30 PM. |
#3 |
Member#: 261612
GrimmSpeed Master Cylinder Brace (02/17/11):
![]() Defi Oil Pressure Gauge (02/17/11): ![]() Red Tail Light Overlays (02/19/11): ![]() Flapatax Mud Flaps (02/26/11): ![]() AEM Cold Air Intake (02/28/11): ![]() GrimmSpeed EBCS and MBC (Hybrid Boost Control) (02/28/11): ![]() Fiveo Motorsports 1200cc Injectors (03/05/11): ![]() Custom E85 Tune (03/05/11): ![]() Whiteline 24mm Adj. Front Sway Bar (04/21/11): Whiteline 22mm Adj. Rear Swaybar (04/21/11): RalliTEK HD Front Endlinks (04/21/11): RalliTEK HD Rear Endlinks (04/21/11): ![]() BC Racing Inverted Coilovers (04/21/11): ![]() Last edited by xluben; 05-25-2011 at 09:49 AM. |
#4 |
Member#: 261612
AEM UEGO Digital Wideband O2 Gauge (05/23/11): ![]() Whiteline 22mm Adj. Front Sway Bar (05/27/11): GrimmSpeed License Plate Relocation Kit (06/02/11): ![]() Fast Motorsports (FMS) Front Mount Intercooler (FMIC) (06/07/11): ![]() OEM Scoopless Hood (06/13/11): ![]() Yakima Roof Rack (06/27/11): ![]() Invidia Q300 Exhaust and Downpipe (7/22/11): ![]() Blouch 20G-XT-R Turbo (9/17/11): ![]() GrimmSpeed License Plate Delete (9/22/11): ![]() GrimmSpeed Turbo Heat Shield (9/23/11): ![]() Gold 04 STi BBS Wheels (09/28/11): ![]() Last edited by xluben; 10-14-2011 at 09:28 AM. |
#5 |
Member#: 207065
Vehicle:2002 wrx platinum silver |
I like the rims they put on the new wrx.
deff get some red taillight tint. car so clean. |
#6 |
Member#: 207901
South East
Vehicle:2010 2.5i Prem NBP |
#7 |
Member#: 261612
#8 |
Member#: 207901
South East
oh i see. sorry, im a noob. sick car though! the interior is beautiful.
#9 |
Member#: 31960
Vehicle:2011 WRX SSM |
Nice interior shot. The '11 wheels are by far the best OEM wheels on any of the WRX's.
#10 |
Member#: 170156
Vehicle:2010 370z white |
Both car and pictures look great!
#11 |
Member#: 261612
Completely stock Black 2011 WRX 5 Door:
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Last edited by xluben; 10-14-2011 at 09:29 AM. |
#12 |
Member#: 214020
W. Canada
Vehicle:2011 WRX SWP |
No heated seats?
#13 |
Member#: 261612
Nope, not included on the base model. Wasn't something I was too interested in though. I park indoors overnight, so it's not a big deal even when it's cold out.
#14 |
Member#: 214020
W. Canada
Weird how theres little differences in the models between Canada and the US. We get heated seats in the base.
#15 |
Member#: 117776
Vehicle:2011 WRX Limited 5dr WR Blue Pearl |
#16 |
Member#: 261612
Canada!!!!!
#17 |
Member#: 259533
NESIC
Vehicle:2011 WRX Premium 5dr OBP |
Nice pics... I'm waiting for my own obp wrx. If you got the last one left in the country that explains why its been taking so long... Can't wait.
Car photo tip: turn the front wheel so it's facing the camera. |
#18 |
Member#: 221812
TXIC
Vehicle:2003 WRX MBP |
damnnnnn that thing would look soooo good with no wheel gap and some meaty tires.
love the 11 5 doors |
#19 |
Member#: 246057
SCIC
Vehicle:2004 WRX WRB |
I'm officially jealous of you.
#20 |
Member#: 157624
Vehicle:2011 WRX Hatch World Rally Blue |
I'm pretty sure the dealership here in Norwalk, CT had one because I saw it leaving the dealership the other day driven by what looked like a tech. Could have been sold already, I guess.
#21 | |
Member#: 178811
Vehicle:2013 WRB BRZ :banana: |
www.bluebatmobile.net |
#22 |
Member#: 233638
W. Canada
Vehicle:2011 WRX Limited 5dr PBP |
#23 |
Member#: 142559
RMIC
Vehicle:02 psm wagg 06 GSXR 1000 |
Man I love the interiors of these 11's! The dark colors make it look so clean.
#24 | ||||
Member#: 261612
Thanks! |
#25 |
Member#: 222776
NWIC
Vehicle:'08 OBS |
Yeah, really good interior shot. Straight outta the catalogue!
| Thread Tools | |
| Display Modes | |
| xluben's Pictures and Review of the SPT Exhaust for the 2011 WRX 5 Door Hatch | xluben | Car Part Reviews | 26 | 11-08-2012 06:55 PM |
| My first post and my first Subaru, a 2011 WRX 5 door in white. | Decade240 | Newbies & FAQs | 25 | 06-20-2012 01:48 PM |
| 2011 wrx 5 door hatch with Rota 17"x7.5 +48 5x100 wheels? | BretCutler | Tire & Wheel | 4 | 01-14-2011 08:05 AM |
| 2011 WRX 5 Door | Ruz4life | General Community | 55 | 10-13-2010 11:37 PM |
| 2011 WRX 5 Door | Ruz4life | General Community | 10 | 10-04-2010 04:02 PM |
